klaus(at)utdallas.edu Guest
Posted: Wed May 21, 2008 10:48 am Post subject: Rotax 912 fuel pump |
Hi,
We just learned the hard way that a fuel filter immediately ahead of the
Rotax mechanical
fuel pump is very important. When we first installed the engine, we did
have such a filter
to catch initial debris possibly coming from the center tank. That tank
receives all fuel
from the two wing tanks, which have filters ahead of the electric
transfer pumps.
After 100 hrs of flying, we thought that the filter ahead of the Rotax
pump could be
removed, since all fuel comes from the wing tanks and thus is filtered.
WRONG!
The Rotax pump failed after 400 hrs, gradually losing pressure. The
second Rotax pump
failed recently, gradually losing pressure after 700 hrs of service. In
both cases
the electric boost pump saved the day. On the other hand, the three
facet pumps
used in the system have never failed.
In the repair manual, Rotax warns that the mechanical pump can fail due
to contamination.
Apparently this can happen even if the fuel sampled from the gascolator
shows
no contamination, which has been the case for years. We can only conjecture
that the Rotax pump can be disabled by very small debris. The lesson is:
There must always be a filter just ahead of the mechanical pump. Since
this is in the
engine compartment, the filter must be have a metal housing.
Maybe this will help somebody else avoid the problems and expense we have
had with the Rotax pump.
Happy flying,
Klaus
www.utdallas.edu/~klaus
haven
Joined: 11 Apr 2007 Posts: 19 Location: Kansas City MO
Posted: Wed May 21, 2008 1:00 pm Post subject: Re: Rotax 912 fuel pump |
Is the Rotax pump very costly?
Posted: Wed May 21, 2008 2:08 pm Post subject: Rotax 912 fuel pump |
The most recent cost of the Rotax fuel pump was around $170.
Klaus
billmileski
Posted: Wed May 21, 2008 7:58 pm Post subject: Re: Rotax 912 fuel pump |
Klaus,
Would you happen to know if, when failed, the pump is blocked, or freely allows fuel to still flow through?
Best,
Bill Mileski
701 912S 125hrs
Posted: Thu May 22, 2008 2:32 pm Post subject: Rotax 912 fuel pump |
Hi Bill,
You ask "Would you happen to know if, when failed, the pump is blocked,
or freely allows* *fuel to still flow through?"
The is a short and a long answer. The short answer is that, in the two
cases
of Rotax pump failure in my plane, the electric boost pump, which is in
series
and precedes the Rotax pump, managed to pump through the failing
Rotax pump. In both cases, there was a failure of the check valves and
not a diaphram failure, which is nasty indeed, but unlikely to happen
if one replaces the Rotax pump at TBO regardless of whether
one overhauls the engine at that time.
The long answer covers two choices, which are placing the electric boost
pump parallel or in series with the mechanical Rotax pump. Both arrangements
have pros and cons.
Parallel placement:
Either one uses one check valve in each parallel
branch immediately after the electric or mechanical pump. For that
choice, the specter of failing check valves looms.
Or one omits such check valves and trusts that the internal check
valve in the electrical pump holds while the
mechanical pump is working, and that the mechanical pump will
retain its internal check valve function even when it fails otherwise.
In my opinion, if I went for the parallel placement choice,
I would go with the choice of two check valves.
Series placement: One trusts that the electric valve will not somehow
become internally clogged and prevent the mechanical pump from
getting fuel, and one also trusts that in case of mechanical pump failure
the electric pump will still be able to pump through the mechanical
pump.
In our installation we opted for the series placement choice. It is
the simplest arrangement, and when one argues through the two possible
types of pump failures (diaphram failure versus check valve failure),
then it seemed to us that series arrangement is likely to save the day
in case
of pump failure. But this is a matter of opinion, and everybody must
make his/her own decision for this important choice.
Happy flying,
Klaus
professor71(at)HOTMAIL.CO Guest
Posted: Thu May 22, 2008 7:30 pm Post subject: Rotax 912 fuel pump |
Hi Klaus
What kind of fuel filter and how many psi pump do you use? Where, how did you mount your pump? Do you use the filter in conjunction with a gascolator? I have only been relying on the mechanical pump in my 601HD but would like to install a backup electric pump just for such situations as you encountered.
John
[quote] Date: Thu, 22 May 2008 17:28:16 -0500
To: Zenith-List(at)matronics.com
Subject: Re: Rotax 912 fuel pump
--> Zenith-List message posted by: Klaus Truemper <klaus(at)utdallas.edu>
Hi Bill,
cases
series
have pros and cons.
Parallel placement:
pump.
in case
Happy flying,
Klaus
www.utdalla========================Change the world with e=EML_WL_ChangeWorld' target='_new'>Join the i’m Initiative from Microsoft. [quote][b]
Posted: Fri May 23, 2008 10:44 am Post subject: Rotax 912 fuel pump |
Hi John,*
*1. Any decent metal automotive fuel filter will do.
2. According to the Rotax manual, max pressure of the
backup pump should not exceed 5.8 psi.
A good choice is the Facet pump #4015.
Aircraft Spruce offers this pump. There is also another
Facet pump that goes up to 6 psi. Do NOT install that pump
since it exceeds the Rotax psi limit.
3. We mounted the Facet pump on the firewall
downstream from and a bit higher than the gascolator.
4. Our gascolator is just an aluminum box with a quick drain.
It was part of the kit and does not have a screen.
5. Our arrangement is as follows:
gascolator -> filter -> Facet pump -> Rotax pump
There are other arrangements possible. Some aspects were
covered earlier (series versus parallel).
6. A backup pump can be a grief- or even life-saver.
Happy flying,
Klaus
Klaus Truemper
Professor Emeritus of Computer Science
University of Texas at Dallas
Erik Jonsson School of Engineering and
Computer Science EC31
P.O. Box 830688
Richardson, TX 75083-0688
(972) 883-2712
