		RobHickman(at)AOL.COM Guest
				 Posted: Mon Jun 30, 2008 11:38 am    Post subject: How to build the Windshield faring |
				One  advantage of having the windows not bond the first time is I got to remake the  front fairing with the help of my neighbor Jim Cullison that built an award  winning Lancair.  The made the first  fairing using Van’s plans, laid up in place and I thought it looked really good  after hours and hours of sanding.
 Jim  suggested we do it like Lancair;   wet out  the layers on the  table and then transfer the 5 foot floppy mess to the windshield.  After my experience with the Lancair  window epoxy I was less than excited about using another Lancair inspired  technique.    After much discussion with my fellow  RV-builder’s that had stopped by to check my progress we all decided it would  never work.  My wife Jennifer then  informed the skeptical group that Jim had built a whole airplane out of  fiberglass and he just might know what he is doing.
 To my surprise “The Cullison Technique” worked fantastic, the  faring looks great and took very little sanding.
 Step  1
 Use  Blue masking tape to tape mark where the faring will be on the window and the  top of the fuselage. The tape should be located where the faring will be.  You can keep moving the tape until  everyone agrees it looks good.
 Step  2
 Use  20 mil black pipe  wrapping tape from Home Depot to layout the edge of the faring next to the  masking tape.  This black tape is  really thick electrical tape, is very rugged and really works well.
 Step  3
 Remove  the masking tape and aggressively sand the windshield and aluminum fuselage  where the faring will bond to. The thick black tape really protects the window  and fuselage faring edge.  After  sanding clean the aluminum with Acetone (do not get on window) and blow off the  window with air.
 Step  4
 Build  the bottom window fillet out of Epoxy and micro balloons; this should fill the  joint between the windshield and fuselage making a smooth radius.  We used slow cure hardener so that we  would have lots of time.
 Step  5
 Lay a piece of thin clear plastic on a 6 foot table that is about 1  foot wide.  Cut your first 3 layers  of increasing widths of fiberglass cloth using a long ruler and a rotary cutter  (we used 9 0z bias cloth,  the woven  fibers run diagonal so that it will curve ).  The rotary cutter is a handle with a  sharp wheel that makes the long cuts very easy (I found mine in Jennifer’s  sewing supplies).  Lay the strips of  fiberglass in a stack with the widest on the bottom on the plastic.  Pour a line of epoxy down the glass  cloth and let it soak through the layers, you should add more resin to places  that are not wetting out.    Once the stack of cloth is wet out you should fold the plastic over the  top of the stack and then using a hard roller you should roll the extra resin  out of the stack.
 Step  6
 Using  your long metal ruler as a guide and the rotary cutter trim both  long edges of the fabric and plastic  sandwich.  You should only be  trimming the edge of the bottom glass layer and the extra plastic and  resin.
 Step  7
 Remove  the top plastic layer from the stack and then using two people flip over the  stack  and carefully place it in the  middle of the windshield-fuselage faring.   Once we had it located fairly  close we removed the top plastic layer and used a brush to push it in place and  remove any bubbles.
  Step  8
 Repeat  steps  5,6,7 for the next three  layer stack.  As long as the epoxy  does not harden you can keep adding layers without sanding.
 Step  9
 Repeat  steps  5,6,7 for the final one  layer stack that will be used for the  bottom fuselage edge.  We trimmed  the width to 2 ½” wide and carefully brushed it  so it just touched the tape edge on the  fuselage.
 Step  10
 Repeat  steps  5,6,7 for the final one  layer stack that will be used for the  upper windshield edge.  We trimmed  the width to 2 ½” wide and carefully brushed it so it just touched the tape edge  on the windshield.
 Step  11
 Press  peelply on the top of the fairing so that it will leave a rough finish that you  can add epoxy and micro balloons without having to sand.  The peelply should be removed once the  epoxy is cured.
 We  precut all the layers of cloth and in less than two hours I had a fairing that  is going to take very little sanding and looks great.
 Rob  Hickman
 N402RH  RV-10 with Windows and a Fairing
 Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
		kearney(at)shaw.ca Guest
				 Posted: Mon Jun 30, 2008 12:47 pm    Post subject: How to build the Windshield faring |
				Rob
 Do you have any pictures (*I hope so*).
 By the way, the last time I pilfered some of my wife’s sewing supplies to cut fibreglass, I was told in no uncertain terms that I would be neutered if I did it again. That was over 10 years ago, am I am still occasionally reminded of my transgression. Be warned!
 Cheers
 Les
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RobHickman(at)AOL.COM
  Sent: June-30-08 1:29 PM
  Subject: How to build the Windshield faring
 Step 1
 Step 2
 Step 3
 Step 4
 Step 5
 Step 6
 Step 7
 Step 8
 Step 9
 Repeat steps 5,6,7 for the final one layer stack that will be used for the bottom fuselage edge. We trimmed the width to 2 ” wide and carefully brushed it so it just touched the tape edge on the fuselage.
 Step 10
 Repeat steps 5,6,7 for the final one layer stack that will be used for the upper windshield edge. We trimmed the width to 2 ” wide and carefully brushed it so it just touched the tape edge on the windshield.
 Step 11
 Rob Hickman
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		Jim Berry
				 Posted: Mon Jun 30, 2008 2:24 pm    Post subject: Re: How to build the Windshield faring |
				Rob,
 I used the same technique as you, with only 2 minor changes. I was concerned about the flox that forms the fillet at the bottom of the windscreen pushing through to the interior and creating an irregular edge, so I took a length of 3/8" round weather strip which I coated with mold release wax, and worked it into the angle between the inside of the windscreen and the glare shield with a paint stir stick. When the flox was cured I pulled the weather strip out, leaving a nice rounded contour at the bottom of the windscreen.
 Also I had seen several -10's with a bulge at the ends of the windscreen fairing, caused by the 10 layers of glass called for. For the first 6 layers I cut back the ends 1" per layer so they were staggered. The top 4 layers are full length. This was enough to eliminate the bulge, and made it much easier to fair to the front edge of the door.
 Jim Berry
 40482
