Davcoberly(at)wmconnect.c Guest
Posted: Fri May 09, 2008 4:32 pm Post subject: front fuselage skins |
Just wondered if anyone has had any trouble getting their new prepunched/cut front fuselage skins to fit right. Mine if I line up the precut spar hole then the aft rivet line is aft of the rear attach plate which has to rivet to the seat back channel which is forward of the attach plate also the baggage rivet holes are off. If you get these right the main spar and upright angle rivet holes are off 10 mm or more. I have measured and measured and I can find nowhere I'm off. Just thought some others might be having problems with these new skins. David Coberly [quote][b]
cndmovn(at)gmail.com Guest
Posted: Fri May 09, 2008 4:45 pm Post subject: front fuselage skins |
YES!
I lost a two weeks in construction for the same issue.
Contact me off list at cndmovn(at)gmail.com (cndmovn(at)gmail.com) and I will tell you what they told me.
Cheers
Paul
On Fri, May 9, 2008 at 8:27 PM, <Davcoberly(at)wmconnect.com (Davcoberly(at)wmconnect.com)> wrote:
[quote] Just wondered if anyone has had any trouble getting their new prepunched/cut front fuselage skins to fit right. Mine if I line up the precut spar hole then the aft rivet line is aft of the rear attach plate which has to rivet to the seat back channel which is forward of the attach plate also the baggage rivet holes are off. If you get these right the main spar and upright angle rivet holes are off 10 mm or more. I have measured and measured and I can find nowhere I'm off. Just thought some others might be having problems with these new skins. David Coberly [b]
lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Fri May 09, 2008 5:50 pm Post subject: Re: front fuselage skins |
Why not post it Zenith's response here?? I wrestled with the same problem but eventually made it all work
Larry Whitlow
601XL
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Sun May 11, 2008 5:15 pm Post subject: Re: front fuselage skins |
| Davcoberly(at)wmconnect.c wrote: | | I have measured and measured and I can find nowhere I'm off. |
I spent a ton of time agonizing over this as well.
In my case, what really started costing me time was a new digital level that I started using that is accurate to within .1 of a degree. I found myself continuously doing, redoing, redoing, and redoing again in futile attempts to get everything within .1 of a degree of everything else.
At that level of accuracy I think the expansion of metal in my shop (winter temperates well below zero at night to heated temperatures of ~60 degrees on a daily basis) come into play. Or maybe phases of the moon or something. I could get everything perfect, walk away and come back the next day and stuff would be .1 or .2 degrees off.
IMHO, accuracy is important, but these are not Mach 3 fighter planes we're building, and it's very easy to waste time beyond the point of diminishing returns in the quest for accuracy that is not obtainable by the human hand...
- Pat
