darnpilot(at)aol.com Guest
Posted: Fri May 09, 2008 8:23 am Post subject: Alternator noise |
| Quote: | Howdy:
Any electrical gurus: I need an alternator noise filter (28v system). Any ideas where to get a good one at a reasonable price?
Thanks!
Jeff |
Plan your next roadtrip with MapQuest.com: America's #1 Mapping Site.
jaycwik(at)gmail.com Guest
Posted: Fri May 09, 2008 8:55 am Post subject: Alternator noise |
I'm far from a guru, But I converted my Tripacer from a Generator to alternator a couple years ago. I tried to solve alternator noise with a progression of "Cheap" to Expensive filters to no avail.
Turns out the cure was the ground to the antenna. While sufficient with the generator, I needed a better, slightly heavier wire - then no problems.
On Fri, May 9, 2008 at 11:19 AM, <darnpilot(at)aol.com (darnpilot(at)aol.com)> wrote:
[quote] | Quote: | Howdy:
Thanks!
Jeff |
