spark plugs and rain
Goto page 1, 2  Next
larry(at)macsmachine.com
PostPosted: Mon Jun 02, 2008 4:32 pm    Post subject: spark plugs and rain Reply with quote
Hi guys,
I recently flew thru some rain showers and was wondering if there was
any prospect of fouling the plugs electrically. Nothing was noticed,
but the rain that washed over my canopy and wings got rid of a lot of
bugs. Is there any reason to worry about a light rain?
Jaybannist(at)cs.com
PostPosted: Mon Jun 02, 2008 5:20 pm    Post subject: spark plugs and rain Reply with quote
Larry,
I have flown through rain many times in production airplanes and never had a problem with the operation of the engine. I think that those spark plugs are so hot that moisture just sizzles off before it can create a short circuit.
Jay in Dallas
LarryMcFarland <larry(at)macsmachine.com> wrote:
Hi guys,
psm(at)att.net
PostPosted: Mon Jun 02, 2008 5:33 pm    Post subject: spark plugs and rain Reply with quote
Hi Larry,
Rain shouldn't be a problem in and of itself. However, it does
present a couple of secondary issues.
First is the reduced viability. If your only method of avoiding
aluminum or granite clouds is by looking out the windshield then rain
can reduce this ability.
Second, if the temperature is right (wrong?) you face the possibility
of rapid build up of clear ice. This will prevent your plane from
flying due to the changed airfoil shape and rapidly increased
weight. The good news is if you change altitude soon enough the ice
will melt. However, if you are already at low altitude your options
are quickly reduced. Icing happens only near the freezing point of
water - give or take a few degrees, so if you stay well above that
air temperature you should not have a problem.
Third (and this is a stretch) is the possibility of carb ice. To get
rain it must be around 100 percent humidity and this means carb ice
will form if the outside air temperature is in the neighborhood of 70
degrees. I might be wrong about the actual temperature since it
depends on the temperature reduction in your
carburetor. Fortunately, you probably have carb heat to deal with
this. If it is raining and your engine starts running rough or slow
then adding carb heat is a great idea.
Lastly, rain is noisy. It can make you very nervous. It can also
get you silly comments from ATC like "multiple targets in your
vicinity". (I got that once from a very green Air Force tower controller.)
Have fun,
Paul
XL fuselage
At 05:29 PM 6/2/2008, you wrote:
Hi guys,
was any prospect of fouling the plugs electrically. Nothing was
noticed, but the rain that washed over my canopy and wings got rid
of a lot of bugs. Is there any reason to worry about a light rain?
kmccune
PostPosted: Mon Jun 02, 2008 5:50 pm    Post subject: Re: spark plugs and rain Reply with quote
Rain water does not have any (many?) minerals, so it should not conduct or short your electrical system.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
Ron Lendon
PostPosted: Mon Jun 02, 2008 5:52 pm    Post subject: Re: spark plugs and rain Reply with quote
Larry,
Everything about the electrical seems to have been covered. I don't think light rain would be much of a problem. Kinda like driving your car through a puddle. Heavy rain would be like driving through the river.
I would shy away from rain if you have a wood prop. I hear it's not good for them, no actual experience.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
raymondj(at)frontiernet.n
PostPosted: Mon Jun 02, 2008 5:57 pm    Post subject: spark plugs and rain Reply with quote
I got my PP in Oregon. Consequently, I flew in a lot of rain and very humid
conditions. Carb ice is not uncommon on a mid 60deg day in the rain. Used
to have to use some carb heat just getting to the departure end of the
runway. It is something to be aware of in the rain.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
professor71(at)HOTMAIL.CO
PostPosted: Mon Jun 02, 2008 6:38 pm    Post subject: spark plugs and rain Reply with quote
Hi Larry
I have been through several light-moderate rain showers without a problem with the engine. A little anecdote here (please do not laugh to hard) The first time it happened (light shower) I was still pretty new to flying and I started dropping altitude figuring I would avoid any clouds. My friend who is an 80 year old pilot started chuckling and asked me where I was going. He said the rain goes all the way to the ground, just thank God for the free wash job. I do remember that the rain on the canopy was real loud.
John
Date: Mon, 2 Jun 2008 19:29:30 -0500
To: zenith-list(at)matronics.com; stratus-list(at)matronics.com
Subject: spark plugs and rain
--> Zenith-List message posted by: LarryMcFarland <larry(at)macsmachine.com>
Hi guys,
&gt
Change the world with e-mail. Join the i’m Initiative from Microsoft.
davgray(at)sbcglobal.net
PostPosted: Tue Jun 03, 2008 2:46 am    Post subject: spark plugs and rain Reply with quote
With respect to VFR pilots and VFR aircraft
One of my instructors, ex navy pilot, told me if you can't see all the way
thru the rain shower area then you should consider going around it. Once
you enter it, you can not be sure you will find any area with better
conditions.
Gary Ray
grant.corriveau(at)TELUS.
PostPosted: Tue Jun 03, 2008 6:48 am    Post subject: spark plugs and rain Reply with quote
Piston-powered commercial aircraft operate in all sorts of weather.
I've never heard of spark plugs being a problem assuming that the
engine compartment isn't being flooded. Even then, the plugs and
ignition system is usually pretty water proof from the outside...
Referring to spark plugs inside the cylinder, remember that the air
is heated several degrees by compression, first in the induction
system due to initial compression (and even manifold preheat on most
automotive conversions like my CAM100); then with in-cylinder
compression the heating is significant. All this to say that shortly
after the air enters the cylinder, the relative humidity is really
really low.
Another small point - water injection was once a technique used to
help gain even more compression of air into (mainly? exclusively?)
jet engines. The heat absorbed by the energy of vaporization of
water allowed for more dense intake of air, so more power - helpful
on really hot days. so, fwiw - the rain may be helping our piston
engines develop more power.
In the previous responses to your posting, perhaps not enough stress
has been placed on the wear and tear that occurs on non-metal
propellors. Check the archives for George Pinneo's comments about
how badly his composite prop was eroded by flight in rain. I plan to
eventually have my Warp Drive prop re-finished with the nickel
leading edges because now that I'm flying on the West Coast, rain is
an inevitability.
Grant
GHTF 601HDS
CAM100
DaveG601XL
PostPosted: Tue Jun 03, 2008 7:20 am    Post subject: Re: spark plugs and rain Reply with quote
The Sensenich rep at Sun-N-Fun recommended pulling the power back to 2200 RPM if flying one of their wooden props in the rain. I was asking about the prop that goes with the Jabiru, W64ZK-49. This may be different for another prop size.
David Gallagher
Cincinnati, OH area
ggower_99(at)yahoo.com
PostPosted: Tue Jun 03, 2008 11:02 am    Post subject: spark plugs and rain Reply with quote
Just a fast comment, The 2,200 rpm are in the propeller, so do your math with the reduction drive if using a Rotax 912... Yes there are at least a couple of 912's using wooden props around here. (not mine).
Saludos
Gary Gower.
--- On Tue, 6/3/08, DaveG601XL <david.m.gallagher(at)ge.com> wrote:
[quote]From: DaveG601XL <david.m.gallagher(at)ge.com>
Subject: Re: spark plugs and rain
Date: Tuesday, June 3, 2008, 11:20 AM
[quote]--> Zenith-List message posted by: "DaveG601XL" <david.m.gallagher(at)ge.com> The Sensenich rep at Sun-N-Fun recommended pulling the power back to 2200 RPM if flying one of their wooden props in the rain. -------- David Gallagher 601 XL, working on final assembly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186039#186039 [quote][b]
rtdin
PostPosted: Tue Jun 03, 2008 11:27 am    Post subject: spark plugs and rain Reply with quote
I don't think rain will effect a normal ignition system. There is a lot of rain here along the Gulf Coast and a lot of us fly VFR in it. A good point well made is to not fly through anything that you cannot see through. After a dozen hours, a little in rain, my wood prop looked like it had been dragged behind a pick up truck. The new clear finish had been applied over the brass abrasion strips. The degradation started there.
Bob Do not archive
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
(http://food.aol.com/tyler-florence?video=4?&NCID=aolfod00030000000002) [quote][b]
jmcburney(at)pobox.com
PostPosted: Wed Jun 04, 2008 7:55 am    Post subject: spark plugs and rain Reply with quote
My dad used to talk about water injection on his Ford Model T.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
ashontz
PostPosted: Thu Jun 05, 2008 3:40 am    Post subject: Re: spark plugs and rain Reply with quote
Larry, the plugs themselves aren't a problem. More likely any problem spots would be water somehow making it's way into the distributor or under the boots of the wires. The distributor should have a nice o-ring under the cap, should come from the factory tht way, as far as the pulg wire boots, I believe AutoZone sells stuff, some sort of gel, that you can put on the plug tips before installing the wire to help keep them from getting dirty and corroded. I've had old distributors in my pickup that have given me trouble on rainy days (I guess it was just the humidity or maybe some water managed to splash up from the street). Anyway, car ran fine after it warmed up long enough to heat the distributor a bit, but ran rough up till that point. The problem was a worn corroded looking cap contacts as well as rotor contact, that thing was all corroded looking too. Granted, that was just age, but it did act up when it was wet out, and probably how it managed to age rapidly to begin with. I changed the wires for good measure at the time too. Anyway, short answer, water can affect the ignition system, but less of a chance if you have the boots and cap sealed well, the plugs themselves should be fine, but I believe there's a product you can apply to the threads to help out too. Just put it on your list of things to check once a year, pull the cap and check out the rotor and cap contacts and plug boots. I'd imagine you'd be pulling the plugs once a year anyway to see what's going on inside.
PostPosted: Thu Jun 05, 2008 9:01 am    Post subject: spark plugs and rain Reply with quote
One of the big problems (at least in cars) for water in the distributor, is that the vapor from the water in the muffler gets inside the dist cap and make an electric arc. will not get the spark to the spark plugs. Some kind of spray or something betwen the distributor and the Dist cup needed to prevent this.
Saludos
Gary Gower
--- On Thu, 6/5/08, ashontz <ashontz(at)nbme.org> wrote:
[quote]From: ashontz <ashontz(at)nbme.org>
Date: Thursday, June 5, 2008, 7:40 AM
[quote]--> Zenith-List message posted by: "ashontz" <ashontz(at)nbme.org> Larry, the plugs themselves aren't a problem. More likely any problem spots would be water somehow making it's way into the distributor or under the boots of the wires. The distributor should have a nice o-ring under the cap, should come from the factory tht way, as far as the pulg wire boots, I believe AutoZone sells stuff, some sort of gel, that you can put on the plug tips before installing the wire to help keep them from getting dirty and corroded. I've had old distributors in my pickup that have given me trouble on rainy days (I guess it was just the humidity or maybe some water managed to splash up from the street). Anyway, car ran fine after it warmed up long enough to heat the distributor a bit, but ran rough up till that point. The problem was a worn corroded looking cap contacts as well as rotor contact, that thing was all corroded looking too. Granted, that was just age, but it did act up when it was wet out, and probably how it managed to age rapidly to begin wit! h. I changed the wires for good measure at the time too. Anyway, short answer, water can affect the ignition system, but less of a chance if you have the boots and cap sealed well, the plugs themselves should be fine, but I believe there's a product you can apply to the threads to help out too. Just put it on your list of things to check once a year, pull the cap and check out the rotor and cap contacts and plug boots. I'd imagine you'd be pulling the plugs once a year anyway to see what's going on inside. -------- Andy Shontz do not archive CH601XL - Corvair www.mykitlog.com/ashontz Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186341#186341 [quote][b]
paulrod36(at)msn.com
PostPosted: Fri Jun 06, 2008 12:11 pm    Post subject: spark plugs and rain Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> ooooookaay, so it should be all right to fill your bathtub with distilled, demineralized water, jump in, and then drop your (plugged in) hair dryer in with you? Just checkin'.........
Paul Rodriguez
DO NOT ARCHIVE
kmccune
PostPosted: Fri Jun 06, 2008 12:25 pm    Post subject: Re: spark plugs and rain Reply with quote
Some of the machines I work with have Vac tubes running 12KVDC (at) 4-5 amps on the plate, it is directly cooled with distilled water from your friendly neighborhood, convenience store. The pump that circulates it is well grounded and made of conductive material. So ya, go ahead, if it turns your crank.
Kevin
Dorothy McCune
carlossa52(at)gmail.com
PostPosted: Fri Jun 06, 2008 12:34 pm    Post subject: spark plugs and rain Reply with quote
That's what theory says.
But I'll let you jump in first...
Carlos
On 6/6/08, paulrod36(at)msn.com <paulrod36(at)msn.com> wrote:
[quote] ooooookaay, so it should be all right to fill your bathtub with distilled,
Paul Rodriguez
DO NOT ARCHIVE
psm(at)att.net
PostPosted: Fri Jun 06, 2008 12:49 pm    Post subject: spark plugs and rain Reply with quote
Actually, the hair dryer and bath tub make very poor weapons. Only
in Hollywood is such a thing a way to kill someone. Even if there
were a real danger from this silly action, the GFI power outlet
required in bath rooms would prevent a significant amount of
electrical shock for the bather.
Paul
Paul Rodriguez
DO NOT ARCHIVE
kmccune
PostPosted: Fri Jun 06, 2008 7:16 pm    Post subject: Re: spark plugs and rain Reply with quote
We actually measure the conductance of the distilled water, it goes up with time, dissimilar metals and bad luck..... But it starts at around 2uS/cm.
Not theory at all.
Kevin
Dorothy McCune
Goto page 1, 2  Next
Page 1 of 2
