SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Fri Jun 13, 2008 2:48 pm Post subject: Painted Prop Tips vrs Prop Balance |
I am considering painting the outside 2 to 3 inches of my prop to make it more visible while running. I have a Warp Drive prop and would probably paint white tips on it with just a can of regular white spray paint. Any chance of changing the balance of the prop? Good idea or bad?
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Fri Jun 13, 2008 3:03 pm Post subject: Re: Painted Prop Tips vrs Prop Balance |
In the past I have used spray paint (or clear coat) to balance several props. Yes, It can change your balance...how much??? It's really hard to get the same amount on each blade. Also, after it drys it weighs a little less. A two blade prop is more prone to small changes in balance than is a three blade. ...Not sure what you have.
Also, adding anything to the ends of the prop can make a big change in balance! I like the idea of painted tips! Much more visible...but only paint the front!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
SkySteve
Posted: Fri Jun 13, 2008 3:14 pm Post subject: Re: Painted Prop Tips vrs Prop Balance |
My Warp Drive is a 3 blade. Sounds like it might not be a good idea for a novice like me to be painting a prop.
Huntsville, UT
Jim Shumaker
Posted: Fri Jun 13, 2008 5:44 pm Post subject: Painted Prop Tips vrs Prop Balance |
I paint the outer tip of the prop on the back for visibility. The front I paint as needed for repairs. I use yellow because it is visible and matches my plane. Balance with a lawnmower blade balancer, available at Sears.
Jim Shumaker
_________________ Jim Shumaker |
rjdaugh
Posted: Fri Jun 13, 2008 5:55 pm Post subject: Painted Prop Tips vrs Prop Balance |
Steve,
I checked with manufacturer about this and they said it was unlikely that I
would make them out of balance if I did all three blades the same. I did do
a couple of inches on the back of the blade too. I think it is a good
safety move.
Randy Daughenbaugh, N10NH
Black Hills of South Dakota, - Near Mount Rushmore
Home Strip, Grass Room in Hangar for visitors
Series 5/7 (7 Firewall Forward) 912S, Warp Drive Taper Tip
Gross Weight 1320 lbs, Flying since November 2004
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
thesupe(at)hotmail.com Guest
Posted: Fri Jun 13, 2008 6:38 pm Post subject: Painted Prop Tips vrs Prop Balance |
A couple of months ago, I had the prop off my Jabiru powered Avid (64" two blade) and checked the balence of the prop by running a 1" rod through the center hole that was set on two thin pieces of steel. (the thinner the better, less friction) and when I put a piece of paper that was 1/4" X 1" on the end of the prop, it immediatly dropped on that side. Just shows how easy it could be to balence a prop, cause that paper didn't weigh much. Jim Chuk Avids, Kitfox 4 Mn
[quote] From: rjdaugh(at)rapidnet.com
Subject: RE: Painted Prop Tips vrs Prop Balance
Date: Fri, 13 Jun 2008 19:55:23 -0600
--> Kitfox-List message posted by: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Steve,
safety move.
FlyboyTR
Posted: Fri Jun 13, 2008 7:05 pm Post subject: Re: Painted Prop Tips vrs Prop Balance |
Jim,
I personally do not recommend painting the back of the prop. In doing so, the prop now becomes visible to the pilot and creates a white or yellow ring in the visual field. In general terms, the back of the prop should be black. The color needs to be on the front. I had the opportunity to fly behind a new composite prop that was all white. After about 2 hours of looking through this white ring I suggested to the new owner that he paint the back of the prop black. Now the prop is virtually invisible to the pilot...and no more headaches and tired eyes.
When you paint your three blade prop, just try to apply the same amount of paint to each tip. Don't forget to remove your tape before the paint dries! Let us know how it turns out!
Travis
| Jim Shumaker wrote: | I paint the outer tip of the prop on the back for visibility. The front I paint as needed for repairs. I use yellow because it is visible and matches my plane. Balance with a lawnmower blade balancer, available at Sears.
Jim Shumaker
Mobile, AL
ADI-II Autopilot
Guy Buchanan
Posted: Fri Jun 13, 2008 9:09 pm Post subject: Painted Prop Tips vrs Prop Balance |
At 03:48 PM 6/13/2008, you wrote:
| Quote: | I am considering painting the outside 2 to 3 inches of my prop to
I painted the forward faces of my prop white, with red tips
with black pin striping. I was careful to paint the same, but
dynamically balanced after anyway. The balance turned out to be very
close so I don't think you'll have a problem. It's a good idea for
safety, but as was mentioned elsewhere, don't paint the back of the
blades, it makes them visible from the cockpit.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Sat Jun 14, 2008 2:11 am Post subject: Painted Prop Tips vrs Prop Balance |
I've got a clear-coated wood prop and when I land with the sun low
and behind me, it's a bitch to see through that reflective prop
circle. I've thought about painting the backside black, but have
hesitated because of the necessity of balance afterward....it's one
thing to touch up the tips as I just did, but painting the whole
prop, even just the backside would almost certainly call for a
balance job. I've done model airplane props, and if you paint one
tip, it will swing radically to one side (of the balance jig) until
dry, then it will swing less actively. This is to say the dried paint
weighs less, but you all knew that. I've done balancing on several
large fan blades, but haven't tried a prop like mine yet. I guess
I'll have to rig up a larger jig and check my prop now that it looks
like the "chunk" is liable to stay on. Besides, I need to earn my
Airplane Propellor-Balancing Merit Badge.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/528 hrs
On Jun 14, 2008, at 1:05 AM, Guy Buchanan wrote:
very close so I don't think you'll have a problem. It's a good idea
for safety, but as was mentioned elsewhere, don't paint the back of
the blades, it makes them visible from the cockpit.
Guy Buchanan
San Diego, CA
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Sat Jun 14, 2008 3:50 pm Post subject: Painted Prop Tips vrs Prop Balance |
I had a three blade Ivo IFA on my 582. It had the stainless steel tapes to
protect the leading edge. I did find it would glint in the sun when I was
flying with the sun behind me. Rather than have a prop all white I think
the two white stripes near the tips of the props
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
