				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| carl(at)flyers.freeserve. Guest
				|  Posted: Sat May 10, 2008 2:53 am    Post subject: Europa safety and the LAA |   |
				| I have changed the title of this thread for obvious reasons but also because
the argument seems to be about how safe our Europas are and how dilligent
 and thorough the PFA and their inspectors are. The AAIB report merely
 highlights the issue which I for one believe dosent exist.
  	  | Quote: |  	  | With all respect to the AAIB and all others involved, i have difficulties understanding the bearing of the report. Since there are a lot of flying
 Europa's, mine being one of them, i would prefer to ask explanation and
 remaining questions to be answered, even if this keeps wounds open.
 The AIIB have made it very clear that whilst their remit is not to apportion
 blame, that there was no fault either on the owners, the inspector or the
 PFA' part and that the cause of the failure (ie: poor build quality) could
 not have been identified after the build by the inspectors concerned or on
 subsequent inspections. It is even possible that the original builder was
 unaware of the error he had made.
 I have read the report several times and it would seem to me that they have
 left no stone unturned and explored every possible reason for this
 catastrophe.
  	  | Quote: |  	  | There is no validation in the report about the quality of the inspection, although the plane broke up shortly after.
 This comment verges on slander - sorry but I cant put it any other way. I am
 sure you didnt intend it but thats how it comes accross. My initial reaction
 is where is your evidence of a culture of cover ups. Most PFA inspectors
 take their roles very seriously and there is no reason whatsoever to suggest
 that the annual inspection was in any way sub standard (this seems to be
 what your comment implies).
 My understanding is that no one knows whether the flight test took place. I
 assumed at the time of the accident that the flight test could have been
 conducted during the return flight home as this is the usual practice with
 annual inspections (ie: the next flight after inspection). The report does
 not say that the flight test was conducted at Bodmin (after the inspection)
 but equally the AAIB have not said if notes/ documentation (ie: the flight
 test schedule) were found in the wreckage. I think it is safe to assume that
 if there were notes this would have been mentioned in the AAIB report.
  	  | Quote: |  	  | There is no recommendation for improvement of these inspections, other then a case triggered inspection on the points involved. I have seen only a few
 >PFA inspected builds and planes myself, and some of them had obvious build
 and or repair AND inspection failures. There seems to be a culture of
 trying >to keep problems under the table and out of sight. This all makes
 me wonder where the responsibilities are and should be.
 I cannot believe you are unaware of Mods 73 and 74 (and the grounding/
 restrictions imposed on the entire Europa fleet) . Hardly what I would
 describe as keeping problems under the table. As regards the Europa fleet
 the PFA has a list of potential problems/ issues which inspectors should pay
 particular attention to whan carrying out inspections.
 The follow up/ safety actions are described at the end of the AAIB report
 and IMHO would appear to be entirely suitable.
  	  | Quote: |  	  | Others have landed with disengaged anti-trim-tab lift pins, although the
 forces were excessive. However, disengaged trim tabs are not taken in
 account as the failure triggering event. Did i miss the reasoning behind
 that?
 It is interesting to note that you say LANDING with the tab disconnected.
 This dosent usually occurr unless you TAKE OFF  with them disconnected
 (which I have done !!!). There have been no reports I am aware of that have
 ever described this happening in flight (ie: disconnection). As has been
 stated in the report even if they had been disconnected this would not have
 made the aircraft uncontrollable.
 Perhaps you could rephrase your concerns/ issues without reference to the
 accident/ report as in your own words this has no bearing on the subject.
 (ie: What specifically are the "remaining unanswered questions")
 Carl Pattinson
 G-LABS
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| josok-e(at)ukolo.fi Guest
				|  Posted: Sat May 10, 2008 6:13 am    Post subject: Europa safety and the LAA |   |
				| [quote:64771ad5e2="carl at flyers.freeser..."]
This comment verges on slander - sorry but I cant put it any other way. I am sure you didn't intend it but that's how it comes across. My initial reaction is where is your evidence of a culture of cover ups. Most PFA inspectors take their roles very seriously and there is no reason whatsoever to suggest that the annual inspection was in any way sub standard (this seems to be what your comment implies).
 [/quote:64771ad5e2]
 It's not the first time that i have to apologize for speaking the language, but not being able to pack the words to a sociable acceptable level. I should also have explained here that i like to simplify things to the black box theory. What's going in and what's coming out. In the inspection box goes an excellent airplane, well maintained, well flown. Out comes a plane that disintegrates in mid-air. That justifies the conclusion that the inspection box, is not working as it should. Please, bear with me, this is not an attempt to blame one inspection or one inspector. The real question is what can we do to improve the standard of the inspection during the build, after the build, and during the lifetime of the airframe.
 As i said before, in the little exposure i have had to PFA builds, i have been pointed by re-builders to inspected and signed of parts and planes that should have been rejected. Some people who know me will nod their head now, in silence. That as an explanation for  my wondering about the keeping silent about clear mistakes.
 [quote:64771ad5e2]
 describe as keeping problems under the table. As regards the Europa fleet the PFA has a list of potential problems/ issues which inspectors should pay particular attention to whan carrying out inspections.
 [/quote:64771ad5e2]
 I cannot believe that that list of potential problems/issues that the inspectors have is not publicly available. Or did i miss it? This could be the kind of information that could save lives in other countries, where the safety of the aircraft is primarily in the hand of the owners. Are the results of build- and yearly inspections (de-personalized) in any form available? Again, this would be a very useful tool to have.
 [quote:64771ad5e2]
 (which I have done !!!). There have been no reports I am aware of that have ever described this happening in flight (ie: disconnection). As has been stated in the report even if they had been disconnected this would not have made the aircraft uncontrollable.
 [/quote:64771ad5e2]
 Thanks for this knowledge. So far i had assumed that without the control tabs connected the plane would not be flyable, hence not be able to land. Little additions to the knowledge base like this make the trouble of reading and writing here worth while. Now back to the unanswered questions: If a trim tab pin would have rested on the T bar, and would during the flight drop past it, inducing a Pilot Induced Oscillation,  be able to start the disaster?
 Jos Okhuijsen
 Visit -  www.EuropaOwners.org
		| Back to top |  |
		| p-a.austin(at)xnet.co.nz Guest
				|  Posted: Mon May 12, 2008 1:16 am    Post subject: Europa Safety and the LAA |   |
				| Carl Pattinson wrote:-
  	  | Quote: |  	  | >>>As regards the Europa fleet the PFA has a list of potential problems/ issues which inspectors should pay
 particular attention to when carrying out inspections.<<<<<
 Carl is there any chance this PFA list can be made public or placed on the
 Europa List as a further guide for those of us deemed by our relevant
 Aviation Authorities capable to perform maintenance on our "AND ONLY OUR,
 OWN" aircraft.
 Peter
 #198
		| Back to top |  |
		| Trevpond(at)aol.com Guest
				|  Posted: Mon May 12, 2008 2:09 am    Post subject: Europa Safety and the LAA |   |
				| Hi Peter,
 Have a word with Neville - he will let you know.
 regards
 Trev Pond
 G-LINN
		| Back to top |  |
				|  Posted: Mon May 12, 2008 3:04 am    Post subject: Europa safety and the LAA |   |
				| Thanks Peter,
 The inspection list and statistical results of inspections are both of extreme importance for continued safety of our aircraft. Even more there where we do not have the benefit of a inspectors with thorough knowledge of the type.
 What is the right word to classify withholding safety critical information?
 Jos Okhuijsen
		| Back to top |  |
		| Carl Pattinson
				|  Posted: Mon May 12, 2008 6:52 am    Post subject: Re: Europa safety and the LAA |   |
				| Hi Jos and others who asked about the "inspectors" list.
 I may have given the impression that this is some sort of secret list but that isnt the case. It is simply a collection of notes relating to Europa issues which the PFA have sent out to owners from time to time since the Europa became a PFA aircraft. If you are a PFA (now LAA) member you would have recieved these. They are issued in a fairly random manner and I dont recall having seen any new ones for quite a while.
 Past bulletins include notes on wear in the outrigger bearings and play in the tailplane assembly.
 Not sure if they are available directly from the PFA though I understood they had been sent to the appropriate inspectors. Maybe someone in the know could confirm this.
 As suggested previously, Neville may be able to help you if you want to get hold of them. Most have since been replaced by official Europa mods.
 I will have a look in my builders file and see if I can locate any of my own copies.
 Carl Pattinson
 G-LABS
		| Back to top |  |
		| rampil
				|  Posted: Mon May 12, 2008 7:48 am    Post subject: Re: Europa safety and the LAA |   |
				| Jos:
 I am afraid you make assumptions where evidence is lacking. Suffice
 to say that there are many areas of any europa, once completed that are
 beyond any conventional inspection or testing.
 Carl:
 You confirm that these are "secret" safety lists (is that an oxymoron!)
 only available to LAA members. Someone seems to forget that half the
 fleet is outside the dominion of the LAA. Safety information should know
 no proprietary bounds.  FAA Advisory Circulars are freely available to all.
 Ira N224XS
		| Back to top |  |
		| rparigor(at)suffolk.lib.n Guest
				|  Posted: Mon May 12, 2008 8:26 am    Post subject: Europa safety and the LAA |   |
				| ">  You confirm that these are "secret" safety lists (is that an
oxymoron!)
  	  | Quote: |  	  | only available to LAA members. Someone seems to forget that half the fleet is outside the dominion of the LAA. Safety information should know
 no proprietary bounds.  FAA Advisory Circulars are freely available to all."
 When I was reading on Safety Bulletin for Tailplanes, I remember reading
 about the "secret" safety lists. Not easy to track down, but someone was
 kind enough to send me scanned copies. I have 3 files. Unfortunate any one
 of those files is too large for Matronics to handle.
 I would be pleased to share files, what is easiest way? Some good
 information contained I have not seen or heard discussed anywhere else.
 Ron Parigoris
		| Back to top |  |
				| Hi Ira,
 Sorry, no assumption. Somebody said that quality of inspection was guaranteed because it was done according to a list of known problem areas. On the question were that list and it's (statistical) results is available no real answer pops up, and in other postings that check list is played down to some known, factory followed up, items.
 Conventional? Is that non-destructive? testing can be very effective if you know where to look, eventually with the aid of a bore-scope or ultra sound Simple tapping also reveals a lot. But it all boils down to in depth knowledge of what you are looking for.
 In this stage i tend to give up. Everything is just fine. There are no problems because planes are inspected perfectly according to a non-existing list. Whatever happens thereafter has nothing to do with the perfect system. End of thread for me.
 Jos Okhuijsen
		| Back to top |  |
				|  Posted: Mon May 12, 2008 8:44 am    Post subject: Europa safety and the LAA |   |
				| Europaowners forum, Europa files, document storage, limit on size is larger then you would like to upload.
 Jos Okhuijsen
		| Back to top |  |
		| rlborger(at)mac.com Guest
				|  Posted: Mon May 12, 2008 8:45 am    Post subject: Europa safety and the LAA |   |
				| Ron,
 Post it on the Europa Owners site.  There's a place for documents.
 On Monday, May 12, 2008, at 11:39AM, <rparigor(at)suffolk.lib.ny.us> wrote:
  	  | Quote: |  	  |
 oxymoron!)
 Ron Parigoris
		| Back to top |  |
		| rampil
				|  Posted: Mon May 12, 2008 10:29 am    Post subject: Re: Europa safety and the LAA |   |
				| Jos:
 Through my friendship with various builder assistance people,
 I have heard many tales of builders going wrong, in many
 imaginative ways.  How about 5 min epoxy instead of redux for
 some structural joints, how about bid instead of uni and vice versus.
 As I said, there are many places including inside layups, even for
 drag pin sockets that are not inspectable by routine methods.
 At my home base there is a gent who built a beautiful copy of an
 ME109.  He expected it would be airworthy.  He built it with Home-Depot
 bolts and Douglas Fir wood. On taxi, it crushed the landing gear. OK, the
 PFA might have caught that one during build.
 There are builders who will confound any conscientious inspector at a
 years on condition inspection especially if they do not scrap off the filler
 and paint.
 Ira N224XS
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
