Alfred Buess
Posted: Wed Apr 30, 2008 11:40 pm Post subject: AW: New HOBBS Idea |
There is another clever solution for hooking up the Hobbs to your engine:
Comco Ikarus (http://www.comco-ikarus.de/index_english.html) sells an
electronic filter produced by Utz Schicke (producer of the Schicke GR6
regulator for Rotax engines) which hooks directly to the AC wires of the
alternator. Whenever the alternator is in action (even with the regulator
shut off), the Hobbs (or an other brand of hour meter) gets DC power and is
active too. I got my filter for 65 Euros.
Alfred
Alfred Buess, CH-3052 Zollikofen, Switzerland
E-Mail: ykibuess(at)bluewin.ch
Europa XS #097, Monowheel, Foam wing, Rotax 912ULS, Airmaster 332 CS
-----Ursprüngliche Nachricht-----
Von: owner-rotaxengines-list-server(at)matronics.com
[mailto:owner-rotaxengines-list-server(at)matronics.com] Im Auftrag von rampil
Gesendet: Montag, 14. April 2008 12:43
An: rotaxengines-list(at)matronics.com
Betreff: New HOBBS Idea
At SnF this year, my best find was a small device for engine time recording.
It is completely independent of and connections to the rest of the aircraft
(power or engine). It time the duration of vibration!
When the engine is running, the timer is going with its own 5 yr battery.
Its made by ENM and I purchased it at PSA aircraft Supply (Lakeland, FL) for
$22 (half retail from ENM)
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=176686#176686
nuckolls.bob(at)cox.net Guest
Posted: Tue May 06, 2008 11:08 am Post subject: AW: New HOBBS Idea |
At 09:37 AM 5/1/2008 +0200, you wrote:
<ykibuess(at)bluewin.ch>
It's also possible to do-it-yerself. Here's an approach
I sketched for some folks several years ago:
http://www.aeroelectric.com/Pictures/Schematics/Hourmeter_Adapter_for_PM_Alternators.pdf
It's a simple AC/DC rectifier combined with a shunt regulator
to keep the capacitor from charging up to un-restrained maximum
that can be well over 50 volts in cruise rpm.
The transistor needs to be heat-sinked to an aluminum
enclosure. It should also be insulated from the heatsink.
Hence the call-out for an insulator kit on the drawing.
longg(at)pjm.com Guest
Posted: Tue May 06, 2008 11:57 am Post subject: AW: New HOBBS Idea |
Ira,
Great find. This has to be the simplest solution yet. No wires! Yeah! I suppose it still have moving parts like those old Swiss watch movements where you shook them up to wind them, but it should last for years. The best price I found so far is about $50.00 from ENM. If anyone finds a better price, please post.
rampil
Posted: Wed May 07, 2008 3:01 pm Post subject: Re: AW: New HOBBS Idea |
Hi LongG,
It may have been a show special price, but PSA is still worth a try at
http://www.psaenterprises.com/
I am using the little guy in car at the moment, trying to build some hours on it
