		SSoule(at)pfclaw.com Guest
				 Posted: Tue Feb 28, 2006 11:38 am    Post subject: Fuel Tank SB. |
				Could you post or locate a sketch? For my next RV ...
 Steve Soule
 Vermont N227RV
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		sbuc(at)hiwaay.net Guest
				 Posted: Tue Feb 28, 2006 11:52 am    Post subject: Fuel Tank SB. |
				Pat Hatch wrote:
  Just another point of reference on this issue:  There are minority of folks
  out there who did not go the Van's route on this.  Personally, I didn't like
  the idea of the pick-up tubes...so I riveted a 1/4" thick piece of aluminum
  as a doubler on to the inboard fuel tank rib, in the rear near the tank
  drain and located inside the tank.  Again, this doubler was riveted to the
  lower inboard corner of the fuel tank and was maybe 2" X 3" X 1/4", just
  enough to enable drilling a hole and tapping for the fitting that contains
  the finger screen pick-up (Aircraft Spruce sells it).
 <snip>
 And this is precisely why the insurance companies can't penalize
 "non-compliers" of a service bulletin! We are dealing with experimental
 aircraft, built by individuals in thousands of diverse shops, not on a
 manufacturer's assembly line.
 If somebody wants to take the position than an insurance company won't
 pay a claim on an accident involving a fuel pickup that doesn't comply
 with a service bulletin, then our friend Pat is in big trouble since he
 isn't even using the Vans pickup! And not only Pat, but anyone else who
 has rudder pedals that don't comply with Vans SB, or a flap motor that
 wasn't returned to the factory per the SB, or an RV-4 that doesn't have
 a reinforced seat per the SB.
 So what defines a "complying RV"? There is no such thing since every RV
 is a unique aircraft constructed by a unique manufacturer, otherwise
 known affectionately as an "experimental aircraft".
 If a builder/owner wishes to comply with Vans's various SB's, fine. But
 the condemnation a perfectly good aircraft to insurance purgatory
 because of failure to comply to a SB is a move that is yet to be
 demonstrated in actual practice by the insurance industry.
 Sam Buchanan
		dan(at)rvproject.com Guest
				 Posted: Tue Feb 28, 2006 12:11 pm    Post subject: Fuel Tank SB. |
				 	  | Quote: | 	 		   and for the life of me I can't figure out why Vans went with the tubes. I
 Probably because if there's a leak, it won't leak ALL of your fuel!
 )_( Dan
 RV-7 N714D
 http://www.rvproject.com
		rv8ch
				 Posted: Tue Feb 28, 2006 1:27 pm    Post subject: Fuel Tank SB. |
				 	  | Quote: | 	 		   ... for the life of me I can't figure out why Vans went with the tubes. ...
 It seems he did use this method on the RV-10.
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
  _________________ Mickey Coggins
http://www.rv8.ch/ |
		Charles Heathco
				 Posted: Wed Mar 01, 2006 5:02 am    Post subject: Fuel Tank SB. |
				Its also on pg 80 of the 24 yrs edition, alongwith othere tank info. Charlie H
