AirMike
Posted: Tue May 20, 2008 9:53 pm Post subject: Fiberglass Wing Tip Installation - simple efficiency |
Reference to page 24-3 of the plans on the installation of the wing tips.
I have pre-fitted the tip using "step 1" and drilled/clecoed #40 the attach holes. It seems to line up pretty good. I do not understand why you want to remove the wing tip per "Step 2"
It would seem better to just finish drill #28 right thru the aluminum and the fiberglass to maintain alignment and keep the fiberglass from puckering. After drilling you can detach the tip and do the dimpling, deburring, countersinking and aligning the nut plates.
Is there something that I am missing here.
_________________ See you OSH '18
Q/B - sold. |
Mike Whisky
Posted: Tue May 20, 2008 11:47 pm Post subject: Re: Fiberglass Wing Tip Installation - simple efficiency |
I guess they want to be sure that no chips are caught between the fiberglass and the aluminum.
Michael
_________________ RV-10 builder (flying)
#511 |
roadmaps
Posted: Wed May 21, 2008 4:27 am Post subject: Fiberglass Wing Tip Installation - simple efficiency |
Mike,
I strongly encourage you to drill the wing tip attach with the wing on the
plane and all control surfaces in the neutral position. Clamp a long
straightedge to the wingtip, aileron and flap edges. Otherwise the wingtips
will not align with the aileron tips. I had to do major surgery with the
wingtips to fix this problem
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Painting and final assembly
ron.mcgann(at)baesystems. Guest
Posted: Wed May 21, 2008 2:28 pm Post subject: Fiberglass Wing Tip Installation - simple efficiency |
I endorse John's comments 100%. I followed the plans and had a right
wing tip 1/2" lower than the flaps/ailerons. The idea of a 'mini
aileron' on the right wing (causing a significantly 'heavy' left wing)
was not acceptable, so 12 build hours later and I am still reforming the
tip. Almost done, but attaching the tips without the flaps and ailerons
aligned is more a lottery than anything else.
Cheers
Ron
187 almost done.
AirMike
Posted: Wed May 21, 2008 8:36 pm Post subject: Fiberglass Wing Tip Installation - uh oh |
Very interesting and informative. It seems that the wing tips only affix to the aluminum part ONE WAY - tight. But the trailing 8-10" seems to be the area in question - is that correct ?
From what I can extrapolate is it ok to affix the forward part (in front of the aileron hinge) and then split the rear and install the reinforcing section after the ailerons are fitted and trimmed for flight ?? That way the trailing edge is perfectly trimmed with the aileron ???
Boy it is great having this resource !!!!! Kuddos to Matt.
Q/B - sold. |
Posted: Wed May 21, 2008 9:26 pm Post subject: Fiberglass Wing Tip Installation - simple efficiency |
I have no experience with splitting the trailing edge and attempting
re-alignemnt. I think I read that Tim O. tried this and had to abandon
a tip in favour of a new one, so I did not even try. I think I have
also seen a post (from Jesse) about forming ('twisting?' the nose of the
LE to raise/lower the aft edge. There is a bit in the archives on this.
I would suggest the following order:
1. make certain the flap and aileron are on the wing and in the
trail position (flap fully up)
2. align the trailing edge with aileron/flap (use tape to attach
the tip to the wing)
3. drill the tip to the fuse
4. attach the tip.
5. Check the length of the tip - if the tip is too long, remove it
and apply some epoxy to beef up the inside of the TE in case you need to
remove the epoxy at the the existing TE join. From what I can tell, you
really don't want to separate the trailing edge.
6. trim the tip and shape as required.
YMMV, but this is what I would do if I had to do it again.
Hope this helps
Ron
187
Posted: Thu May 22, 2008 4:26 am Post subject: Fiberglass Wing Tip Installation - simple efficiency |
I haven't been following this thread very closely, so I don't know
what all has been said so far, but you can twist the leading edge up
or down a little bit to raise or lower the trailing edge to line up
with the aileron. This, of course, has to be done before drilling all
of the holes. You can drill a couple to hold it in place with clecos
to see if it is right, then move it a little and drill others until it
is right, then you will need to reenforce the holes that were off
before finishing the wing. We now use the hinge method of
installation, which still uses the same technique for fitting it in
the first place. I very much prefer using the hinge because it not
only looks much better, IMHO, but it can make the tip much easier to
take off and put back on during an inspection. We still use a few
screws up in the front where a standard hinge can't handle the curve
very well.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
abandon
the
this.
4. attach the tip.
need to
you
Hope this helps
Ron
187
roadmaps
Posted: Thu May 22, 2008 4:31 am Post subject: Fiberglass Wing Tip Installation - simple efficiency |
When I attached my wingtip it had room to move inside the metal - kind of
rotates - and the trailing edge could be adjusted up or down. I clamped the
trailing edge to the aileron and then drilled the attach holes. All this was
after I did not do this the first time and had to cut open the trailing
edges, adjust and then re-glass them together. You should be able to avoid
doing this if you clamp things together before drilling.
I also had to cut about 1/2" off the trailing edges and also re-glass
them. The tips were a lot of work.
John Testement
40321
Richmond, VA
Posted: Thu May 22, 2008 4:51 am Post subject: Fiberglass Wing Tip Installation - simple efficiency |
You can also use some fiberglass resin with flox (mix very runny) and
fill up the trailing edge, which will allow you to sand down until
it's flush and then use cloth to reglass around the trailing edge.
This eliminates the need to split the trailing edge and then reglass
it from there.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
kind of
clamped the
this was
trailing
avoid
John Testement
40321
Richmond, VA
Tim Olson
Posted: Thu May 22, 2008 5:09 am Post subject: Fiberglass Wing Tip Installation - simple efficiency |
I agree fully with Ron. I would absolutely make sure the flaps
are mounted and all the way up, and that the ailerons are mounted
too. I don't believe it matters a bit if the wing is on the plane
though. Once the tip is in place, it can rotate around and cause
the trailing edge to take different positions...not much, mind you
but enough to make a difference. So what I did was to push the
tip in place and forward to expand the fiberglass out to meet
the metal everywhere, and had a helper drill and cleco. You want
that tip pushed in forward tight so the tip fills most of the gap
between the tip and skin......while maintaining the trailing
edges of everything all in alignment. What you then have is a
wingtip/aileron/flap combo that is all aligned in flight when
the flaps are at -3 degrees in the reflex position.
If the tips are too long, and I was doing it all over again, I'd
probably get it all drilled and fit in place and then trim the
tip back to the length I needed...but if it was going to trim
enough to split the upper and lower tip halves, I'd glass inside
the tip further before I started...just to maintain the same
relative positions. Of course, you'd still have to make the
upper and lower skins meet at a taper, so you couldn't let the
tip get too thick at the trailing edge. You could also
match them up and drill and bold thru the trailing edges to maintain
alignment. If they're over 3/4" too long though, it could get
painful.
McGANN, Ron wrote:
4. attach the tip.
Hope this helps
Ron
187
