Posted: Sun Jun 15, 2008 5:19 pm Post subject: Question on EGT on Jab3300 |
Question to the Engine geniuses on this site. My CHTs are all reading great, between 267 and 280 on all 6 cylinders on my Jabiru.
Number 5, the right rear most side has an EGT of 1400 and all other EGTs are reading 1300 to 1320. so they read as follows
EGT 1310
1320
1315
1315
1400
1320
Why are the CHTs running great but the 5th cylinder EGTs running hoter by 100 degrees than rest?
Anythoughts?
Juan Vega Jabiru 3300
psm(at)att.net Guest
Posted: Sun Jun 15, 2008 6:16 pm Post subject: Question on EGT on Jab3300 |
Hi Juan,
It may be that your #5 jug is running hotter or it may be the sensor
is measuring it differently from the other ones. Is there a way you
can swap sensors between 3 and 5 and see if the hot jug moves? If it
does, you know it is a measurement issue rather than something about
the engine itself.
Fortunately, I think the difference you are seeing is not a
problem. It may just wind up being one of those curious things that
you never figure out.
Have fun,
Paul
XL getting close to done
| Quote: | Number 5, the right rear most side has an EGT of 1400 and all other
EGT 1310
1320
1315
1315
1400
1320
Anythoughts?
jetboy
Posted: Sun Jun 15, 2008 6:19 pm Post subject: Re: Question on EGT on Jab3300 |
Juan,
aside from probe placement being effectively different from the point of view of the gasflows, if you have a cylinder thats leaner than others and is near its peak EGT or running on the lean side of peak, the CHT on that cyl. will be less than for another cyl. running on the rich side of peak EGT.
With the bing carb there is not much you can do other than rotate the carb to balance the mixtures (bottom of carb rotates towards the leaner cyl bank by 5 to 10 degs) or lag the #5 pipe with insulation if they are in a cold airstream. Also check there is no intake leaks or cyl. head to barrel leak.
Ralph
_________________ Ralph - CH701 / 2200a |
Posted: Mon Jun 16, 2008 3:37 am Post subject: Question on EGT on Jab3300 |
thanks, i think you are on to something. I am switching the sensors to check it out. also doing a pressure differential test just in case.
thanks, i am going to do a pressure differential test to check for leaks.
