rowil(at)clara.net Guest
Posted: Tue Jun 10, 2008 7:23 am Post subject: cockpit module trimming |
Thanks to all those who responded to my rudder pulley access holes query.
Now, here's the next one: The manual says trim to the joggle line at
the front end of the cockpit module. Mostly that's fine, the tiny
line on th einside of the CM follows the edge of the joggle across
the rudder pedal support and up the sides of the tunnel. However,
along the top of the tunnel there is a discrepancy. The joggle is
about 20mm down from the edge as supplied, then the tiny line is
about 20mm below that again. If I trim to the line rather than the
joggle, there will still be abut 30mm of flange left, and that will
be about the same width as up the sides of the tunnel where line &
joggle coincide. The drawing appears to show that the flange is about
the same width all around the tunnel.
Roger at the factory says he thinks (HE THINKS) that the line is
where to cut, but I'd welcome a second opinion. (I'd prefer not to
have a flange 20mm too narrow!) Anyone remember checking this with
the factory while Andy or Neville were still there?
regards
Rowland
| Wilma & Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
