		RV-6(at)comcast.net Guest
				 Posted: Sat Feb 25, 2006 4:46 pm    Post subject: Fuel tank SB (it's easy) |
				I was helping a friend annual his RV-7 today and he decided he wanted to
 comply due to insurance issues.
 It took less than 1/2 hour to do the first tank. A lot easier than I
 expected.
 Drilling the nut is no problem if you do it on the end away from the
 threads.
 There's plenty of meat there.
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		sears(at)searnet.com Guest
				 Posted: Sun Feb 26, 2006 2:56 am    Post subject: Fuel tank SB (it's easy) |
				 	  | Quote: | 	 		   I was helping a friend annual his RV-7 today and he decided he wanted to
  expected.
  threads.
 Excuse me; but, I'd really like to know how he did it that quickly.  Let's
 see.  One has to gather the stuff to drain the tanks.  Drain the tanks.  Get
 the tools gathered to clean the proseal off the screws, etc.  Clean the
 proseal off of the screws, etc. to remove the cover plate.  Remove the cover
 plate.  Gather the stuff to fix the problem.  Fix the problem.  Mix up a
 batch of proseal, after cleaning the areas that are to receive the proseal.
 Put the plate back on with the proseal.  Clean up any messes and put away
 the tools.  That's if one doesn't have to remove the tanks!   Now, tell me
 how he did that in 1/2 hour because I see this taking hours to do.  I may be
 missing something.  It's takes me longer than that to clean up and reseal a
 leak at the plate, much less removing it and reinstalling it.
 Jim Sears in KY
 RV-6A N198JS (Scooter)
 RV-7A #70317
 EAA Tech Counselor
		Steve Glasgow
				 Posted: Sun Feb 26, 2006 7:31 am    Post subject: Re: Fuel tank SB (it's easy) |
				Is there a solvent that will clean the pro seal off?
 Is there a gasket between the fuel sender access plate and the T-408 access plate?
  _________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
		evmeg(at)snowcrest.net Guest
				 Posted: Sun Feb 26, 2006 8:03 am    Post subject: Fuel tank SB (it's easy) |
				Nope....no solvent will work after it is cured....use a razor blade. There
 is supposed to be a gasket between the sender and the access plate...throw
 it away and proseal the sender on. That crappy gasket is by far the single
 biggest leaker on these tanks. Also put a small smudge of sealant on the
 underside of each of the screw heads before you tork them down. It will
 squidge out and make a perfect little gasket around the screw head.
 Evan Johnson
 www.evansaviationproducts.com
 (530)247-0375
 (530)351-1776 cell
		bill(at)vondane.com Guest
				 Posted: Sun Feb 26, 2006 8:19 am    Post subject: Fuel tank SB (it's easy) |
				Ok, so when I built my tanks I thought about this and although I didn't
 totally proseal the tube and connector, I did build the anti-rotation
 bracket a little differently...  If I were to do it again I would just
 proseal the whole thing as you should never need to do anything with it
 again...
 I built and installed my anti-rotation bracket so that it not only keeps the
 90 degree fitting from rotating, it also keeps the nut from backing off and
 the tube from ever falling off...
 So tell me what you all think...  Do any of you think it could ever come
 loose or fall off?
 http://www.rv8a.com/tanks/ps4.jpg
 -Bill VonDane
 RV-8A - Colorado
 www.rv8a.com
 www.creativair.com
 www.epanelbuilder.com
		Steve Glasgow
				 Posted: Sun Feb 26, 2006 8:29 am    Post subject: Re: Fuel tank SB (it's easy) |
				Thanks Evan.  The perfect answer.
Cappy's Toy
RV-8 N123SG |
		rv8ch
				 Posted: Sun Feb 26, 2006 8:49 am    Post subject: Fuel tank SB (it's easy) |
 To me it looks like you're in good shape, Bill.
 One side question - the "proseal" on my QB tanks is very
 very tough.  The "proseal" I got from Van's is about as
 strong as RTV.  Does anyone know where to get the strong
 stuff?
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
  _________________ Mickey Coggins
http://www.rv8.ch/ |
		cgreimer(at)mts.net Guest
				 Posted: Sun Feb 26, 2006 9:27 am    Post subject: Fuel tank SB (it's easy) |
				I can see why this would be a problem with the flop tube but not with all
 the other flare nuts - most flare nuts don't have a 1 lb hose flopping
 around, attached only at one end. If this were a firewall forward hose it
 would be required to be secured with Adel clamps!
  	  | Quote: | 	 		  From my perspective, the whole flop tube concept is far more trouble than
 it's worth for anyone other than die-hard negative-G aerobatic flyers. When
 I rip into my tank to deal with this, my flop tube is coming off and will be
 replaced with a solid aluminum pickup tube.
 The potential for a hung-up tube, this nut loosening issue, and the
 requirement to replace the flop tube periodically add up to too much
 maintenance hassle and risk. (There is at least one report in the RVator of
 an RV-4 with a fuel pickup problem that was attributed to a flop hose that
 had deteriorated and was leaky as a sieve. That time Van's stopped short of
 issuing an SB - I wonder what they would do today?)
 Curt
 RV-6 C-GACR
 375 hours
		shempdowling2(at)earthlin Guest
				 Posted: Sun Feb 26, 2006 12:31 pm    Post subject: Fuel tank SB (it's easy) |
				Hey Jim, once you do this the first time, Im sure it will get much quicker.
 Sooooo, how about doing ehhhhh, lets say 3 more rvs
 shemp
		chaztuna(at)adelphia.net Guest
				 Posted: Sun Feb 26, 2006 7:37 pm    Post subject: Fuel tank SB (it's easy) |
				Bill,
   Your design reminds me of the phrase "A snowball's chance in hell"
 Charlie Kuss
 again...
 loose or fall off?
 -Bill VonDane
 RV-8A - Colorado
 www.rv8a.com
 www.creativair.com
		Kellym
				 Posted: Sun Feb 26, 2006 8:44 pm    Post subject: Fuel tank SB (it's easy) |
				I guess you haven't looked at the number of mandatory service bulletins
 Lycoming, Piper and Cessna have issued over the years. And Part 91
 pilots mostly ignore them until and if they become ADs. Right up there
 with the dozen mandatory service bulletins Parker Hannifan has issued on
 Airborne vacuum pumps, that all went in the round file.
 Do not Archive
 bdjones1965 wrote:
  Not sure about everyone else out there, but I kind of doubt my flop tube is "flopping" around very much at all.  It may shift around side to side a little and maybe once every year or two I'll really botch something and get negative.  Other than that, I'd be more worried about the weight wearing a hole in the bottom of the tank where it's sitting in 99+% of the time.
  I find two things really curious.  One is why Van has apparently crossed into the grayness of liability and appears to have assumed some partial role as manufacturer by sending out these Service Bulletins.  This "SB" looks and smells just like one you might get from a *manufacturer*.  And his wording was just too much like that of a manufacturer as well.
  Second, speaking of risk, I have several other hose fittings in my plane that *will* cause engine stoppage - maybe I need to safety those as well.  A flop tube connection failure *may* cause stoppage, and should be recoverable by switching tanks.
  This flop-tube item is pretty far down on the priority list for me.  Not to mention that I specifically remember tightening that nut very well.
  But now Van's has me concerned about the applicability of my insurance if I don't comply with this overreactive "SB", while not being worried about the airworthiness of my plane.  Gee, I would expect this kind of treatment from Cessna, Piper or Lycoming.
  Bryan RV-8
  Houston, Texas
  http://forums.matronics.com/viewtopic.php?p=15240#15240
KCHD |
		low pass
				 Posted: Mon Feb 27, 2006 7:29 am    Post subject: Re: Fuel tank SB (it's easy) |
 Lycoming, Piper and Cessna have issued over the years....
 I've owned a production plane and have done a good bit of research along the lines of AD's, SB's, etc.  So I'm familiar with this process.
 But I'm not sure I understand your point.  Cessna, Piper, Lycoming and Parker-Hannefin, etc. all have issued quite a few SB's that, IMO, are overly conservative.  This mostly due to the frivolous lawsuits flying around over the last 20 years.  That was my point.
 BTW - looks like you caught my post before I decided to delete it and stay out of this conversation.  I'm still thinking about how I'll address this thing.  And I did enjoy a safe, fun afternoon of flying yesterday.
 Bryan RV-8
 Houston, Texas
		lhelming(at)sigecom.net Guest
				 Posted: Mon Feb 27, 2006 10:49 am    Post subject: Fuel tank SB (it's easy) |
				I bought mine from Vans.  When mixed properly, and shown respect for its age
 and the temperature environment it was stored in I had excellent results.
 If kept in an ice box at about 35F it is still usage after a couple years.
 You must of gotten a bad batch.  I would return it to Vans so they can
 decide if you should get a free one.  Vans is very easy to work with and
 fair.  They don't always do what the customer wants, but I can appreciate
 that too because they are trying to keep their costs and our prices down.
 RTV will literally melt/dissolve/become mushy in fuel.
 Indiana Larry, RV7 "SunSeeker" 90+ hours flying
 "Please use the information and opinions I express with responsibility, and
 at your own risk."
 > loose or fall off?
  stuff?
  Mickey Coggins
  http://www.rv8.ch/
  #82007 finishing
		Terry Watson
  Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
				 Posted: Mon Feb 27, 2006 11:44 am    Post subject: Fuel tank SB (it's easy) |
				Van's is selling a new kind of tank sealant with a 4 month shelf life. I
 have had a can of the old stuff in my refrigerator for at least two years,
 maybe twice that, and every time I use some it seems to work fine.
 Terry
 This is from their current web catalog:
 Fuel Tank Sealant
 Required Sealant for Building Your Tanks
 Description
 MC-236-B2 (Quart Kit)
 The recommended sealer for RV fuel tanks, replaces older ProSeal. Limited
 shelf life (approximately 4 months from purchase). Order the Quart Kit when
 ready to seal tanks. With careful application, one can should do one
 airplane, even the larger RV-7 and RV-8 tanks, but many builders use more.
 Includes accelerator.Sealing compound and accelerator are mixed by WEIGHT at
 a ratio of 10:1. Save yourself a call. We know that the quart can does not
 contain a full quart of sealant. This is normal.
		Dale Ensing
  Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
				 Posted: Tue Feb 28, 2006 6:12 am    Post subject: Fuel tank SB (it's easy) |
				"RTV will literally melt/dissolve/become mushy in fuel."
 By RTV I assume you are talking about general purpose room temperature vulcanizing silicone sealants.
 Your statement is not true of fluorosilicone sealants. I have two pieces of aluminum bonded together with  Dow Corning 730 RTV sealant immersed in 100LL in a glass jar for 6 years and there is no indication of degradation of the sealant. This is my test piece as I used it to seal wing inspection covers. It will be much easier to remove for the MSB  than the Proseal.
 Dale Ensing
  _________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
		chuck515tigger(at)yahoo.c Guest
				 Posted: Tue Feb 28, 2006 7:56 am    Post subject: Fuel tank SB (it's easy) |
				Dale,
   Where do ya' order the Dow Corning 730 RTV sealant ?   I bent my tank inspection plates tryin' to take 'em off after 3 years of being "Pro-sealed".
   Chuck
 Dale Ensing
 Brings words and photos together (easily) with
				 Posted: Tue Feb 28, 2006 8:06 am    Post subject: Fuel tank SB (it's easy) |
				You are correct, I was referring to room temp. vulcanizing.  Which specific
 fluorosilicone sealant are you referring to from the list?
 http://www.nusil.com/Engineering-Silicones/Aircraft/AircraftProducts.aspx?SCID=12
 Thanks.
 at your own risk."
		pbesing(at)yahoo.com Guest
				 Posted: Tue Feb 28, 2006 7:47 pm    Post subject: Fuel tank SB (it's easy) |
				Great test, Dale...I look forward to your continued
 findings...but, if it were me, I'd bet you won't find
 anyting different in another 6 years.  Proseal??
 Paul Besing
 --- Dale Ensing <densing(at)carolina.rr.com> wrote:
  fuel."
  sealants.
   than the Proseal.
  Dale Ensing
  browse
  Subscriptions page,
  FAQ,
  Admin.
		lsbrv7a(at)yahoo.com Guest
				 Posted: Tue Feb 28, 2006 8:04 pm    Post subject: Fuel tank SB (it's easy) |
				Dale, Do you mean the tank inspection covers?
   Sherman Butler
 Dale Ensing
 Sherman Butler
 RV-7a Empennage
 Idaho Falls
 Bring photos to life! New PhotoMail  makes sharing a breeze.
		rv8ch
				 Posted: Tue Feb 28, 2006 10:33 pm    Post subject: Fuel tank SB (it's easy) |
				 	  | Quote: | 	 		   I bought mine from Vans.  When mixed properly, and shown respect for its age
 Hi Larry,
 Was your "proseal" in the caulk tube or in the can?
 Mine was in the tube.  I've got a picture of the label
 here:
   http://www.rv8.ch/article.php?story=20040726220023545
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
