naumuk(at)alltel.net Guest
Posted: Sat May 17, 2008 12:04 pm Post subject: General shop-type question |
All-
Bought a polishing wheel and want to clean the light rust off of something. Do I wire-wheel the piece first, or does that make it harder later on?
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
Thruster87
Posted: Sat May 17, 2008 1:38 pm Post subject: Re: General shop-type question |
Howdy, If the item you wish to remove corrosion from is Aluminum don't use a wire wheel as it can leave small pieces of iron impregnated in the job and it can also cover and hide existing corrosion.Emery mops ,grit blasting and scraping are the mainstay for surface corrosion.Rust is another matter as it's steel based.Cheers
Ron Lendon
Posted: Sat May 17, 2008 2:10 pm Post subject: Re: General shop-type question |
Bill,
Polishing requires much surface preparation matters not whether aluminum or steel. Your mention of rust makes me think you are talking about steel. If you really want to polish you will sand, wet or otherwise, from 600 grit to about 1500 grit before polishing.
Of course if your part is rougher that 600 grit to begin with, a coarser grit will be appropriate to get it smooth before you begin the polishing process.
Hope that gives you some help.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
georgerace
Posted: Sat May 17, 2008 2:48 pm Post subject: General shop-type question |
Hi Bill:
I think you will find you get better results by using a "Green Scotch Pad" instead of a wire wheel. The wire wheel will leave scratches and groves that will be more difficult to polish out.
George - 701 - N73EX
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Saturday, May 17, 2008 3:59 PM
To: zenith list
Subject: General shop-type question
All-
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
Aerolitellc(at)aol.com Guest
