Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
steveadams
Posted: Mon Feb 27, 2006 8:10 am Post subject: Static Dischargers |
Hopefully some of you can help me out. Last week I finally got to fly in some actual IMC in my plane (total of 4 hours actual). After about 15 minutes in the clouds, my radio transmissions became more and more filled with static. Still understandable, but not very clear. No static when just listenning to controllers or talking without transmitting. Slowly cleared up after exiting clouds. I think this is a static build up problem and wondered what others thought. My airplane is an CH640 and I have braided grounding straps across rudder and horizontal tail hinges. They didn't specify static wicks in the design. I know that static dischargers should be out and back as far as possible, but otherwise am not sure about placement and how many I may need. Is there any general advise concerning placement and number, or is it basically a trial and error process to see what works?
nuckollsr(at)cox.net Guest
Posted: Mon Feb 27, 2006 2:48 pm Post subject: Static Dischargers |
At 08:10 AM 2/27/2006 -0800, you wrote:
<dr_steve_adams(at)yahoo.com>
what works?
Pretty much. P-static mitigation is a combination of science and
art . . . but without the 200Kv hot spot chaser wand we use at
RAC, a bit of luck doesn't hurt.
Fortunately your airplane is slow and your time in the clouds
probably limited. If you query the usual suspects for aircraft
quality static wicks, you'll find listing like:
http://www.aircraftspruce.com/catalog/elpages/staticwick.php
http://www.texair.com/aircraftparts/Dayton-Granger.asp
. . . and occasionally you might even find them on Ebay. See
item 4612427645
You can try three minimum. One on trailing edge of each
aileron and one on the rudder. It's a cut-n-try sort of
thing without a purposeful testing facility but you
have nothing to loose and an experimental airplane to
try things on.
Here's an article that speaks to the science of crafting
and installing static wicks for terrestrial applications:
http://www.repeater-builder.com/pdf/staticbusterarticlecomplete.pdf
In a Google search I ran across this note. I was 3/4th through
the thing before I realized it was one I wrote some years ago:
Stat Wicks
Static wicks have nothing to do with radio quality or
reliability. EVERY time dissimilar materials slide across each
other, there is a tendency for one material with a stronger affinity
for electrons than the other to acquire a negative charge.
Common manifestations include sparks that jump between
fingertip and doorknob after walking across carpet. In the winter
especially, I have to remind myself to keep part of my body
touching the frame of my 1" vertical belt sander while sculpting a
piece of metal . . . the Van DeGraff like nature of the belt sander
will charge the ol' bod with a significant kick if I don't bleed it off
during the sanding operations.
Precipitation static is unique to airborne particles sliding
past any conductor. Radio receivers can be severely affected by
dust storms usually associated with high winds. I used to work
with an amateur radio repeater installation 1200 feet up on
KTVH-TV in Hutchinson, KS. A blowing snowstorm would
severely de-sense our receivers.
Airplanes have unique problems in that they generate their
own wind. Airplanes flying through dust, rain or snow can pick
up significant charges. When the charge reaches sufficient
magnitude, it begins to form coronas at the sharp (usually trailing
edges) of wings and flight control surfaces.
The static wick is a sharp-ended conductor (enhances
tendency for charge to concentrate and form corona) connected to
the airframe through some nominal but rather high resistance.
The idea is to put sufficient static wicks in the right places so that
they force lots of small, low current discharges to form and
dissipate the energy at much lower (read less noisy) levels than if
the wicks were not present.
The faster the airplane flies, the more likely it is to
experience the effects of p-static. Further, the finish and skin
materials have an influence on tendency to build and concentrate
static charges. These effects are present and potentially
troublesome irrespective of the vintage of radios carried aboard
the airplane.
VHF radios are less susceptible than HF or ADF receivers.
Grounded antennas are quieter than isolated antennas. There are
some modern digital signal processing techniques that can reduce
the audible effects of p-static but ultimately, locally generated
static noises will overwhelm a receiver looking for weaker
signals.
The number, style and placement of static wicks on our
bizjets is as much an art as a science. We spent a great deal of
$time$ selecting the right products and installations. Further,
there's a comprehensive incoming inspection of static wicks . . .
seems that a performance of a static wick is very sensitive to
production variability.
If your airplane suffers from the effects of p-static, it may
take a lot of effort over a long period of time to deduce the
optimum solution
I might add to this that a static wick is not
a simple sharp-tipped conductor tacked to the trailing
edge of a wing. It has a high resistance . . on the
order of tens of megohms. Not easy to build. This
long, linear resistance element is necessary to keep
the wick from becoming an efficient concentrator
and radiator of noise at it's 1/4 wave resonance
frequency. It's also necessary to mitigate the
ability of the discharge at the tip to generate
noise.
Your best source for "real" wicks is probably Ebay.
They'll come already built . . . but with no guarantees.
rshannon(at)cruzcom.com Guest
Posted: Mon Feb 27, 2006 4:32 pm Post subject: Static Dischargers |
Slightly tangential, but....
Early research on P-static and how to deal with it was carried out
during WWII by a team led by Bob Buck. In a B-17, they intentionally
sought and charged (sorry about that one) into major storm clouds all
over the world -- for the benefit of science. He writes about it in
fascinating detail in "North Star Over My Shoulder", a memoir of his
extraordinary life in aviation (early biplanes to Chief Pilot for TWA
driving 747's, etc.) and a good read all around.
Ron
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Feb 27, 2006 5:27 pm Post subject: Static Dischargers |
steveadams wrote:
| Quote: | ...After about 15 minutes in the clouds, my radio transmissions became more and more filled with static. Still understandable, but not very clear. No static when just listenning to controllers or talking without transmitting.
While the fact that it happens in the cloud and clears up when you leave
the cloud certainly implies p-static, I have *never* heard of p-static
having an effect on transmission. I have been in p-static so bad (dry
snow) that not a single receiver in the aircraft worked (well, they
worked but the noise was greater than any signal). Through that my
transmissions were clear to receivers.
Is there anything else you turned on while in the clag? Pitot heat?
Another (remote) possibility is that the base of your antenna is not
bonded well and the water changed the characteristic of your ground
plane connection.
And of course it could be just a bad lobe on your antenna radiation
pattern. Did you make any turns or were you motoring straight and level?
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
dcarter11(at)sbcglobal.ne Guest
Posted: Mon Feb 27, 2006 8:12 pm Post subject: Static Dischargers |
I believe p-static is principally the noise created by static electricity
jumping from skin panel to skin panel on the way aft and finally off of the
plane in elevator and rudders. I think fiberglass stuff up front is a big
source of buildup. You could try running a wire from nose to tail, with good
electrical connection at each end - this might let the static build up on
fiberglass cowl (I'm thinking RV series aircraft) bleed off by going from
front to back without jumping a lot of little skin gaps along the way (don't
ask me why the fore-aft longerons wouldn't do the same).
David
Bruce(at)glasair.org Guest
Posted: Mon Feb 27, 2006 8:27 pm Post subject: Static Dischargers |
Yes, we know of p-static. It's a real problem in our fast plastic airplanes.
The only solution the factory ever came up with was a copper mesh imbedded
in the glass close to the surface, this was also their solution to lightning
protection. I believe the same solution was used on the SR-20/22. Others
(builders) have had some success with conductive primer. Static wicks won't
work on our airplanes.
Bruce
www.glasair.org
steveadams
Posted: Tue Feb 28, 2006 4:22 am Post subject: Re: Static Dischargers |
Thanks for all the suggestions. I have over 150 hours flying, and this never happened before. I was flying down to Florida, straight and level when it first happened. As I said, it cleared slowly after leaving the clouds. I then took a few flights VFR and everything was fine. Then again coming home I was in the clouds and it happened again, but not as bad. On my plane the cowl is fiberglass, but the cabin is carbon fiber and the rest of the plane is metal. Com 1 antenna is on top, and com 2 is on the bottom. Static was worse on #1, but also present on com 2, again, only with transmission. Maybe it is something other than p-static. The CH640 airframe is the same as the Alarus, which does not have static wicks, and from people I have talked to it has no p-static problems. The 640 is about 30 KTS faster though, which could make a difference. I guess it is worth finding a few static wicks and seeing if it makes a difference.
Posted: Tue Feb 28, 2006 5:11 am Post subject: Static Dischargers |
At 04:22 AM 2/28/2006 -0800, you wrote:
You bring up an interesting point. Not every owner
of a particular airplane has p-static problems to
report . . .
It's a HIGHLY variable phenomenon. EVERY airplane has
a p-static charge on it to some degree or another, it's
only in the right combination of variables that noise
levels rise sufficiently to be heard on radios. In severe
cases, we've had p-static eat away at structural parts of
the airplane . . . e.g. window glazing. The results
of your experimenting may not be known until you seem
to have slain the dragon by not having problems over a
series of similar conditions . . . which could take years.
It's quite disappointing than to have a solution
in place for a couple of years and encounter conditions
further out on the bell-curve and find that you're only
partially successful.
What you're experiencing is not new/startling. In fact,
it's so commonplace and has such a problematic history
of solutions that first response from those who have
wrestled with it is sympathy and best wishes for a lucky
break. Folks who do this professionally have access to
expensive test and development tools and techniques
that are not going to be available to the OBAM aircraft
community. So, please do experiment and let us know of
your findings. But I would also caution that what works
for you may only be a starting point for determining
what mitigates someone else's problems at a later date.
Good luck!
