		dlm46007(at)cox.net Guest
				 Posted: Wed Jun 11, 2008 7:29 am    Post subject: SB |
				I spoke with Scott R  at Vans and the pictures of the actual crack should be on their site by  tomorrow. I don't believe that the diagram as previously reported is  correct, as the flat version of the part would actually have  two tabs at the outboard top edge. My understanding is that the crack would be  in the tab that is riveted to the longeron.
		Dsyvert(at)aol.com Guest
				 Posted: Wed Jun 11, 2008 1:39 pm    Post subject: SB |
				I've been thinking about doing something to this area for some time. What I  had decided to do, but had not done yet, is to put a mirror image angle on the  aft side of F-1010 like on the forward side. I would then have two angles with a  total of four bolts to the longeron. Not knowing all the details of the fix,  they seem to  treating a symptom and not the cause. It seems that  an additional angle would reduce twist and also strengthen the  attachment. I am planning to do this in addition to Van's SB. I would like to  hear what others think.
      In addition, I had already planned to add another  angle at the aft portion of where the VS attaches to the tailcone.
  Dave Syvertson
  40625 (fuselage)
 Vote for your city's best dining and nightlife. City's Best 2008.
		Dave(at)AirCraftersLLC.co Guest
				 Posted: Wed Jun 11, 2008 2:15 pm    Post subject: SB |
				I just  finished looking at our plane.  No cracks after 141 hours.  The  inspection is easy with the emp fairing off.  I'm not going to pull the  tail off unless more people find cracks or unless there's a better  reason.
   Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
  www.AirCraftersLLC.com
				 Posted: Wed Jun 11, 2008 3:09 pm    Post subject: SB |
				agreed. The aircraft I  would like to hear about are those who flew with a misrigged trim and  experienced twisting force on opposite halves of the elevator.
  33 hours and obviously  not enough time to crack?
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave  Saylor
 Sent: Wednesday, June 11, 2008 3:16 PM
 To:  rv10-list(at)matronics.com
 Subject: SB
   Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
				 Posted: Wed Jun 11, 2008 5:33 pm    Post subject: SB |
				Check the vans site  ; the service bulletin now includes pictures of the crack and installation of  the doublers. Their original description  of a crack in the tab is  incorrect. see the pictures
				 Posted: Wed Jun 11, 2008 5:55 pm    Post subject: SB |
				Curious that the  crack appeared on the left side. Seems like that is the same side that a mis  rigged trim setup would cause twisting of the elevator halves in flight under  some circumstances.
		wayne.e(at)grandecom.net Guest
				 Posted: Thu Jun 12, 2008 3:42 am    Post subject: SB |
				I and another RV10, both of us flying, on my field  performed the SB yesterday and found no cracks. As Dave said it's fairly easy to  perform the inspection with the emp fairing off, with a flex mirror and flash  light. I have about 125 hours and I think the other 10 has about 60 hours. I  plan on waiting on pulling the tail off for now and do like Dave and continue  the inspections.
  Wayne Edgerton N602WT
              Time:      03:15:35 PM PST  US            From:      "Dave Saylor" <Dave(at)AirCraftersLLC.com (Dave(at)AirCraftersLLC.com)>            Subject:      SB
       Dave Saylor
        AirCrafters LLC
       140 Aviation  Way
       Watsonville, CA
        831-722-9141
       831-750-0284  CL
		johngoodman
				 Posted: Thu Jun 12, 2008 4:05 pm    Post subject: Re: SB |
				Perhaps it's time to take another look at why the RV-10 even needs two trim tabs....
  _________________ #40572 Phase One complete in 2011 |
				 Posted: Sun Jun 15, 2008 10:36 am    Post subject: SB |
				33 hours no cracks  N46007
		GenGrumpy(at)aol.com Guest
				 Posted: Sun Jun 15, 2008 5:43 pm    Post subject: SB |
				N184JM
  65 hrs and no cracks.
  Great borescope tool is the SeeSnake offered by Home Depot for under  $200!
  grumpy
				 Posted: Mon Jun 16, 2008 7:59 am    Post subject: SB |
				N256H503 Hrs and no cracks
  Jesse Saint
 Saint Aviation, Inc.
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Jun 15, 2008, at 9:40 PM, GenGrumpy(at)aol.com (GenGrumpy(at)aol.com) wrote:
 [quote]  N184JM
  grumpy
   	  | Quote: | 	 		  http://www.matronics.com/Navigator?RV10-List
  | 	  [b]
				 Posted: Mon Jun 16, 2008 3:28 pm    Post subject: SB |
				as an example of why  we need for info about the cause of the damage to 220RV.
  I just received  ,today, a new SB for my Glastar. In the SB ; the writer states that all  counterweights for the elevator must be inspected visually for cracks in the  aluminum where the screws hold the counterweight in place. In addition it says  that these counterweights must be inspected every annual. Now the fiberglass  tips have never been off my Glastar and the building instructions have them  installed with blind rivets. Big change.................... Now the rest of the  story. The only airplane to experience a problem was a "two weeks to taxi "  build that was being shipped from the factory to the builders address. The  elevator was stored/transported by truck vertically without the fiberglass  tip in place. Damage occurred...Then somebody decided at the factory to issue an  SB to all flying aircraft. what a  crock.
		sam(at)fr8dog.net Guest
				 Posted: Mon Jun 16, 2008 6:11 pm    Post subject: SB |
				N540MR
  120 hrs and looks like new, no cracks!
  Jesse Saint wrote: [quote]N256H   503 Hrs and no cracks
           Jesse Saint
    Cell: 352-427-0285
    Fax: 815-377-3694
        	  | Quote: | 	 		            N184JM
      grumpy
  | 	   [b]
		Fixitauto(at)AOL.COM Guest
				 Posted: Tue Jun 17, 2008 4:46 am    Post subject: SB |
				Rick so how many drilled out and replaced rivets will this bring your total  up to?
 Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
				 Posted: Tue Jun 17, 2008 5:06 am    Post subject: SB |
				LOL....well these will be the first ones for real, I messed  up one on my practice kit...except of course the ones for the Vertical Stab SB and all of Bob Kauffmans I helped drill out for him. ...I knew that crack about never having to drill one out would come back sometime!! Thanks for putting a big smile on my face to start the day.
 Rick Sked
 40185
		bob.kaufmann(at)cox.net Guest
				 Posted: Tue Jun 17, 2008 5:45 am    Post subject: SB |
				ROFLMAO……Every time I go over to Rick’s its like walking on a floor covered with little bitty aluminum donuts, wonder why they are all over the place.
 Bob Kaufmann
 N104BK, In the air, just a couple of inches.
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
  Sent: Tuesday, June 17, 2008 5:59 AM
  Subject: Re: SB
 Rick Sked
 40185
				 Posted: Tue Jun 17, 2008 7:20 am    Post subject: SB |
				Those are not drilled out rivets...they are microstop shavings.
 Rick Sked
 4015
		dougpflyrv(at)gmail.com Guest
				 Posted: Tue Jun 17, 2008 1:17 pm    Post subject: SB |
				N372RV - 117 HRS. LOOKS GOOD AS NEW.
 DOUG PRESTON
 BHM
 On Mon, Jun 16, 2008 at 9:05 PM, Sam <sam(at)fr8dog.net (sam(at)fr8dog.net)> wrote:
 [quote]         N540MR
