kearney(at)shaw.ca Guest
Posted: Sat May 31, 2008 5:37 am Post subject: Wiring Questions |
Hi
I am in the process of planning my wiring and have a couple of questions for the list.
First, I am planning on using Infinity stick grips. When wiring these grips through the control stick tube, how does one protect the wires from undue stress when the control stick is moved?
Are there any rules of thumb that can be used when deciding what sizes of shrink wrap to be used in an applications – in particular what arte the most common sizes that are used. I would like to order some from ACS but have no idea as to quantities and sizes I should get.
Lastly, what is the difference between a 4 indent and a 8 indent D-Sub crimper? Which is preferable?
Inquiring minds need to know….
Les Kearney
#40643
dlm46007(at)cox.net Guest
Posted: Sat May 31, 2008 6:06 am Post subject: Wiring Questions |
try www.mcmaster.com for spiral wrap. They also have wraps that will take
under cowl temps
s easy-to-use spiral wrap installs
like tape around bundles of wire, tube, and hose.
Wrap also permits access anywhere along its length.
Polyethylene—Comes on a spool. Temperature range
is –76° to +190° F. Sleeving is abrasion and solvent resistant
and is UL recognized. To Order : Please specify length
from those listed in the table. Clear wraps are for indoor
use. Ultraviolet-resistant wrap is black and ultraviolet-stabilized
for outdoor use in direct sunlight. Choose-a-color
wraps are for indoor use. To Order : Please specify blue,
green, orange, red, white, or yellow.
1/2 to 5 for self-extinguishing nylon sleeving. Lengths are not
continuous.
OD
Bundle Dia.
Range
CHOOSE-A-COLOR POLYETHYLENE SELF-EXTINGUISHING NYLON
Wall
Thick.
Each Wall
Thick.
Each
10 ft. 25 ft. 50 ft. 100 ft. 10 ft. 25 ft. 50 ft. 100 ft.
1 / 8 . . 1 / 16 to 1 / 2 . . 0.032 . . 7378K41 . . . . . . . . . $1.99
$4.44 $8.11 $14.77 0.015 . . . . . . . . . 7432K56 . . . . . . . . . . .
wcurtis(at)nerv10.com Guest
Posted: Sat May 31, 2008 6:43 am Post subject: Wiring Questions |
shrink wrap
One each of: 1/4'', 3/8'', 1/2'', 3/4'', 1'' 48" long
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9639
William
http://nerv10.com/wcurtis/
roadmaps
Posted: Sun Jun 01, 2008 4:29 am Post subject: Wiring Questions |
I used the Case Mod sleeving on my stick grip wires. Also used it on several other cables on the plane - like wing connections. One kit pretty much took care of everything I needed. It has several sizes. It is tough stuff. You cut (melt) it with a soldering iron and put heat shrink on the ends (some heat shrink comes with the kit). Here is the link:
http://www.xoxide.com/techflex6.html
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Painting and final assembly
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Saturday, May 31, 2008 9:35 AM
Subject: Wiring Questions
Hi
Les Kearney
#40643
| No virus found in this incoming message. Checked by AVG. Version: 7.5.524 / Virus Database: 269.24.4/1475 - Release Date: 5/30/2008 2:53 PM
Checked by AVG.
5/31/2008 12:25 PM
Posted: Sun Jun 01, 2008 7:29 pm Post subject: Wiring Questions |
Hi John
Thanks for the info. Now that I know what to look for, I was able to find it locally.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
Sent: June-01-08 6:26 AM
Subject: RE: Wiring Questions
John Testement
40321
Richmond, VA
Hi
Les Kearney
#40643 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
Checked by AVG.
5/31/2008 12:25 PM 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4
