				 Posted: Mon Jun 02, 2008 8:32 am    Post subject: heat transfer compound |
				Do you have to use a heat transfer compound on plugs in a 447?
                                                  Bill Sullivan
                                                  Kolb Firestar/447
                                                   Windsor Locks, Ct.
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Mon Jun 02, 2008 11:35 am    Post subject: Re: heat transfer compound |
				The 2 strokes do not get any paste, lube or anti-seize at all. They are supposed to be a dry thread and torqued because the heads on the 2 strokes are softer aluminum (different materials than the 4 strokes) and can be damaged with improper torque. This can happen whether they are dry if you use to much torque, but more susceptible if lubricated.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		imap8ntr(at)cox.net Guest
				 Posted: Mon Jun 02, 2008 12:42 pm    Post subject: heat transfer compound |
				Roger
 On my 582 the US Dealer/Distributor had me put antiseize on the sparkplugs
 (silver colored antiseize.)
 Ivan
		Roger Lee
				 Posted: Mon Jun 02, 2008 3:54 pm    Post subject: Re: heat transfer compound |
				Hi Ivan,
 I went back through all the 2 stroke manuals and it doesn't say anything about the use of anti-seize on 2 stroke plugs, but it is taught not to use anything on 2 stroke threads in the Rotax classes. If the manual doesn't say use it there must be a reason for it.
 It does say to torque them on a cold engine only. Remember the heads are aluminum and the plug threads are steel. No gorilla arms when tightening plugs.
 The maint. manual says to torque the plugs on a cold engine to 238 in/lbs or 19.8 ft/lbs. page 11-4 sec. 11.8
 The installation manual says to torque the plugs with a CHT sensor ring in place to 133 in/lbs. or 11 ft/lbs  pg 20-1 fig. 49
 This is quite a difference. Might help to call Lockwood for a clarification.
Tucson, Az.
Cell 520-349-7056 |
				 Posted: Mon Jun 02, 2008 4:32 pm    Post subject: heat transfer compound |
				Thanks for the info.  Kemmeries Aviation,  the US importer for Air Creation
 Trikes which all come with Rotax engines,  gave me this info.  I will double
 check it this month.
 Ivan
		Float Flyr
				 Posted: Mon Jun 02, 2008 4:46 pm    Post subject: heat transfer compound |
				I've been criticized for this before but I always torque the plugs on my 582 to 220 in.lb. intentionally.  I tend to check my plugs quite often (5-10hr) and have never had a problem with the lower torque.  I do check my torque wrench annually for calibration at that torque.  I  also never use anything on the threads of my plugs except a soft clean cloth.  Whenever I remove all the plugs I will put a clean shop towel over the plug openings to keep any grit from getting into the combustion chambers.
 Noel
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Roger Lee
				 Posted: Tue Jun 03, 2008 11:52 am    Post subject: Re: heat transfer compound |
				Hi Noel,
 I don't see any thing to criticize. You torque the plugs within 1 ft/lb. Not a big deal since many don't torque them at all.
Tucson, Az.
Cell 520-349-7056 |
		Float Flyr
				 Posted: Tue Jun 03, 2008 4:31 pm    Post subject: heat transfer compound |
				I'm a bit anal about torque and using a calibrated wrench.  I have been
 criticized for doing the lower torque but I do it for two reasons.  1. I
 pull my plugs a lot... I never really trust the EGTs to do more than give me
 a trend.  Plugs will always tell the whole story.  2. I feel the 20 in. Lb.
 will create less stretching of the heads.  I've been torquing plugs into
 outboard engines, snowmobiles etc.. for more years than I like to think
 about and I've yet to strip a thread.. I've also yet to lose a plug from
 having it too loose.
 The important thing is consistency.  You can only get that if you use a
 torque wrench or for the real small stuff a torque meter.
 Thanks for the reply Roger
 Noel
Kitfox III-A
