countzero
Posted: Sat May 17, 2008 1:50 pm Post subject: Full Length Wingtips |
See attached photo
Rob
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Description: |
Filesize: |
223.31 KB |
Viewed: |
1081 Time(s) |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Afterfxllc(at)aol.com Guest
Posted: Sat May 17, 2008 4:23 pm Post subject: Full Length Wingtips |
They come with the new kits... I got mine 3 weeks ago I thought everyone knew.
Jeff
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
Ron Lendon
Posted: Sat May 17, 2008 5:00 pm Post subject: Re: Full Length Wingtips |
Made mine out of metal. It's supposed to be a metal airplane not plastic
Description: |
Filesize: |
159.24 KB |
Viewed: |
1007 Time(s) |
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
bryanmmartin
Posted: Sat May 17, 2008 5:09 pm Post subject: Full Length Wingtips |
I'd sure like to find some of that transparent aluminum.
On May 17, 2008, at 9:05 PM, Craig Payne wrote:
> plastic
Canopy bubble too?
-- Craig
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Ron Lendon
countzero
Posted: Sun May 18, 2008 5:43 am Post subject: Re: Full Length Wingtips |
Did you get drawing or manual updates Jeff? mine show the shorter ones and I thought I had the latest revision.
Rob
cndmovn(at)gmail.com Guest
Posted: Sun May 18, 2008 6:34 am Post subject: Full Length Wingtips |
I saw them up at Zenair on Friday. I think they are easier to install, but look just the same as the old two piece version. I like the two piece version since you can get access to the wing tip light easier if you need to.
In talking with they guys up at Zenair, they are making changes as they go from things they learn while building the LSA's for the US and European market. I believe the wingtips were done to allow for quicker installation....kind of like the new canopy they showed me.......much easier to install....
On Sat, May 17, 2008 at 8:22 PM, <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:
[quote] They come with the new kits... I got mine 3 weeks ago I thought everyone knew.
Jeff
Posted: Sun May 18, 2008 1:41 pm Post subject: Full Length Wingtips |
I'm not sure I will look when I go to the shop tonight and let you know. >From my experience with Zenith the plans don't change for awhile after a change because they have to wait until they send out all the ones they have printed but I will check.
Rob
Posted: Sun May 18, 2008 1:46 pm Post subject: Full Length Wingtips |
I always install my wing tip with plate nuts so it can be removed so now it will require a lot more and I would also install the power unit for the strobs on the forward side of the spar and the wing tip was the access but now I'm thinking of an access hole and rivet the tip on. Decisions decisions.......
Quote: | I saw them up at Zenair on Friday. I think they are easier to install, but look just the same as the old two piece version. I like the two piece version since you can get access to the wing tip light easier if you need to.
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Mon May 19, 2008 9:57 am Post subject: New XL Canopy? |
cndmovn(at)gmail.com wrote: | ....kind of like the new canopy they showed me.......much easier to install.... |
Could you elaborate on the new canopy...? Any pictures?
I heard that Zenith now sells Todd's Canopies, and I heard rumors that there was something in the works regarding the canopy, but no details yet.
The canopy is the only airframe component I lack, and I'd sure like to hold off buying it if something new is in the works....
- Pat
Gig Giacona
Posted: Mon May 19, 2008 10:09 am Post subject: Re: New XL Canopy? |
Patrick, If there is even a chance that there is going to be an easier to install canopy kit I would highly recommend that you and anyone else wait for it until the very last minute. Installing the canopy SUCKS!!!
PatrickW wrote: | cndmovn(at)gmail.com wrote: | ....kind of like the new canopy they showed me.......much easier to install.... |
- Pat |
601XL Under Construction
Posted: Mon May 19, 2008 11:48 am Post subject: Full Length Wingtips |
I think the difficulty of installing the canopy is what caused the change. The factory in Canada, that builds the LSA for the US market (they get finished in the US) and Europe hated how hard it was to install the canopy so they are making a rolling change (along with some other things you will likely see at OSH) on the canopy. My understanding is that the new canopy will show up on the LSA first and slowly make it into the kit. In talking with the guys at the factory, I was told the canopy is not retrofitable. Basically the canopy has a fixed front part that does not move off the fuselage and a swinging part just aft of the instrument panel (kind of like a sliding RV canopy but with the rear section swinging up rather than sliding back). There is a roll hoop built into the rear edge of the fixed part. The rear section swings like the original. It was in pieces when I saw it since it was prototype #1. What is really nice is the latching system that has a hooks coming up by the upper longerons that are joined via a control arm and are operated by a single handle between the seats by the arm rest.
I have no pictures and all of this was from memory but it looked really nice. They showed it to me without me asking and didnt tell me I could not say anything about the mods. However, remember that it was a prototype and still a work in process. I talked with a group of guys who went up this past friday and they saw the completed canopy on a plane and said it looked REALLY nice.
Hope that helps
Paul
On Mon, May 19, 2008 at 2:09 PM, Gig Giacona <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)> wrote:
[quote] --> Zenith601-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)>
> Thanks,
> - Pat
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=183857#183857
br> -List" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
MS -
e -
-Matt Dralle, List Admin.
Gig Giacona
Posted: Mon May 19, 2008 1:17 pm Post subject: Re: Full Length Wingtips |
If Paul's info is even close to right I strongly suggest to everyone wait for it if you can. If I was at that point in the process I'd be calling Zenith and asking them for any info I could get on the new canopy.
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Mon May 19, 2008 1:47 pm Post subject: Full Length Wingtips |
On Mon, May 19, 2008 at 03:48:24PM -0400, Cndmovn wrote:
Quote: | What is really nice is the latching system that has a hooks coming up by
My Zodiac won't have the new canopy, but it will have this latch. I've seen
it, and it looks like it'll be a lot better.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
