h&jeuropa
Posted: Fri May 02, 2008 3:52 pm Post subject: Comm Antenna |
I'm having a problem with my comm antenna installed in my Europa. It is a common copper tape antenna with toroids over the coax. Materials and plans came from RST Engineering. Installed in the vertical rudder fin per Europa directions and tuned using a SWR bridge.
When I transmit, certain frequencies cause my ACK ELT to transmit. It is located on the bottom of the fuselage touching the rear bulkhead (under the elevator torque tube). This is about 20 inches forward of the antenna and near the tip of the copper tape. If I disconnect the cable going to the remote actuator, there is no problem. (I had this problem previously and added toroids to the four wires but no change).
Also, when I transmit, certain frequencies cause the magnetometer in my GRT EFIS to swing heading 20 degrees. The magnetometer is mounted on the port side of the fuselage essentially on the fuselage parting line and just at the rear of the D panel bulkhead. This is about 60 inches forward of the antenna and about aligned with the center of the copper tape.
Have others had difficulity with the dipole in the rudder causing problems? Found a solution? How about using other antennas, like Bob Archer?
Jim Butcher
Europa N241BW
nuckolls.bob(at)cox.net Guest
Posted: Sat May 03, 2008 8:28 am Post subject: Comm Antenna |
It's probably not the antenna . . . in fact, the BETTER the antenna
works, the worse the problem(s) get.
When crafting products to live in the real worlds aboard
aircraft, the the thoughtful and through designer tries to
anticipate and accommodate every expected stress that might
attack the product's performance.
This process generally includes an assessment of the
design against guidelines cited in DO-160. See:
http://aeroelectric.com/articles/do160.html
Under the topic of Radiated Susceptibility, DO_160
cites a variety of test levels which a product
must stand of without degradation of performance.
Things that are buried in the guts of an all metal
airplane and have no direct sight of external antennas
(either on airplane or off) have the lowest test
levels. Things that have clear sight of and perhaps
close proximity to antennas have the highest test
levels. There is a HUGE difference between the highest
and lowest levels.
In a small plastic airplane, we're faced with the
worst case scenario for friendly system integration.
The exposure probabilities and magnitudes for the
small plastic airplane are as bad or worse than
any of those encountered by the heavy iron birds.
The variables for electro-whizzies responding badly
to comm (or even transponder) signals fall into
three categories.
(1) strength and signature of the interferring
source. Is it radiating stresses that are normally
expected to be under control? In the case of your
transceiver and antenna installation, the strength
is obviously strong . . . and it's unlikely that
were seeing the effects of spurious outputs.
(2) coupling mode. In this case you have close
proximity, un obstructed spaces between an
antenna that's radiating normally and a device
that operates normally . . . except while you're
transmitting.
Can this feature be mitigated? Probably not in
that size airplane constructed of radio energy
transparent materials.
(3) inability of the offended device to operate
in this environment. Unfortunately, may devices
that have served us well in metal airplanes for
decades are seeing new and un-anticipated problems
in plastic airplanes. They may have been
artfully crafted with the metal airplane in mind.
A further consideration is that devices intended
for the OBAM aircraft market are not being produced
by individuals with knowledge of (or perhaps an
interest in) what's needed to work properly
in this relatively unique environment.
I have one such case on my bench right now. The
Van's aircraft ammeter would be hard pressed to
run the gauntlets necessary for qualification
onto type certificated aircraft . . . much less
an OBAM aircraft.
The task before you is daunting without the
support of skills and experience of individuals
who solve these problems for a living. Your
best bet is to get with the manufacturers of
the victim devices and see if any other customers
have experienced difficulty and what remedies
were useful.
khorton01(at)rogers.com Guest
Posted: Sat May 03, 2008 9:07 am Post subject: Comm Antenna |
> bridge.
It seems that the cable between the ELT and the cockpit control is
acting as an antenna, picking up COM transmissions, and feeding it
into the ELT. This signal coming in on the cable is somehow
interpreted as if the cockpit control had been activated. So, I
wonder if there is a way to shield the cable between the ELT and the
cockpit control, to reduce the amount of energy that it is picking up
from COM transmissions. Also, rerouting that cable further away from
the COM antenna would reduce the energy level it sees.
Bob - the ACK ELT uses a length of apparently conventional telephone
cable to connect the ELT to the cockpit control. Is it worth trying
to replace that telephone cable with some sort of shielded cable,
splicing it into a piece of telephone cable at each end so it has the
correct connectors? If that was tried, where should the shield be
grounded (keeping in mind this is a composite aircraft, and that the
ELT enclosure and cockpit control are both made of plastic)?
Kevin Horton RV-8 (final assemby)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Sun May 04, 2008 5:19 am Post subject: Comm Antenna |
Quote: | It seems that the cable between the ELT and the cockpit control is
I've heard this about the ACK ELTs in the past. I
'presume' they've done their homework and meet all
the test requirements levied on them for qualification
in metal airplanes.
Quote: | Bob - the ACK ELT uses a length of apparently conventional telephone
I presume the problem goes away when the cable is unplugged?
Hmmm . . . shielding a bundle is almost never the best way
to go after an RFI problem. A filter assembly at the ELT's
remote switch connector is the best shot at it. Do you know
which wires in the conductor are common or ground? A few
chokes and capacitors from Digikey could be crafted into
a compact filter that would have high attenuation at
VHF Comm frequencies.
frazitl
Posted: Mon May 05, 2008 8:14 am Post subject: Comm Antenna |
FWIW, I looked up the installation instructions on the artex ME406 ELT
http://www.artex.net/products/oneproduct.php?categoryid=15&productid=87 .
They call for a shielded cable between the ELT and the control panel. I
decided to go with the C91a ELT, but ran the shielded cable from the ELT
location to the panel for future upgrade ease. I'm no expert, but I'd try
the shielded control cable first.
Terry
7A Panel
SNIP
Time: 09:12:01 AM PST US
Subject: Re: switch for smoke pump
Time: 10:07:23 AM PST US
Subject: Re: Comm Antenna
> bridge.
Ottawa, Canada
SNIP
_________________ Terry Frazier
RV7A
Finishing |
rampil
Posted: Mon May 05, 2008 9:01 am Post subject: Re: Comm Antenna |
Hi Jim,
I agree that the ELT remote head cable is picking up the com signal.
Most Europas I have dived into (including mine) use standard
unshielded telephone quad cable. My King 450 ELT does not pick up
the RFI as a test button press however.
The right sized toroids at the ELT end of the cable might help,
Changing the length of the cable (to move it from a resonance, might help,
finally, shield the cable.
Unless of course you think its time to get a new UHF ELT
Alfio
Posted: Mon May 05, 2008 9:06 am Post subject: Re: Comm Antenna |
This may not be your problem or situation, however .....
One thing I noticed about the ACK installation, is that their antenna cannot be substituted for another one. It is part and parcel of the EMC filtering of the unit. According to ACK, other RF signals (e.g. comm) can be received via the ACK antenna port and falsely trigger the unit.
If you did not substitute the antenna, then this would not apply.
Alfio
mprather(at)spro.net Guest
h&jeuropa
Posted: Tue Jun 10, 2008 4:38 am Post subject: Re: Comm Antenna |
I seem to have these problems pretty well solved. Initially tried shielded cables (shield grounded to A/C ground point near inst panel - unconnected at other end) with lots of toroids to the ELT and Magnetometer. Also made the interconnect between the Primary Flight Display and the MFD a shielded cable. Had little or no effect. Then tried just shielded cable (no toroids) to ELT and wrapped the entire ELT in aluminum foil. Foil is connected to the cable shield and ground is as before. That solved the ELT problem. From other forums I learned that there are D Sub filters which have capacitors built in bypassing each connection to the shell of the connector. Acquired Spectrum Control Series 100 filters, 5600 pf (from Newark Electronics) for the Magnetometer and the PFD (main display). At the Magnetometer I connected the cable shield to the D Sub shell since the shell is floating inside the Mag and I needed a return for the filter. Found the PFD filter didn't have any effect but the Mag helped some. Finally wrapped the Mag in aluminum foil which is connected to the shield and that seemed to solve the problems. I think there is so much RF from the com antenna and no shielding because of the composite, that it overwhelms the ELT and Magnetometer.
I also found a local ham with an antenna analyzer (MFJ Model 269) and had a look at my com antenna. Found it had very low SWR but the resistance of the antenna changed if I walked near the antenna and the resistance was not constant or nearly so across the 118 to 136 Mhz range. We both suspected the toroid balun just didn't perform properly. So we decided to make a balun from coax as the ham radio books have shown for years. It is very much like the one on the Aero Electric website except the length of the balun section is an electrical half wavelength, so you must take into account the velocity factor of the cable. Using RG400 (vf=.695), the balun section is 16 1/4" long. Took off the toroids and installed the new balun. Had to trim the antenna to get the SWR low near the center of the band, but now the SWR is less than 2:1 across the entire band, the resistance stays constant and walking near the antenna makes no difference.
Hope this helps someone else.
Jim Butcher
Europa N241BW
