200hp ea81 in the builders gallery
craigb(at)onthenet.com.au
PostPosted: Fri May 23, 2008 3:52 am    Post subject: 200hp ea81 in the builders gallery Reply with quote
Can anyone tell me about the 200hp supercharged ea81 in the builders
gallery. I am just curious
if someone has this in a europa.
craig
Checked by AVG.
4:44 PM
fklein(at)orcasonline.com
PostPosted: Fri May 23, 2008 6:18 am    Post subject: 200hp ea81 in the builders gallery Reply with quote
gallery. I am just curious if someone has this in a europa.
Craig....send an email to: GLENN CROWDER <gcrowder2(at)hotmail.com>...he
be the USA Guru on EuropaSoobs...Fred
believed to be clean.
gcrowder2
PostPosted: Fri May 23, 2008 9:31 am    Post subject: 200hp ea81 in the builders gallery Reply with quote
Wayne Oehler from San Diego is just about done with his the last time I heard from him.
I can send you his email address if you would like. I use the 125 hp NA version in my mono
and it works fantastic. You get a bit more power with a bit more weight. All up wt on mine
RTF no fuel is 930 lbs. WOT 175 mph at 7500 ft.
    Glenn
Subject: 200hp ea81 in the builders gallery
Date: Fri, 23 May 2008 21:51:47 +1000
--> Europa-List message posted by: "craig bastin" <craigb(at)onthenet.com.au>
craig
Checked by AVG.
4======================
Give to a good caust.aspx?souce=EML_WL_ GoodCause' target='_new'>Join the i’m Initiative from Microsoft. [quote][b]
