user9253
Joined: 28 Mar 2008 Posts: 1978 Location: Riley TWP Michigan
Posted: Thu May 08, 2008 10:24 am Post subject: RV-12 toolkit |
Below is an RV-12 toolkit from the Avery Tools website.
$1,375.94 seems like a lot. Is it worth it?
Joe
http://www.averytools.com/pc-991-68-rv-12-kit.aspx
The New RV-12 Toolkit is here! This originated from the tool list in the RV-12 Plans, and was then reworked and verified with the kit manufacturer. Some items from the list are not included here but can be obtained at a local store.
Part # Description
__________________________________________
9430 3” AVERY HAND RIVET SQUEEZER<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
3/32 DDS SP 3/32” DIMPLE DIE W/SMALL DIA. FEMALE
1/8 DDS 1/8” DIMPLE DIE SET
#8 DDS #8 DIMPLE DIE SET
1621 1/8” FLUSH SET
1627 1/2” FLUSH SET
1602 SP 1/8”X 1/2” CUPPED SET
1017 1/8” (30) CLECOS (350 PCS.)
1016 3/32” (40) CLECOS (50 PCS.)
1012 1/2”X1 SIDE GRIPS (5 PCS.)
1014 1/2”X1/2” SIDE GRIPS (5 PCS.)
200 CLECO PLIERS
40 #40 COBALT DRILLS (4 PCS)
30 #30 COBALT DRILLS (3 PCS)
19 #19 COBALT DRILLS (2 PCS)
12 #12 COBALT DRILLS (2 PCS)
52 #52 COBALT DRILLS (4 PCS)
12X30 #30 X 12” EXTENSION DRILL
1/4 1/4” COBALT DRILL (1 PC)
11 #11 COBALT DRILL
16 #16 COBALT DRILL (2 PCS)
3 # 3 COBALT DRILLS (2 PCS)
5/16 5/16 COBALT DRILL 1 EACH
11/32 11/32 COBALT DRILL 1 EACH
11076 #40 PLEXIGLASS DRILL
11077 #27 PLEXIGLASS DRILL
500 FLUTING PLIER
575 HAND SEAMER
1046 SPEED DEBURRING TOOL
22022 ROYAL MULTI-BURR TOOL
1052 #30 C’SINK CUTTER
1051 #40 C’SINK CUTTER
1053 #27 C’SINK CUTTER
30-120 SPECIAL #30 X 120 CUTTER
19360 MICRO-STOP C’SINK CAGE
7891 PNEUMATIC POP RIVET PULLER
P26A TIGHT SPACE POP RIVETER
4910 ADJUSTABLE TORQUE WRENCH
UBX3 UNIBIT #3 1/4” to 3/4”
6510L OFFSET SNIPS - LEFT
6510R OFFSET SNIPS - RIGHT
212 PARKER ROLO-FLAIR FLARING
470-FM TRIPLE HEADED BENDER
7447 S/B GEN. PURPOSE HAND PADS
4510 SMALL BLOCK FOR DIES
15357 1/4” UNDERSIZE REAMER
6-32 6-32 TAP
3/8-16 3/8-16 TAP
3/8-24 3/8-24 TAP
1/4-28 1/4-28 TAP
72758 6 PC. 4” SMOOTH FILE SET
17695 SAFETY GLASSES
RV-12 Kit
SKU: Kit-107
Price: $1,560.00
On Sale For: $1,375.94
| | - The Matronics RV12-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV12-List |
_________________ Joe Gores |
Jim Cone
Posted: Thu May 08, 2008 10:36 am Post subject: RV-12 toolkit |
You need all of these tools and it is a good value. You can probably find a few of these items cheaper, but getting everything that you need with good quality is the way to go. Avery is one of the best companies and really supports the RV community.
Jim
From: owner-rv12-list-server(at)matronics.com [mailto:owner-rv12-list-server(at)matronics.com] On Behalf Of Joe
Sent: Thursday, May 08, 2008 11:25 AM
To: rv12-list(at)matronics.com
Subject: RV-12 toolkit
Joe
Part # Description
1621 1/8” FLUSH SET
1627 1/2” FLUSH SET
200 CLECO PLIERS
11 #11 COBALT DRILL
500 FLUTING PLIER
575 HAND SEAMER
6-32 6-32 TAP
3/8-16 3/8-16 TAP
3/8-24 3/8-24 TAP
1/4-28 1/4-28 TAP
RV-12 Kit
SKU: Kit-107
Price: $1,560.00
| Quote: | | http://www.matronics.com/Navigator?RV12-List | 0123456789
Checked by AVG.
5/7/2008 5:23 PM
_________________ Jim Cone
3-peat offender
2 RV-6A's & 1 RV-7A
EAA Tech Counselor
EAA Flight Advisor |
