		lwhitlow
  Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
				 Posted: Sun Jun 08, 2008 1:27 pm    Post subject: Nose Wheel Bearings Questions |
				All
 I've been working on the nose gear and pulled the Matco Wheel out for a test fit (kit is from Nov 2005)
 The included bearings have the name Azusua on them and are stamped made in China.
 Any issues with these wheels / bearings that anyone would care to comment on??  And while we're at it, What grease should I pack them with and how often should I repack them?
 Thanks in Advance
 Larry
 601XL
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Jun 08, 2008 3:24 pm    Post subject: Nose Wheel Bearings Questions |
				Larry,
 I've never heard or read anything that cast doubt on Azusua Bearing
 quality.  I thought the bearings would be sealed each side and not
 require any grease.
 If you need to inspect these every year (without seals), it's probably a
 good idea to repack them at annual inspection with any good white
 lithium grease.
 lwhitlow wrote:
  All
  Thanks in Advance
  Larry
  601XL
  http://forums.matronics.com/viewtopic.php?p=186858#186858
		Aerolitellc(at)aol.com Guest
				 Posted: Mon Jun 09, 2008 12:13 am    Post subject: Nose Wheel Bearings Questions |
				Ours fell apart after about 10 hours (couldn't find any of the bearings) if  it is the same one piece bearing. If you have the small axle I would call zenith  and upgrade to the bearings that comes with the new kits. They  use thicker  axles and better bearings and I think the axle is only like 8 bucks.
  Jeff
   	  | Quote: | 	 		  All
 Thanks in  Advance
 Larry
 601XL
 Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
		jmcburney(at)pobox.com Guest
				 Posted: Mon Jun 09, 2008 6:46 am    Post subject: Nose Wheel Bearings Questions |
				Hi, Larry (McFarland) and List,
 I've always used wheel bearing grease to pack this type of bearing, mostly
 on automotive front wheel bearings.  They definitely get more use than
 airplane wheels.  Seems to me that white lithium might break down sooner.
 What say you?
 Blue skies and tailwinds
 Jim
 CH-801
 DeltaHawk diesel
 Augusta GA
 90% done, 90% left
				 Posted: Mon Jun 09, 2008 7:35 am    Post subject: Nose Wheel Bearings Questions |
				Hi Jim,
 Lithium is additive to lubricating grease to raise temperature tolerance
 and maintain viscosity.  It doesn't absorb water and is non corrosive
 unlike
 some general products sold as wheel and bearing grease.  I don't think
 the stuff breaks down if you clean and repack with any regularity.
 I check mine at annual inspection, but my bearings are sealed both
 sides, so I will be replacing the bearings within a 5 year period.
 Larry McFarland at www.macsmachine.com
 Jim McBurney wrote:
  What say you?
  Jim
  CH-801
  DeltaHawk diesel
  Augusta GA
  90% done, 90% left
		ronlee
				 Posted: Mon Jun 09, 2008 10:20 am    Post subject: Re: Nose Wheel Bearings Questions |
				I think you are looking at a sealed ball bearing as that is what my 701 has and not a tapered bearing the would need to be preloaded. If you preloaded the sealed ball bearings (pinch the bearings together) they will fail soon. When all is in place you should have some end play to each side on the wheel. If you don't and it is preloaded as you would a tapered roller bearing it will certainly fail soon. Do not preload the mains either, give them a bit of space. A little space will allow the brake pads to be pushed back from the rotars a bit  which will ease the friction on the pads and allow a more free wheeling on take off, thats good! Alot of this was gone through some time ago. I'm sure it is in the archives somewhere.
 Ron Lee
  _________________ Ron Lee
Tucson, Arizona |
		graeme(at)coletoolcentre. Guest
				 Posted: Mon Jun 09, 2008 1:33 pm    Post subject: Nose Wheel Bearings Questions |
				Straight sealed bearings will fail with side load.
 I modified my wheels by making a spacer to keep the inner part of the
 bearing in the correct position. this would also spread the side load over
 both bearings,
 With out a spacer the correct tension is guess work.
 Graemecns
		freonmen(at)verizon.net Guest
				 Posted: Tue Jun 10, 2008 5:17 pm    Post subject: Nose Wheel Bearings Questions |
				Hay U all,I just went through this bearing  problem on my 601,I had  the 5/8 roller bearing,I replaced it with a 5/8 tapered, much less friction.  Qestion call Pat 941 270 7802
  [quote]   ---
				 Posted: Wed Jun 11, 2008 5:42 am    Post subject: Nose Wheel Bearings Questions |
				Hi Pat,
 Do you have a number for that tapered roller bearing?
 pat & lyn wrote:
  	  | Quote: | 	 		   Hay U all,I just went through this bearing  problem on my 601,I had
