Look doors Mecanisms
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith640-List
cj.tremblay(at)videotron.
PostPosted: Mon May 05, 2008 6:39 am    Post subject: Look doors Mecanisms Reply with quote
Hi Steeve C
6nbsp;
If you have numeric camera C it would be nice if you can 6nbsp;provide us a close photography of those mecanisms E I am interest to see how this is setup on you plane C and check with my owne plan E If not possible or too much trooble for you C I will understand E
6nbsp;
Thanks again for your collaboration E
6nbsp;
Christian Tremblay
Plan buider 3 59
http: //www Ezodiac640 Ecom
----- Message d 7origine -----
De: steveadams 6lt;dr_steve_adams(at)yahoo Ecom 6gt;
Date: Lundi C 5 Mai 2008 C 8:00 am
Objet: Zenith640-List: Re: 640 Builders Check-In
À: zenith640-list(at)matronics Ecom
6gt; -- 6gt; Zenith640-List message posted by: 2steveadams 2
6gt; 6lt;dr_steve_adams(at)yahoo Ecom 6gt;
6gt; There have been instances of the doors departing in flight on
6gt; the Alarus E There was a modification of the latch mechanism so
6gt; there are 2 positive stops when latching; the first a kind of
6gt; safety stop C and the second fully closed E There is quite a bit
6gt; of negative pressure on the doors when flying C so obviously you
6gt; need to ensure the latches are fully closed and brief all
6gt; passengers not to open the latch in flight E Unlike some aircraft
6gt; with clamshell doors C the latch mechanism is quite simple and
6gt; easy to check to ensure it is closed E I also check the hinges as
6gt; part of the preflight E
6gt;
6gt; As far as cruise speed E At 7-8000 feet I cruise at 130kts TAS E
6gt;
6gt;
6gt;
6gt;
6gt; Read this topic online here:
6gt;
6gt; http://forums Ematronics Ecom/viewtopic Ephp?p=181198 3181198
6gt;
6gt;
6gt;
6gt;
6gt;
6gt;
6gt;
6gt; _-============================================================
6gt; _-= 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; - The
6gt; Zenith640-List Email Forum -
6gt; _-= Use the Matronics List Features Navigator to browse
6gt; _-= the many List utilities such as List Un/Subscription C
6gt; _-= Archive Search 6amp; Download C 7-Day Browse C Chat C FAQ C
6gt; _-= Photoshare C and much much more:
6gt; _-= 6nbsp; 6nbsp; -- 6gt; http://www Ematronics Ecom/Navigator?Zenith640-List
6gt; _-
6gt; = 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; - MATRONICS WEB FORUMS -
6gt; _-= Same great content also available via the Web Forums!
6gt; _-= 6nbsp; 6nbsp; -- 6gt; http://forums Ematronics Ecom
6gt; _-
6gt; = 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; - List Contribution Web Site -
6gt; _-= 6nbsp; Thank you for your generous support!
6gt; _-
6gt; = 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; 6nbsp; -Matt Dralle C List Admin E
6gt; _-= 6nbsp; 6nbsp; -- 6gt; http://www Ematronics Ecom/contribution
6gt;
6gt;
6gt;
- The Matronics Zenith640-List Email Forum -
http://www.matronics.com/Navigator?Zenith640-List
steveadams
PostPosted: Tue May 06, 2008 4:07 pm    Post subject: Re: Look doors Mecanisms Reply with quote
Maybe I wasn't too clear. On the very early ch2000 models I think the latch had only a single notch. That was changed to the current latch with 2 notches quite a while ago. I made no modification to this system myself and the stock design is simple and sturdy. Do make sure that when you do the final install you put some locktite on the screw that holds the inside latch in place and check it occasionally because it will loosen with use if you don't (that 1 screw is what holds the door in place in flight so having it come out would be a bad thing). The same is true for the 2 allen head screws used for hinge pins in the door. I found mine had backed out a little bit over the first 100 hours. I put a little locktite on them and they have held tight ever since.
Steve
seattle
PostPosted: Wed May 07, 2008 8:41 pm    Post subject: Re: Look doors Mecanisms Reply with quote
For cooling, do you taxi with the doors up?
steveadams
PostPosted: Thu May 15, 2008 11:56 am    Post subject: Re: Look doors Mecanisms Reply with quote
No, even with the engine idling they would at the least be damaged and likely torn off. They are sturdy when closed, and big enough to make getting everything and everybody in when opened, but are just not designed to be open and flapping in the breeze.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith640-List All times are GMT - 8 Hours
