n277dl
Posted: Thu May 29, 2008 6:08 pm Post subject: removeable co-pilot stick |
Anyone made the copilot control stick removable? My wife enjoys the stick being pulled for long cross countries in the -7.
Doug
_________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Dave(at)AirCraftersLLC.co Guest
Posted: Thu May 29, 2008 10:04 pm Post subject: removeable co-pilot stick |
To take ours out we just unbolt it using the per-plans hardware. As you
move the stick full forward the bolt kind of presents itself. It seems like
a bad job but it only takes a few minutes. A pip pin would make it even
easier but it wouldn't be as tight. We used an Amp plug in the panel
adjacent to the stick for wiring.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Posted: Fri May 30, 2008 4:46 am Post subject: removeable co-pilot stick |
Why not a ball pin??? Check out [url=http://www.reidsupply.com/catalog.aspx?pn 77]http://www.reidsupply.com/catalog.aspx?pn 77[/url] .......
Linn
orchidman wrote: [quote] | Quote: | --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com> (gary(at)wingscc.com)
n277dl wrote:
| Quote: | Anyone made the copilot control stick removable? My wife enjoys the stick being pulled for long cross countries in the -7.
Doug
There was a thread like this I believe over on VansAirForce some time ago. I am thinking about it but have not come to any conclusion yet nor has it come to the time when any decision must be made. From the thread I noted and stored one thing that might be able to be used. It is from McMaster.com (McMaster-Carr) and is called a 'Telescoping Tubing Quick-Release Button connector'. The part numbers of note are 92988a650 and 92988a730. Not sure if they would work but it is floating around in the mush between my ears. [Laughing]
Gary Blankenbiller
RV10 - # 40674
Instrument Panel, Fiberglass - SB
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=185474#185474
| [b]
johngoodman
Posted: Fri May 30, 2008 5:54 am Post subject: Re: removeable co-pilot stick |
I think that Dave's "pip pin" is the same thing as a "ball pin". Perhaps it's a brand issue like pop-rivets vs. blind rivets....
_________________ #40572 Phase One complete in 2011 |
Posted: Fri May 30, 2008 6:00 am Post subject: removeable co-pilot stick |
Linn,
Ball pin,,,,AKA.....pip pin..
Rick
Posted: Fri May 30, 2008 6:24 am Post subject: removeable co-pilot stick |
Think it's a military or aircraft thing for "push-in-pull"
n277dl
Posted: Sat May 31, 2008 6:57 pm Post subject: Re: removeable co-pilot stick |
thanks for the options folks.
Doug
