		| Author | Message |
		| Alfred Buess
				|  Posted: Wed May 07, 2008 10:21 am    Post subject: AW: Switch for Hobbs. |   |
				| Mike,
Comco Ikarus (http://www.comco-ikarus.de/index_english.html, I have no commercial relations to them, but can  recommend their excellent customer support) sells an electronic filter  produced by Utz Schicke (producer of the Schicke GR6 regulator for Rotax  engines) which hooks directly to the AC wires of the alternator. Whenever the  alternator is in action (even with the regulator shut off), the Hobbs (or an  other brand of hour meter) gets DC power and is active too. It costs 65 Euros.
 Alfred
 иииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии
 Alfred Buess, CH-3052 Zollikofen,  Switzerland
 E-Mail: ykibuess(at)bluewin.ch
 Europa XS #097, Monowheel, Foam wing, Rotax 912ULS,  Airmaster 332 CS
 Von: owner-europa-list-server(at)matronics.com  [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Graeme  Smith
 Gesendet: Mittwoch, 7. Mai 2008 15:59
 An:  europa-list(at)matronics.com
 Betreff: Re: Switch for  Hobbs.
 I used a small vacuum switch from Radio Spares connected to the  engine-driven vacuum pump
 Graeme Smith
 G-CCGW
 2008/5/5 Mike Gamble <mp.gamble(at)tiscali.co.uk (mp.gamble(at)tiscali.co.uk)>:
 [quote]      What are chaps using to switch their hobbs timer    on with engine start? Is there an alternative to the n/o oil pressure switch?    - perhaps sensing alternator output.
 Mike Gamble
 This message has been    scanned for viruses and
 dangerous content by Houxou, and is
 believed to be clean.
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
		| Back to top |  |
		| rampil
		| Back to top |  |
		| craigb(at)onthenet.com.au Guest
				|  Posted: Wed May 07, 2008 3:53 pm    Post subject: AW: Switch for Hobbs. |   |
				| thats quite good isnt it, I think i will go that way
		| Back to top |  |
		| rowil(at)clara.net Guest
				|  Posted: Fri May 09, 2008 4:28 am    Post subject: AW: Switch for Hobbs. |   |
				| At 2008-05-07 16:12 -0700 rampil wrote:
  	  | Quote: |  	  | The simplest device requiring no connections at all is the vibration- sensitive timer made by ENM
 Ira - sounds great ... then I realised that there is no way to turn
 it off, and so it will probably record road time in the trailer for
 me as well as air time!
 regards
 Rowland
 | Wilma & Rowland Carson    http://home.clara.net/rowil/
 | <rowil(at)clara.net>          ... that's Rowland with a 'w' ...
		| Back to top |  |
		| rampil
				|  Posted: Fri May 09, 2008 9:13 am    Post subject: Re: AW: Switch for Hobbs. |   |
				| Rowland,
That could well be a problem.
 There actually a loop of wire in the back of the meter which you
 cut to activate the timer. You could splice in a switch to detect wings
 on, airspeed>60, etc. If trailering is frequent though, I'd look for a
 different solution.  N224xs lives in a hangar far from my old
 earthquake shaken home of KSQL
 Ira N224XS
		| Back to top |  |
