mp.gamble(at)tiscali.co.u Guest
Posted: Mon May 05, 2008 8:20 am Post subject: Switch for Hobbs. |
What are chaps using to switch their hobbs timer on with engine start? Is there an alternative to the n/o oil pressure switch? - perhaps sensing alternator output.
Mike Gamble
topglock(at)cox.net Guest
Posted: Mon May 05, 2008 9:58 am Post subject: Switch for Hobbs. |
Mike,
I used a standard marine ignition switch to supply current to the
starter, with rockers for the ignition circuit. The "run" side of the
ignition switch supplies power for the hobbs and the trim circuit breaker.
Jeff - Baby Blue
Mike Gamble wrote:
| Quote: | What are chaps using to switch their hobbs timer on with engine start?
Mike Gamble
Checked by AVG.
nwcmc(at)tiscali.co.uk Guest
Posted: Tue May 06, 2008 6:34 am Post subject: Switch for Hobbs. |
Attached is the circuit I used.
Nigel Charles
63.67 KB |
345 Time(s) |
gcsmith(at)flyer.co.uk Guest
Posted: Wed May 07, 2008 7:04 am Post subject: Switch for Hobbs. |
I used a small vacuum switch from Radio Spares connected to the engine-driven vacuum pump
Graeme Smith
G-CCGW
2008/5/5 Mike Gamble <mp.gamble(at)tiscali.co.uk (mp.gamble(at)tiscali.co.uk)>:
[quote] What are chaps using to switch their hobbs timer on with engine start? Is there an alternative to the n/o oil pressure switch? - perhaps sensing alternator output.
Mike Gamble
dangerous content by Houxou, and is
believed to be clean. [b]
Troy Maynor
Posted: Thu May 08, 2008 6:13 pm Post subject: Switch for Hobbs. |
Mike,
Aeroelectric sells a double throw oil pressure switch you can connect up that when engine is not running turns on an oil light LED for a Master Switch left on warning, and flips the other way when engine is running to operate a hobbs. FWIW......Not flying yet so can't vouch, but that's my plan.
Troy Maynor
Visit - www.EuropaOwners.org
