Posted: Thu Jun 19, 2008 4:04 pm Post subject: Randolph County Airport Fly-in Newspaper Article |
Kolbers,
I was interviewed for the local newpaper during the fly-in. The article
came out today. I asked for an email copy of it and I put it up at:
http://www.thirdshift.com/jack/firefly/firefly141.html
I thought you may enjoy it.
Jack B. Hart FF004
Winchester, IN
beauford173(at)verizon.ne Guest
Posted: Thu Jun 19, 2008 4:25 pm Post subject: Randolph County Airport Fly-in Newspaper Article |
Brother Hart:
Best thing I've read on the internet in a coon's-age...
The part she wrote about "spinning around" was right on... I can
identify with it...
Good on 'ya... keep 'er flying...
Beauford
FF 076 - N173BW
Brandon, FL
Posted: Fri Jun 20, 2008 2:14 am Post subject: Randolph County Airport Fly-in Newspaper Article |
<<Hart says the thought occurred to him that he could fall out of his
plane>>
Now there is a guy who is really switched on! Falling out of my airplane...
well.. wonder why I never thought of that.
.<< So he got a better seatbelt to replace the racing buckle he first had.
He saw just what he needed at Toys R Us,>>
So he went to the shop and bought a safety harness that was rated to stop a
5 year old child from going through the windshield at 30 mph. I hope it
never has to stop a full grown man from being thrown out of his plane at 70
mph when it hits a tree
The best bit was that the plane `was made of Dacron`. Great !. Just like an
umbrella with no frame. Presumably you can roll it up in a ball and put it
in your pocket.
Cripes. I said in my post that all reporters write b********s. Even when
you carefully explain everything they will write it up full of mistakes.
Worse they may have an agenda of their own
.We were unfortunate to have a light aircraft written off at a local strip
I sometimes use. The pilot missed the strip, tried to put it down in an
adjacent field and rolled it into a ball.
Reporters, newspaper and TV, descended on the site and proceeded to question
everyone in the area. The main thrust of all their questions was " Doesn`t
it scare you with these little planes flying overhead all the time" All they
wanted to do was dump on someone, get the locals to complain about the noise
etc.,.
Luckily we are very close, actually within the MATZ, of Lyneham which
operates the largest fleet of C130 outside the States. All the neighbors
said that the C130`s were much more of a problem than the planes operating
out of this little strip.
You gotta watch the press. Even if you write the report yourself they will
edit it so that it reads wrongly.
We are all enthusiastic about our sport and like to spread the word and its
a bit of an ego boost to have your name attached to a report. However, over
the years I have come to believe that we are best served by keeping our
heads down and keeping the media out of the picture if we possible can. If
you want to spread the word talk to your friends NOT the press.
Cheers
Pat
Posted: Fri Jun 20, 2008 4:45 am Post subject: Randolph County Airport Fly-in Newspaper Article |
At 11:11 AM 6/20/08 +0100, you wrote:
Pat,
At my age ego has nothing to do with it. This is a rural area, and just
about everyone knows everyone else. The New Gazette is a small local
newspaper that reports everything that happens in the county. If I had
refused to talk to the reporter, it would have been in the paper "Jack Hart
refuses to talk about ultra-light" Ms. Aukerman, locally, is well known for
"not getting it right". I was pleasantly surprised about how well she did
do with the article. In questioning her, I found she hates flying, but she
is a word smith and wrote an article that makes sense to her and most of the
other people in the county. Those who fly will get a chuckle about what she
wrote. Those who do not fly will find it interesting from the normal fare
of county, town, farm, and weather news.
We must not feel superior because we can fly. We should feel compassion for
those who have never had the experience.
Jack B. Hart FF004
Winchester, IN
Ricochet
Posted: Fri Jun 20, 2008 9:14 am Post subject: Randolph County Airport Fly-in Newspaper Article |
Jack,
I enjoyed "your" article, but it piqued my interest. What Italian
engine are you using, and what has been your experience with it,
performance and reliability? Also, what is the third engine and of
course why.
Thanks again,
Jerry
Posted: Fri Jun 20, 2008 9:49 am Post subject: Randolph County Airport Fly-in Newspaper Article |
At 10:11 AM 6/20/08 -0700, you wrote:
Jack,
course why.
Jerry,
I have 161 hours on a Simonini Victor 1+, 382 cc, one cylinder, water
cooled, reed valve engine with dual ignition and electric start. Although
they say it is more powerful than the Rotax 447, I do not believe this to be
the case. It burns 1.5 to 1.0 gph less than the Rotax 447 on my FireFly.
It is one sweet engine. If you would like more info on the engine, it can
be found at:
http://www.thirdshift.com/jack/firefly/firefly.html - and:
http://www.thirdshift.com/jack/firefly/fireflyindex.html
The reason for changing to a lower hp third engine, is to reduce fuel
consumption, drag, and overall weight. I will give up some climb rate, but
by going down in hp and weight, I can fare in more things and reduce drag
and still cruise just as fast. Since I have moved to east central Indiana,
the winters are more severe, and I would like to fly with a full enclosure
and remain 103-7 compliant. I purchased an MZ34 engine three + years ago,
and then got involved with moving etc. I took it out of storage a couple of
months ago and am trying to get the muffler mounted. It will hang inverted
off the rear of the fuselage. No propeller extension will be required.
Using electric start, and discarding the pull start, it should lower empty
weight by 40 to 50 pounds. This engine is air cooled reed valve engine of
27 hp.
In general, reed valve engines are smoother running and use less fuel than
piston ported engines. The big problem is carburetion and getting the Bing
tuned for your engine aircraft set up.
If you have any additional questions please let me know.
Jack B. Hart FF004
Winchester, IN
Posted: Fri Jun 20, 2008 10:04 am Post subject: Randolph County Airport Fly-in Newspaper Article |
those who have never had the experience.>>
Nicely put Jack.
As far as the egotrip is concerned. I don`t think age has much to do
with.it. I shall be 79 in August and I must confess to a little frisson of
pleasure when an article or a letter which I have written is good enough to
be published.
When I bust my leg hang gliding, not an unusual occurence in the sport, the
local press made their usual rubbish write up of it. While I was laid up
with my leg in plaster I wrote my own account for Sailplane and Gliding, the
main gliding magazine here
It so happened that I turned up at my next Rotary Club meeting to be met
with "The speaker has not turned up, can you talk about your crash" `Crash`
you will note , not `accident`.
Of course I was lucky. I had the article which I had just written clear in
my head. I also had a plaster cast on and was using crutches. Therefore I
found myself holding forth on how safe the sport was while surrounded by the
evidence that it obviously was not. The talk went well and by chance there
were several Rotarians from other Rotary Clubs in the audience. In due time
they reported to their Clubs that they had enjoyed my talk and as Rotary
Clubs are always short of speakers invitations to speak at other Clubs
rolled in.
In the end I think I did about 20 or so repeat performances, and didn`t have
to buy a dinner for ages. By the time of the last talk of course the
crutches were gone and the plaster cast but I learned the usefulness of
using props when speaking to a crowd.
Sailplane and Gliding also deemed my article worthy of publication and that
produced a few comments in the letter columns from readers worldwide.
Its an ill wind etc..
Cheers
Pat
Ricochet
Posted: Fri Jun 20, 2008 1:19 pm Post subject: Randolph County Airport Fly-in Newspaper Article |
Jack,
Thank you for your informative reply and the links to your web site.
It has the best analysis of anything I've seen.
Jerry
On Jun 20, 2008, at 11:47 AM, Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
> Jack,
> course why.
Jerry,
Although
this to be
FireFly.
it can
be found at:
rate, but
reduce drag
Indiana,
enclosure
years ago,
couple of
inverted
required.
lower empty
engine of
27 hp.
fuel than
the Bing
Jack B. Hart FF004
Winchester, IN
