Z13-8b Brown Out Relay Question ?
Bill Schlatterer
PostPosted: Fri Jun 13, 2008 7:11 pm    Post subject: Z13-8b Brown Out Relay Question ? Reply with quote
Bob, I am having a little trouble understanding the charging circuit for the 7ah battery in Z13-8b. What I see is that the normal E-Bus Alt Feed path is in place to activate the Aux Bat if needed to the Endurance bus. The Brown-Out Battery Relay is normally energized by the starter circuit which disconnects the Aux Bat while starting but leaves it in the circuit for normal charging at all other times.
What I don't understand is why you would use a S701-4 relay instead of a simple D25 steering diode which has no moving parts? Isn't this the same thing we are doing with the diode between the E-Bus and the Main Bus (allowing a one way current flow)? Is there some advantage in using the relay over the diode in this "brown-out battery relay" position?
[url=http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf]http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf[/url]
Thanks Bill S
7a finishing
Z13/8/32/35
nuckolls.bob(at)cox.net
PostPosted: Sat Jun 14, 2008 7:49 am    Post subject: Z13-8b Brown Out Relay Question ? Reply with quote
<http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf>http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8B(BrownOutBattery).pdf
The relay has essentially zero voltage drop across it.
The silicon rectifier has about .8 volts you could
use a Schottky diode for about 0.5 volts depending
on your e-bus loads. The design rationale is that
the brown-out support battery get the recharging
benefit from full bus voltage for normal operations.
On the other hand, if you're not counting on the
brown-out support battery as part of the endurance
capacity, perhaps allowing the brown-out battery
to live in the airplane at reduced capacity fits
your design goals.
I have it on my list of things to do in the lab
to measure the difference in state of charge for
small SVLA batteries when the recharge levels are
0.5 and 0.8 volts below the main bus.
In any case, I'm sure it's not a really big deal
if you'd like to substitute a diode, particularly
a Schottky device for the relay. The reason I
suggested the relay was because I could not
quantify the difference in state of charge based
on good data. The "easy" way out was to suggest
a switching device that did not put the battery's
state of charge in question.
( -Thomas Paine 1776- )
PostPosted: Sat Jun 14, 2008 5:19 pm    Post subject: Re: Z13-8b Brown Out Relay Question ? Reply with quote
Bill S
Another advantage of using a relay is that the power can be interrupted close to the source, a nice feature to have in case of smoke in the cockpit. One could think of the relay as a mini battery contactor. Only a small size wire is required between the relay coil and cockpit switch. Also, a diode would keep the E-Bus always hot. With a diode, each load on the E-Bus would have to be shut off individually at the end of the flight to prevent the batteries from running down.
Joe Gores
Joe Gores
Bill Schlatterer
PostPosted: Sat Jun 14, 2008 7:17 pm    Post subject: Z13-8b Brown Out Relay Question ? Reply with quote
Thanks Bob, I have the diode on a fused circuit going to the main bus so
that it charges when the master is on but doesn't drain if it's off. Didn't
consider the reduced voltage through the diode as being insufficient to keep
the smaller battery "fully" charged. I do get a .6 volt drop across the
D25.
Thanks for posting the diagram, made me think about it again.
Thanks Bill S
7a finishing
PostPosted: Sun Jun 15, 2008 3:45 am    Post subject: Re: Z13-8b Brown Out Relay Question ? Reply with quote
Bill,
Oops, my mistake. I thought you were talking about the Alternate Feed Relay and my first reply was in reference to that.
Joe
Joe Gores
