Fuel tank - bulges and leakage.
Goto page Previous  1, 2, 3, 4
ami(at)mcfadyean.freeserv
PostPosted: Sun May 04, 2008 11:34 pm    Post subject: Fuel tank - bulges and leakage. Reply with quote
I'm not aware that the Europa tank is made of HDPE; which is actually highly
resistant to a wide range of chemicals, hence its widespread use as basal
liners to landfills.
I don't suppose the HDPE automotive tanks are rotary moulded either.
The Kitfox rotary moulded tanks were made of cross-linked LDPE, and I'd
presumed the Europa tanks were the same. LDPE has a "benefit" of being more
elastic than HDPE.
FWIW, I have the old style non-fluorinated tank. So far it hasn't bulged,
split or leaked. However, fuel permeation is noticeable, as it was on the
Kitfox too.
Duncan Mcf.
sidsel.svein(at)oslo.onli
PostPosted: Mon May 05, 2008 4:03 am    Post subject: Fuel tank - bulges and leakage. Reply with quote
Duncan,
During this current thread, I introduced the assumption that the Europa
tanks are made of HDPE. Based on the extensive bulging some have
experienced, however, my source of much more knowledge than I possess
assumes it might be LDPE - which he in general does not find suitable for
gasoline containers. There are some unfortunate "Europeans" who can attest
to that - - - - .
As others have stated already, gasoline composition varies from brand to
brand, etc.
The fact that your non-fluorinated tank has not bulged is quite interesting.
What type of fuel have you used - unleaded mogas or leaded Avgas?
Svein
LN-SKJ
PS: EA2004 has not been open for business since I copied them one my
previous messages, asking their comments. Today is Bank Holiday in the UK.
highly resistant to a wide range of chemicals, hence its widespread use as
basal liners to landfills.
more elastic than HDPE.
Kitfox too.
Duncan Mcf.
fklein(at)orcasonline.com
PostPosted: Mon May 05, 2008 8:59 am    Post subject: Fuel tank - bulges and leakage. Reply with quote
On Monday, May 5, 2008, at 00:30 US/Pacific, Duncan & Ami McFadyean
use as basal liners to landfills.
Duncan,
My apologies...I incorrectly gathered from the thread that our tanks
were HDPE; hopefully, we'll learn soon enough for certain.
The article I referenced on 5/4,
http://www.tms.org/pubs/journals/JOM/9607/Alvarado-9607.html#ToC7 ,
dated 1996, about HDPE tanks in automobiles, does mention "rotary style
blow-molding machines" which I took to be equivalent to the
"roto-molded" process mentioned in Europa literature; again, I may be
incorrect.
What struck me about the article was that back in 1996 in the auto
industry there was no consideration for the use of LDPE...and it
includes a nice synopsis of the evolving HDPE technology (barrier
coatings, mono vs. multi-layer), regulatory issues (permeability
standards), and fuel compatibility (methanol/ethanol, additives,
flex-fuel vehicles).
Fred
believed to be clean.
h&jeuropa
PostPosted: Thu May 08, 2008 10:10 am    Post subject: Re: Fuel tank - bulges and leakage. Reply with quote
Just a data point on this discussion. Our Europa first flew in Oct 2005. After a ground loop in Sept 2006 the fuel tank has been empty during repair. I filled it this week and have no leaks.
Granted, our climate is much cooler than some. The empty tank probably never saw ambient temps in excess of 80 deg F.
This is kit A185 which was delivered May 2000. We screwed up the install of the fuel tank initially and got a replacement tank from Lakeland in Sept 2000. My guess is it was from a kit on hand.
Tank has only had MoGas in it, no 100LL.
I have no idea why ours is OK and others have split, but I'm glad it turned out that way!
Jim & Heather
B241BW
Page 4 of 4
