Reality check
bretttdc(at)yahoo.com
PostPosted: Sun Jan 08, 2006 8:20 am    Post subject: Reality check Reply with quote
I completely agree with Mike. I have seen the STOL
701 operating from extremely short strips. Five
hundred feet can be enough but you will need some
additional STOL training. If you want to continue to
touch down at 50mph you will need a longer strip. The
all terrain gear with disk brakes would be a big plus
in this type of operation as well.
My first STOL ride was in Costa Rica. The plane was
flown by a Colombian that had been flying a different
701 as a crop duster. During the flight he turned to
a short final on a strip that could not have been an
inch over 400'. I was almost in shock as the plane
came to rest with a considerable bit of the strip left
in front of us. I have seen videos of this same
person landing the 701 in the length of a long city
bus!! Granted, he had a gentle headwind and a uphill
grade on the strip. Even with those factors
considered I was impressed.
I do not think that there are very many pilots out
there that have mastered the short field capabilities
of the 701. Check the builders section on the Zenith
website. There you will find an article on learning
to do short take offs and landings. Please be sure to
practice and refine your technique where you have
plenty of room until you have it mastered. You will
know when you are ready to take on the the shorter
strip with confidence.
Brett
Time: 08:24:03 PM PST US
Subject: Re: Zenith-List: Re:Take-off roll reality
check...
<mike.sinclair(at)att.net>
Doug
I can pretty much guarantee you can get the 701 into
and out of places
you
won't get the 206. With just an 80 hp engine, about a
10 degree uphill
slope,
and 15 degrees of flaps, I'm still off in under 200
feet. Full flaps, a
15
kt. headwind, and I was off the ground in about 30-50
feet. The
shortest
strip I have landed on so far, a friend of mine has a
strip about 700
feet
long and landing from the north you have to clear some
30 foot oil
field
power lines that are about 70 yards north of the
barbed wire fence at
the end
of the strip. Still can get it on the ground and
stopped by about the
halfway
point. Looking forward to the takeoff (and climb)
performance
--- Zenith-List Digest Server
<zenith-list-digest(at)matronics.com> wrote:
dralle.txt gigi.txt grant.txt matt.txt save.txt
