		Ianrat
  Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
				 Posted: Mon May 12, 2008 5:33 am    Post subject: Engine mount bolts |
				Just about to fit the engine mount to the fire wall. What type of bolts are being used (AN or Grade 8 ).
 And are they using Castle nuts or Nylon lock nuts.
 Thank you.
 Ianrat
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jaybannist(at)cs.com Guest
				 Posted: Mon May 12, 2008 6:32 am    Post subject: Engine mount bolts |
				Ianrat,
 I used AN6 bolts with MS21045-6 (AN363-6) nuts.  Those nuts are medium heat self-locking.
 Jay in Dallas
				 Posted: Mon May 12, 2008 7:46 am    Post subject: Engine mount bolts |
				Ianrat,
 AN bolts should always be used and not Grade 8.  Castle nuts AN310 or
 Nyloc nuts depend on whether engine
 heat is going to be a factor.  Nylocs are only good to 250-degrees F.
 If its an air cooled engine the engine castle nut is recommended.
 Ianrat wrote:
  Thank you.
  Ianrat
		tonyplane(at)bellsouth.ne Guest
				 Posted: Mon May 12, 2008 10:46 am    Post subject: Engine mount bolts |
				Just my $ .02
 My Jab FWF came with cad plated steel self-locking  AN ???(not Nylock) type
 nuts. I used these nuts vice the "nylock type" ones supplied by Zenith.  I
 don't have the number in front of me, but you can probably get it from the
 Jab USA website for the Zodiac FWF kit.  In my opinion, I would not
 recommend castle nuts with cotter keys to lock these nuts as  I believe you
 should keep them torqued or risk fatigue/fretting, leading to possible bolt
 failure.. Part of my annual Inspection, and every time my fwd skin is
 removed, is to check the torque.  I use 300 in-lbs.
 Tony Graziano
 601/Jab3300; 374 hrs; N493TG
		n556p(at)yahoo.com Guest
				 Posted: Tue May 13, 2008 4:21 am    Post subject: Engine mount bolts |
 Hello, Ianrat, and other listers,
      I must agree in part with what Mac already wrote you.  Use the AN
 bolts.  Grade 8 are slightly stronger/harder, but are also a bit more
 brittle.  You don't want brittle on something that's potentially so
 safety critical as engine mounts.
      I must disagree with something else Mac wrote.  Castle nuts are
 good.  Self locking nuts are not necessarily bad.  Nylock type nuts
 SHOULD NOT BE USED on an engine mount.  Here's the reasoning:  Under
 normal operating conditions, some engines don't produce sufficient heat
 to present a problem.  However, forward of the firewall is the most
 likely place on an aircraft to have a fire.  If you ever have an
 in-flight fire (God forbid), you don't want your engine to fall off the
 plane because you used Nylock nuts on the mounts and the nylon melted.
 If you choose to use self-locking nuts on your engine mounts, please
 USE ALL-METAL ones.
      Assuming that heat isn't an issue under normal operating
 conditions, Nylock nuts are great in almost all other applications.
 Phil Raker     N556P     HDS/Stratus     ~85% completed
      (using all-metal self-locking nuts on my engine mounts)
