		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Fri May 23, 2008 7:41 am    Post subject: UltraStar engine woes nearing a conclusion |
				Recap:
 My UL-202 was running to hot CHT's and EGT's and no amount of messing with jets and carb needle settings could correct the problem.
 Because the engine had been repaired after a seizure by the previous owner I feel it is suspect but I got a spare Cuyuna 430 with the deal.
 New:
 I swapped out my Cuyuna UL-202 for a 50 hr Cuyuna 430 and it is behaving the same way producing the same high CHT's and EGT's.
 It also can not get more than 5900 rpm like the UL-202
 The only conclusion I can draw is that I have to much prop loading.
 Its a 50" Ritz wood prop, but there is no indication of pitch anywhere on it.
 I figure that I will start cutting down the tips 1/2 inch at a time until I get the RPM up to the recommended 6200-6400 range and see what CHT's and EGT temps result.
 Is there an easy way of measuring the prop pitch, or do I just get out the protractor and a calculator and figure it out using trigonometry?
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
				 Posted: Fri May 23, 2008 8:17 am    Post subject: UltraStar engine woes nearing a conclusion |
				Ray, pitch for "real" airplanes and us guys is two different worlds.
 It would be nice to see a conversion chart (is there one out there?)
 I have come to like the degree method because it is easily measurable
 by the owner.
 10 degrees is a fairly fine pitch, 14 and over is for the fast, high
 HP guys.
 I'm currently at about 11 1/2 with a 70" two blade which gives me
 about 4900 on take off roll.
 I'm going to squeeze it back to about (this ain't a precision deal
 here folks) 10 1/2
 so I can impress the runway turtles.
 BB, managing to fly on 55 hp with a fat MkIII
 looking nicer here now
 On 23, May 2008, at 11:41 AM, jb92563 wrote:
  Recap:
  with the deal.
  New:
  Its a 50" Ritz prop, but there is no indication of pitch anywhere
  on it.
  trigonometry?
  Ray
  Moni MotorGlider
  Riverside County, CA
  http://forums.matronics.com/viewtopic.php?p=184522#184522
		Dana
				 Posted: Fri May 23, 2008 8:55 am    Post subject: UltraStar engine woes nearing a conclusion |
				-------------- Original message ----------------------
 Measure the angle and do the trig.
 -Dana
		Dana
				 Posted: Fri May 23, 2008 8:59 am    Post subject: UltraStar engine woes nearing a conclusion |
  HP guys.
 10 or 14 degrees... where?  That doesn't tell much, as the angle varies along the blade due to the twist.  Near the root the angle is very large and near the tip it's very small.  You need to specify the radius where it's measured, from which you can then calculate the pitch (in inches).
 -Dana
				 Posted: Fri May 23, 2008 11:11 am    Post subject: UltraStar engine woes nearing a conclusion |
				The tip
 On 23, May 2008, at 12:56 PM, d-m-hague(at)comcast.net wrote:
 > HP guys.
  -Dana
				 Posted: Fri May 23, 2008 12:38 pm    Post subject: UltraStar engine woes nearing a conclusion |
				At 08:41 AM 5/23/08 -0700, you wrote:
 Ray,
 No trig is required.  Using a bubble level, level the leading edge of the
 blade that is being adjusted. Measure the angle to the vertical using an
 incline meter across the blade tip.  Adjust the blade to the new desired
 change in angle.  Then rotate each unchanged blade into the level position,
 and repeat the change.  If you have an IVO then you only have to do this
 once.
 To find the final pitch, repeat the blade leveling (up blade) and recorded
 the tip angle to the vertical.  Then rotate the blade 180 degrees, level
 the same leading edge (down blade), and measure the same angle.  Add the
 two together and divide by two and you have the blade pitch.
 Jack B. Hart FF004
 Winchester, IN
		Dana
				 Posted: Fri May 23, 2008 1:15 pm    Post subject: UltraStar engine woes nearing a conclusion |
				At 03:08 PM 5/23/2008, robert bean wrote:
 Still not enough... pitch is a function of blade angle and the radius where
 it's measured.
 Pitch (in inches) = tan(blade angle) * 2*pi*R
 Many props don't have a constant pitch, so it's typically measured 75% of
 the way out from the hub.
 -Dana
   Work is underway on drafting a new constitution for Iraq.  Why don't we
 send them ours?  It worked for 200 years, and we don't use it any more.
		Dana
				 Posted: Fri May 23, 2008 1:20 pm    Post subject: UltraStar engine woes nearing a conclusion |
				At 05:35 PM 5/23/2008, Jack B. Hart wrote:
  	  | Quote: | 	 		  No trig is required.  Using a bubble level, level the leading edge of the
 change in angle...
 Jack, trig IS required to get the pitch.  What you've described is getting
 the blade _angle_, which is what you use for setting an adjustable prop...
 what Ray needs is the pitch (in inches) of his fixed blade prop.
 Ray:  Measure the angle of the back side of the blade 75% of the way out
 from the hub (for the standard 50" Ultrastar prop that's 18-3/4" out.  Then:
 Pitch (in inches) = tan(blade angle) * 2*pi*18.75
 I've never measured mine, but I'm told the standard US prop is a 50X30 (30"
 pitch).
 -Dana
				 Posted: Fri May 23, 2008 2:13 pm    Post subject: UltraStar engine woes nearing a conclusion |
				At 05:15 PM 5/23/08 -0400, you wrote:
 Danad,
 OOPS!
 You are absolutely correct.
 Jack B. Hart F004
 Winchester, IN
		jb92563
				 Posted: Fri May 23, 2008 2:37 pm    Post subject: Re: UltraStar engine woes nearing a conclusion |
				Thanks guys.
 I sat down and crunched some numbers.
 PI = circumference of circle in radians
 Circumference = PI x Diameter
 hence Circumference= 3.14159 x 50"
 Pitch = distance advanced during 1 complete rotation not accounting for slippage etc.
 Pitch = Tan(Blade Angle (at) 75% to tip) x (3.14159 x 50")
 So for a 50x30 prop the angle at 75% out to the tip should be about 11 Degrees.
 If I measure more than this then I know my prop pitch is definitely to high.
 Being a fixed pitch wood prop the easiest solution is to cut the tips down.
 The rpm should go up, and hopefully the CHT's and EGT will come down making my engine and me happy again.
 Then I can finally fly this thing and learn what flying a Kolb is all about.
Moni MotorGlider
Do Not Archive |
		Dana
				 Posted: Fri May 23, 2008 6:10 pm    Post subject: UltraStar engine woes nearing a conclusion |
				Ray, not quite correct:
 At 06:37 PM 5/23/2008, jb92563 wrote:
  	  | Quote: | 	 		  I sat down and crunched some numbers.
 No, radians are a measure of angles.  2pi radians = 360°.
  	  | Quote: | 	 		  Circumference = PI x Diameter
 Correct, but read on.
  	  | Quote: | 	 		  Pitch = distance advanced during 1 complete rotation not accounting for
 slippage etc.
 Degrees.
 No, you need to use 75% of the diameter too, you use Pi * 50 * .75  so the
 angle at the 75% point (18-3/4" from the centerline) should be 14.3°
 (arctan(30/(pi*50*.75)).
  	  | Quote: | 	 		  If I measure more than this then I know my prop pitch is definitely to high.
 Be sure you balance it after you cut it!
 One thing you might want to try if you're trimming the prop anyway... I'd
 try it myself if I had to modify a prop ... is the tip mod described on
 Jack Hart's website:
 http://www.thirdshift.com/jack/firefly/firefly100.html
 -Dana
   Inflation is a result of legalized counterfeiting.
		jb92563
				 Posted: Fri May 23, 2008 9:34 pm    Post subject: Re: UltraStar engine woes nearing a conclusion |
				Thanks Dana for validating and correcting my formulas.
 I'll check out those prop tips and measure my prop pitch in the morning.
Moni MotorGlider
Do Not Archive |
		jb92563
				 Posted: Tue May 27, 2008 6:48 am    Post subject: Update: UltraStar engine woes nearing a conclusion |
				I cut down the prop tips yesterday by 3/4"
 So now I have a 48 1/2 " diameter instead of 50".
 I ran up the engine (Cuyuna 430) and got a bit of belt slipping that allowed 6400 rpm but once that stopped it steadied at 5800.
 Not really what I expected as I figured rpm would go up a lot more.
 However after running the engine at full power for a a good 5 minutes it was apparent that the CHT's were staying a lot lower.
 It pretty much took the full 5 minutes for the engine CHT's to creep up to their highest temps.
 The front fan side cylinder only went as high as 365 and stopped climbing and the rear cylinder only went to 408 which is slightly over the 400 redline.
 The EGT's however went to 1400 so perhaps my jetting is a bit lean.
 I need to find my notes on what the various EGT's &CHT's mean to see what needs to be done next.
 I also noticed that there seemed to be significantly more static thrust.
 Looks like I'm getting closer to solving the engine problems.
Moni MotorGlider
Do Not Archive |
