Bldgrv10450(at)comcast.ne Guest
Posted: Wed May 14, 2008 6:21 am Post subject: Rudder Trim Question |
My friend John Hilger in Bend Or. sent an email suggesting that we should come up with an addition to the rudder pedal system we have designed. Thanks to John we are now considering two optional features. First, a gust lock that will work for the pedals and stick, and the second an effective servo adjustable rudder trim. We have two concepts under consideration, however we need some help from flying RV10's.
We need to determine the amount of pedal pressure required by a clean rudder without trim tab in level flight. We are assuming 3 to 5 lbs. How can this be measured?
Thanks in advance for your help.
Paul Grimstad
RV10 40450
Portland, Or.
planesmith(at)hotmail.com Guest
Posted: Wed May 14, 2008 7:04 am Post subject: Rudder Trim Question |
Hi Paul,
It was great meeting you last Saturday. While not yet flying the following email excerpt may help.
Vern Smith (#324 finishing)
What trim force do you think you are getting? I had sent an e-mail to Vans asking what input they thought would be required. They told me that a 5 to 10 pound force as measured at the bottom of the rudder pedal should take care of any 'normal' trim, 25 pounds could be required to compensate for takeoff forces.
I have been crunching numbers on the torsion spring bias system that I had designed. I am having difficulty getting the required trim force without overloading the trim servo motor, or limiting the travel too much. A combination of the two systems may be just the ticket to realize the benefits of both.
Again I really like the different approach, thanks for sharing.
Jason Kreidler - #40617
4 Partner Build - Finishing
[quote] From: Bldgrv10450(at)comcast.net
Subject: RV10-List: Rudder Trim Question
Date: Wed, 14 May 2008 07:16:27 -0700
Paul Grimstad
RV10 40450
Portland, Or.
ricksked(at)embarqmail.co Guest
billderou(at)yahoo.com Guest
Posted: Wed May 14, 2008 8:16 am Post subject: Rudder Trim Question |
Paul-
I would suggest that you keep the clamping rudder trim concept on the table and compare it with a servo setup. It works very well and you can easily design it with a breakaway force allowing override from the pedals. I can get away with a "personal" big screw setup that has an "iffy" override but to be offered to the general public it must have the override feature.
The obvious advantage is the clamping approach is simplier with less expensive manufacturers cost. The not so apparent advantage is it fuctions with much less force.
A servo implementation needs force to move the rudder and overcome friction in the cable system. The clamping design uses the friction to help hold the rudder. Difference in forces required is two times the friction.
I can see where the gust lock fits well with the pedals but its a little harder to visualize the rudder trim. If you want to spin the rudder trim off as a seperate product take a look at the work I have accomplished. It needs a few more parts to add a breakaway feature and I think a builder would rather buy than build.
Good Luck,
Bill DeRouchey
N939SB, flying
Paul Grimstad <Bldgrv10450(at)comcast.net> wrote:[quote]NW Builder Dinner My friend John Hilger in Bend Or. sent an email suggesting that we should come up with an addition to the rudder pedal system we have designed. Thanks to John we are now considering two optional features. First, a gust lock that will work for the pedals and stick, and the second an effective servo adjustable rudder trim. We have two concepts under consideration, however we need some help from flying RV10's.
Paul Grimstad
RV10 40450
Portland, Or.
Fixitauto(at)aol.com Guest
Posted: Wed May 14, 2008 7:27 pm Post subject: Rudder Trim Question |
Hey, if you know James, then you been hiding out awhile!!! Had Lasik on my eyes last week, see great, all but my monitor and those stinkin little letters
Rick Sked
40185
