		michaega(at)verizon.net Guest
				 Posted: Mon Jun 16, 2008 12:56 pm    Post subject: fit up of Fire wall bent idetations to cowl bonnet? |
				I plan on having a simple set up to remove the cowl bonnet my model 7.  The originally kit  came with a permanent sealer to fill the gaps left by shaping of the top round end of the firewall that fit up against the bonnet. Is there a descent rubber seal that can fill the wide openings but still be squeezed thin?
  George
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		darinh
				 Posted: Mon Jun 16, 2008 1:56 pm    Post subject: Re: fit up of Fire wall bent idetations to cowl bonnet? |
				George,
 The question becomes...do you want a fire retardant material to fill the gap?  I looked and looked for something that would work and was fire retardant but the only thing I could come up with was RTV.  I took some packaging tape and applied it to the underside of the boot cowl and then filled the gap with RTV and let it cure.  It worked pretty good but I didn't like the looks of it so I peeled it off and ended up with simple weather stripping.  It isn't fireproof or even resistant but my cowl will burn off in a fire anyway.  I thought about using the silicone tape they use for baffling but didn't want to go to the effort to make it work.  Let us know if you fine a compressible foam sealant that is fire resistant.  Good Luck.
  _________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
		dwparker
				 Posted: Tue Jun 17, 2008 4:08 am    Post subject: Re: fit up of Fire wall bent idetations to cowl bonnet? |
				I used "Fiberfax" insulation. You can buy it from Aircraft Spruce (part number 05-02678). I attached it to the firewall flange with red high temp RTV. It is very thin so I was able to put it on after I drilled the mounting holes. It is good for 2300 degrees so the boot cowl will go long before this seal.
 Dana W. Parker
 N474DP
 Series 7 in phase one testing
  _________________ Dana Parker
N474DP
Kitfox Series 7 w/912S
First Flight 12/26/07 |
