AirMike
Posted: Sun May 25, 2008 7:38 am Post subject: Engine Baffles - Paint/Alodine ? |
Taking a look at my engine baffles and the potential heat that the baffling endues, I am curious to see what others are doing........
I have some 2-part epoxy, but I am worried about discoloration and odor especially during initial flight testing.
Alodine seems to be a good solution (no pun intended) as it should be odorless when hot. There was a short post last Sept. but an update would be appreciated !
_________________ See you OSH '18
Q/B - sold. |
Jim Berry
Posted: Sun May 25, 2008 9:32 am Post subject: Re: Engine Baffles - Paint/Alodine ? |
I painted the baffles on my Pitts 25 years ago with Imron and they still look good except for some minor discoloration next to the cylinder heads. Always had to be careful about scratching them though.
A local shop anodized all the baffles for my -10 for $75. Really looks nice, and I suspect they will be much more durable than paint.
Jim Berry
40482
N15JB(reserved)
gailmrowe(at)roadrunner.c Guest
Posted: Sun May 25, 2008 10:30 am Post subject: Engine Baffles - Paint/Alodine ? |
I had my baffles powder coated by a local outfit. If I remember
correctly there were 9 pieces. Was able to match the "goldish" color
of the engine that came from Mattituck. Not yet flying (but getting
close) so I don't know how it will stand up to the heat but the
powder coaters assured me that their paint was "good" to 500 degrees.
We will see. Jay Rowe 40301 (finishing the wiring and interior).
On May 25, 2008, at 11:38 AM, AirMike wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - exited cabin top/door purgatory
http://forums.matronics.com/viewtopic.php?p=184747#184747
roadmaps
Posted: Sun May 25, 2008 2:33 pm Post subject: Engine Baffles - Paint/Alodine ? |
I painted mine with the same paint they used on the engine - PPG Concept
DCC. Alodined and primed with PPG DPLF primer. The baffles and engine match-
looks good.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Painting and final assembly
carl.froehlich(at)cox.net Guest
Posted: Sun May 25, 2008 2:34 pm Post subject: Engine Baffles - Paint/Alodine ? |
I used Imron on my RV-8A. 400 hrs and it still looks like it was just
painted. I'll probably use PPG Concept (single stage) on the RV-10 as I
have found it to be an easier product to use.
Carl Froehlich
