Posted: Wed May 14, 2008 9:21 am Post subject: linear actuator for rudder trim |
Well, as promised ..... between forest fires .... I googled for
jackscrews. I started with '12 V jackscrew' and got all kinds of weird
stuff .... so went to '12V linear' and hit paydirt. There are a lot of
sources out there. The price isn't bad if you consider a Ray Allen trim
servo is $145!!!!
http://www.route66supply.com/store/page26.html in the $120+ range
http://productsearch.machinedesign.com/mdproducts/12v_linear_actuator
has listings for 515 companies, and no, I didn't check them out.
http://www.servocity.com/html/12v_linear_actuators.html has them for
$100 .... max speed .5"/sec.
or look here:
http://www.dcactuators.com/
I think that with the linear actuator and the torsion spring concept
.... there's a very good solution to the rudder trim scenario.
Linn
