orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Mon Jun 30, 2008 6:17 am Post subject: Ramp to belly distance? |
Can someone publish the ramp (garage floor) to belly distance with the gear on? It would be really good to get the distance both with the engine on and before it is installed.
I am in the garage with the canopy top fully trimmed but not bolted down. Standing back and looking at the project this weekend I started looking at the distance from the top to my garage door opener which also translates to what I will need for clearance rolling out of the door.
I am trying to get as much of the wiring complete before I install the gear and don’t want to get surprised and stuck.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
millstees(at)ameritech.ne Guest
Posted: Mon Jun 30, 2008 7:04 am Post subject: Ramp to belly distance? |
Gary:
Mine measures 28.5" from the garage floor to the belly, at the firewall. That is with an Eggenfellner engine installed. My airplane rolls out of a standard 7' garage door with several inches to spare. No tail feathers of course.
Steve Mills N750SM (reserved)
RV-10 40486 Slow-build Eggenfellner E-6TI
Naperville, Illinois
Finishing kit, engine install
Tim Olson
Posted: Mon Jun 30, 2008 8:24 am Post subject: Ramp to belly distance? |
Gary,
From waaaaaay back before when I was in the same situation, I put
this together:
http://www.myrv10.com/tips/workarea.html
orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
Instrument Panel, Fiberglass - SB
(N2GB registered)
orchidman
bldanrv9a(at)yahoo.com Guest
Posted: Tue Jul 01, 2008 3:34 pm Post subject: Ramp to belly distance? |
I'm not sure of the belly height but we were able to get ours out of a door that was 6'-4" high by 7'-11" wide door with the Lyc IO 540 hung. We were able to do this by removing the main wheels and fabricating a 4" dolly wheel. We rolled it about 6-8 feet on the dollys and then put mains back on. It worked great. I have pictures somewhere if you need to see them.
--- On Mon, 6/30/08, orchidman <gary(at)wingscc.com> wrote:
| Quote: | From: orchidman <gary(at)wingscc.com>
Subject: Ramp to belly distance?
Date: Monday, June 30, 2008, 9:17 AM
installed.
stuck.
Gary Blankenbiller
RV10 - # 40674
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=190550#190550
orchidman
