Posted: Wed May 21, 2008 1:42 pm Post subject: Tansfer pump Ideas? |
Re: powering a fuel pump.These things don't draw a lot of power and I like to keep things simple, BUT....
That is the one item that I installed with a relay. OK, I know that when the pump
coil fries that my engine will quit anyway but it makes me feel better knowing that
part is isolated from the rest of my panel power. No I don't have a "hot box"
and don't even know what it is. Ol' Suzuki is wired up according to my own druthers.
John, just as mizzerble here in upper NY. Windy and cold. Dug a tater patch
with the backhoe for my brother yesterday.
Flying coming soon.
BB
On 21, May 2008, at 4:10 PM, knowvne(at)aol.com (knowvne(at)aol.com) wrote:
[quote]Thanks for the heads up Dennis.
I haven't started the parts list yet so any and all info is appreciated...
I have ideas floating around in the Grey matter and on paper..
but thats as far as i've gone so far...
I may hard wire a female plug to the battery terminals and install a
In line switch for power... but again that just one idea.. The goal is
a KISS approach.... I want an easy in and out and reliable set up...
Mark
Possums
Posted: Wed May 21, 2008 6:27 pm Post subject: Tansfer pump Ideas? |
At 05:59 AM 5/21/2008, you wrote:
these types of on line Campfires.... Sharing ideas..>>
on my Xtra the engine , Jabiru, pulls fuel equally from 2 tanks connected by a tee piece. Any reason why I can`t put a spare tank on the passengers seat and just add a quick connect into the same fuel line?
Cheers
Pat
You can ....if the tee is below the (bottom) of the tanks.
You could hook up ten tanks that way, and never suck up any air.
Physics 101, fuel is heaver than air.
_________________ Possum |
Dana
Posted: Wed May 21, 2008 7:38 pm Post subject: Tansfer pump Ideas? |
At 10:24 PM 5/21/2008, possums wrote:
| Quote: | You can ....if the tee is below the (bottom) of the tanks.
Physics 101, fuel is heaver than air. |
Not necessarily... if there's any restriction in the tank, like an in-tank filter or even enough hose, and if the pressure drop from that restriction is greater than the pressure due to gravity at the tee, then it'll suck air from an empty tank feeding the tee.
-Dana
Lottery: a tax on the mathematically challenged. [quote][b]
Possums
Posted: Wed May 21, 2008 9:26 pm Post subject: Tansfer pump Ideas? |
-Dana
Lottery: a tax on the mathematically challenged. |
Only if the restriction is more than ..... 1 gallon a minute. We are only feeding a tank here.
[quote]BTW - Lottery: next is 3 22 30 31 44 48 - Fanisty5[b]
Possums
Posted: Wed May 21, 2008 9:34 pm Post subject: Tansfer pump Ideas? |
Then the other tanks will dump fuel into the system.
Possums
Posted: Wed May 21, 2008 9:43 pm Post subject: Tansfer pump Ideas? |
For fun & $
http://www.intrade.com/
Dana
Posted: Thu May 22, 2008 3:11 am Post subject: Tansfer pump Ideas? |
At 01:23 AM 5/22/2008, possums wrote:
| Quote: | | Only if the restriction is more than ..... 1 gallon a minute. We are only feeding a tank here. |
Restriction isn't measured in flow rate; restriction produces a pressure drop at a given flow rate.
At 1 gpm, the pressure drop through a 5/16" hole is the same as the head pressure of 4" (0.104psi). Thus if you have an empty tank teed into a fuel line and the tee is 4" below the liquid level in the tank, it'll start sucking air from the empty tank. At 4 gph (more reasonable), it'd take a .082 hole to get that pressure drop. Now I hope you don't have a .082 fuel passage, but all the restriction is cumulative, so if you have a long hose, a filter, some elbows and valves... I'll keep the aux tank feeding into the top of my main tank, thanks.
-Dana
Income tax: capital punishment. [quote][b]
Posted: Thu May 22, 2008 4:48 am Post subject: Tansfer pump Ideas? |
You can ....if the tee is below the (bottom) of the tanks.>>
My tanks feed fuel from the top. The air breather is also teed to both tanks and tapped into the handles. Now what?
Cheers
Pat
Posted: Thu May 22, 2008 5:08 am Post subject: Tansfer pump Ideas? |
Is yours a Gravity feed?>>
Hi,
No. Tanks are a couple of feet below the engine. Pick up is from the top of the tanks and the balancing air inlets are grommet push fit into the handles. Fuel is drawn equally from both tanks. If I add a third tank, feeding fuel into the same pick up line and adding a tee to the same air line there would be no more chance of sucking air than already exists. They will all empty together (roughly). I assume that I should have to install the tank at the same level as the existing ones?
If I can do this it saves all the problems of transfer of fuel.
Cheers
Pat
knowvne(at)aol.com Guest
Dana
Richard Swiderski
Posted: Fri May 23, 2008 5:00 pm Post subject: Re: Tansfer pump Ideas? |
Sorry if this posted twice, but I thinks I just clicked the 1st attempt int oblivion. I'm not on the List much any more this last year or so, but here are some thoughts on auxiliary tanks:
1) Always plumb so the aux tank drains 1st, as often you must take it to the fuel source.
2) On my UltraStar I installed an aux tank above the engine. It fed the 2 carbs by gravity after changing the float seat valves to gravity feed valves. I then used the fuel pump to transfer fuel from my Ken Brock seat tank to the top of the aux tank which had an overflow that drained back to the seat tank. I modified the pump diaphragm with a neoprene gasket material so it would run dry just fine. I had many trouble free hours with this system but it would have been easier & portable if I had done what I did later with my SlingShot.
3)On the SlingShot the 2nd 5 gal tank was behind the front 5 gal, which put it behind the cg so I modified the plumbing so it drained 1st. I drilled out the vent holes in both tanks & installed a grommet fuel fitting. Both tanks had a fuel pickup tube on it's top. The main tank (front) had it's pickup tube connected to the input of the fuel pump. The vent of the front tank was connected to the pickup of the rear aux. tank. The aux tank vent was plumbed to outside the cockpit. With both tanks full, fuel would be 1st drawn from the aux tank as it was feeding the vent of the main tank. When it was completely dry, then the main tank would begin to go down. An added advantage is I only have to top off one tank if I use less than 5 gal. If the aux tank was portable ( not so with SS) I would have put the female quick disconnect on the pickup of the aux tank and the male coupler ( the always open kind) on the vent of the main tank. This would preclude any way to block the vent & thus keep it fail safe. This is a tried & tested method & it is also cheap! Email me off the List if I did not explain this well enough. -Richard Swiderski
JetPilot
Posted: Sat May 24, 2008 8:35 am Post subject: Re: Tansfer pump Ideas? |
[quote="pj.ladd(at)btinternet.com"]Is yours a Gravity feed?>>
Hi,
Cheers
Pat
Pat,
I would not add a third tank to this system. Pulling fuel from the top of the tank is not a good setup, if you get even the slightest leak anywhere in a suction system such as this you will just be sucking air and the engine will quit. Adding a third tank to this system just increases the chances that you will one day have a slight leak somewhere.
Also, all three tanks need to have the same vent pressure, and need to be at the same level for this system to work. If one of the tanks is emptied before the others for any reason, its pickup tube will immediately fill the fuel system with air, and you will be flying a glider, no matter how full the other two tanks are.
Three tanks being drawn from the top could work, but it is a system with a lot of unnecessary risks and is just an engine failure waiting to happen.
Fuel systems should be pressure fed, that way a pinhole would be a very slow drip instead of a sudden engine stoppage. You also have vapor lock to consider, and a lot of other reasons that your fuel system should be pressure fed rather than having a pump suction fed from the tanks. I had the standard fuel tanks on my MK III, and changed it so that the fuel pump is now below the level of the tanks.
Mike
Kolb MK-III Xtra, 912-S |
JetPilot
Posted: Sat May 24, 2008 8:42 am Post subject: Re: Tansfer pump Ideas? |
Mark,
Why would your engine quit if your Facet pump failed ? Don't you have an engine driven pump ? Most installations have both, on my Kolb the engine does not quit when I turn the Facet pump off.
Also, there is no advantage to installing a relay to control the facet pump. There is not reason to try to "Isolate" the pump from the rest of the electrical system. You only complicate the electrical, and increase risk of a failure for absoluetly nothing. The facet pump draws very little power and is not prone to electrical failures.
Mike
Posted: Sat May 24, 2008 10:01 am Post subject: Tansfer pump Ideas? |
At 09:35 AM 5/24/08 -0700, you wrote:
Mike,
The nice thing about a suction system and feeding from the top of the tank
is there is less likelihood of a fire. I believe I would rather go with the
silent engine rather than a fire. But in both cases the chances of either
are fairly small.
Jack B.
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Sat May 24, 2008 11:42 am Post subject: Tansfer pump Ideas? |
I decided to make one of these and ordered a facet pump. Since I have an old
twinstar and only have a 5 gallon tank, bungee a 5 gal tank on the boom tube
just in front of the H frame. Doubles my range. Knowing how I am, I got to
worrying about what would happen if I left the pump running too long and the
main tank overflowed. So I got to thinking what would be nice would be to
pressurize the bottom tank a little at a time, forcing the gas into the top
tank as needed. I'm a firm believer in the KISS principle, so I ran a pickup
tube in through the cap using a grommet, and then a line from the top of the
tank with a grommet & L to the front next to the seat and put a cutoff valve
on it. Now after flying a while I just puff a lung full of air in the tube &
shut the valve. So long as it holds pressure I know I still have fuel in the
bottom tank. So long as I'm breathing I can transfer fuel. Works great.
Didn't cost me a penny. I have a little mirror I strap on my wrist as a fuel
gauge so when the tank gets down a gallon or two I go to huffin' & puffin'.
If anybody's interested I'll post some pictures.
George
Posted: Sat May 24, 2008 1:11 pm Post subject: Tansfer pump Ideas? |
re: fuel pump relay.... call me quirky.
Guess I'm used to relays after many years in the HVAC business.
My old (homemade) water source heat pump is a Rube Goldberg heaven.
No flames at my house unless I light up the oxy acetylene.
water press switch, time delay relay for the fan, low temp relay,
+ stuff I can't remember. Cheaper than ignition based heat.
BTW I'm living dangerously with the facet being my sole fuel supply.
Car engines seem to lack mechanical pumps with the advent of FI
BB
On 24, May 2008, at 12:42 PM, JetPilot wrote:
Mark,
Mike
http://forums.matronics.com/viewtopic.php?p=184644#184644
Posted: Sat May 24, 2008 1:29 pm Post subject: Tansfer pump Ideas? |
Pretty innovative George. Just don't go huffin' and SUCKIN" heh heh
I have the standard two fives in my MkIII. I have them top fed and
valved for either/or
If my second tank is half full I will go both on the TO trip and
single on the return.
I also carry a mechanical transfer pump just in case.
At 2 1/2 GPH my 8 gallons usable gives me a decent range in the old
tugboat.
BB
have an old
boom tube
got to
long and the
be to
the top
a pickup
top of the
cutoff valve
the tube &
fuel in the
great.
as a fuel
puffin'.
George
Posted: Sat May 24, 2008 1:44 pm Post subject: Tansfer pump Ideas? |
| Quote: | re: fuel pump relay.... call me quirky.
BB
Bob,
Car engines don't have mechanical fuel pumps anymore, because they use those scary, prone to failure, explosive & always spookey...in-tank fuel pumps. Oooooooooohhh!!!!! (ghost noises!)
Oh, btw, Facet uses the same style motor for their fuel pump as ALL in-tank fuel pumps....brushless motors. Ooooooh! (more ghost noises)
Mike Welch
Change the world with e-mail. Join the i’m Initiative from Microsoft. [quote][b]
Posted: Sat May 24, 2008 4:42 pm Post subject: Tansfer pump Ideas? |
Date: Sat, 24 May 2008 14:42:22 -0700
Mike,
I cut open the one that came out of the tank on my 96 GMC Sonoma and the
pump had brushes.
Jack B. Hart FF004
Winchester, IN
