dlm46007(at)cox.net Guest
Posted: Tue May 06, 2008 8:45 am Post subject: RPM |
Having difficulty getting 2700 RPM on the IO540D4A5 and the Hartzell CS prop. Have tried adjusting the prop low pitch stop without positive results. Did anyone else have to adjust the sped control inside the governor or was the use of the set screws enough?
Posted: Tue May 06, 2008 9:54 am Post subject: RPM |
I seem to remember in one instance having to move the arm on the governor one notch, but that makes a big difference. Usually the set screw stop will give you the needed change.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On May 6, 2008, at 12:41 PM, David McNeill wrote:
| Quote: | Having difficulty getting 2700 RPM on the IO540D4A5 and the Hartzell CS prop. Have tried adjusting the prop low pitch stop without positive results. Did anyone else have to adjust the sped control inside the governor or was the use of the set screws enough?
Randy(at)abros.com Guest
Posted: Tue May 06, 2008 3:11 pm Post subject: RPM |
The problem might be that your governor is kicking in too early. When I made the initial run-up to check for max rpm I backed off the stop set screw on the governor is not in the loop. Then make the adjustment on the stop screw on the prop hub. Randy 40006
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Tuesday, May 06, 2008 10:52 AM
Subject: Re: RPM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
n277dl
Posted: Tue May 06, 2008 6:24 pm Post subject: Re: RPM |
Just a thought... may get someone with a remote gun to check the prop speed. No clue what tach you're using but on the grt eis there is a "factor" to choose for accurate readings. If you choose the wrong one of course you'll not get the correct reading (don't ask how I know) and you'll think you're not getting the max rpm.
Folks that balance props have remote gun to shoot the prop.
Doug
_________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
ricksked(at)embarqmail.co Guest
Posted: Tue May 06, 2008 7:03 pm Post subject: RPM |
AND STAY WAY BACK OF THE BLADES WHEN YOU USE THAT OPTICAL TACH GUN, it doesn't need to be that close to count them going by.
Rick Sked
40185
