ron.mcgann(at)baesystems. Guest
Posted: Thu May 08, 2008 2:55 pm Post subject: Wing Tips |
G'day all,
Recently completed the final installation of the wingtips with lights, Archer navs, MB etc. Needed to trim the TE 3/8" - 1/2" to align with the aileron - not too bad. I did notice though that the aft underside of both both tips were extremely loose and wobbled like really bad oil canning (even with the closeout rib and fully screwed to the wing). Easily fixed by gluing in a foam support rib toward the trailing edge, but I was wondering whether others have experienced this?
Cheers,
Ron
-187 finishing (waiting on window glue!) [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Posted: Thu May 08, 2008 8:24 pm Post subject: Wing Tips |
Ron,
Mine seemed pretty sturdy but I went the hinge route instead of screws. I also fabricated an outer flush rib that fits inside the tip made out of .063 sheet that is held against the hinges and inner rib in the opening with two screws and nutplates on the inner rib. This conceals my hinge pins and makes the closeout of the wingtips neat and clean, no hole or recess and allows access to easily pull the hinge pins to remove the tip. Yeah I know...someone will want photos...I'll need to go through my vast files and reduce the image so I can post it...
PS-I only had to sand my tips TE...they were one of the first batches sent out after Vans made the fix...or I just got lucky.
Rick Sked
40185
VHMUM(at)bigpond.com Guest
Posted: Thu May 08, 2008 9:56 pm Post subject: Wing Tips |
Ron I too had to cut heaps off but seem sturdy once fitted.
Chis
johngoodman
Posted: Fri May 09, 2008 3:25 am Post subject: Re: Wing Tips |
| VHMUM(at)bigpond.com wrote: | Ron I too had to cut heaps off but seem sturdy once fitted.
Chis
I got mine from Van's about a year ago, and I'm 1/16" long on the left and 1/16" short on the right. Will sand the left but I can't see trying to build up the right - maybe some leftover micro or something.
I found the trailing edge rib an issue. It doesn't appear to be large enough. I added a scab piece which helped a little.
John
_________________ #40572 Phase One complete in 2011 |
wcurtis(at)nerv10.com Guest
Lew Gallagher
Posted: Fri May 09, 2008 5:45 am Post subject: Re: Wing Tips |
Hey William,
Thanks for the pictures ... the nav antenna pictures and tie downs are even more of interest to us right now than wing tip length.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
