Coloradodan
Joined: 11 Jun 2008 Posts: 31 Location: Frederick, CO
Posted: Tue Jul 01, 2008 2:35 pm Post subject: Tire Pressure |
On the 801 with the 8.0 tires has anyone experimented with the tire pressure?
_________________ Crashed and destroyed 801 back the the drawing board. |
n85ae
Posted: Wed Jul 02, 2008 9:23 am Post subject: Re: Tire Pressure |
What I do on my Kitfox with my current 6.00x6 tires, and with my 8.50x6
tires I occasionally use is adjust to about 20 psi, and then lay down on the
ground in front of the plane and adjust pressure plus or minus until I get
the tread contact I want to see. The taildragger can get pretty squirrely
with too much pressure on pavement, but with too low a pressure
ground roll increases. Based on experience with the plane I have a pretty
good idea of what amount of tread I want to see for different conditions.
I have McCreary 6, and 8.50's for it. The 6.00's are rated to 60 psi so
there is a lot of room for adjustment. Too low though can cause slipping
on the rims which is bad.
I imagine the CH801 tire inflation procedure would be a similar lay on
the ground and eyeball the tread contact pattern were I doing it.
Jeff
Coloradodan
Posted: Sat Jul 05, 2008 3:20 pm Post subject: Re: Tire Pressure |
First 5 landings at 30 psi, control felt tight and fast
Second 5 landings 18 psi, felt better but I'm planning on dropping them another 5-8 psi.
ronlee
Posted: Sat Jul 05, 2008 6:08 pm Post subject: Re: Tire Pressure |
I put just enough air in my 701 tires so the side walls don't bulge, about 10 pounds. It can get a little squishy feeling on taxi but they take up alot of shock on landing with low pressure.
_________________ Ron Lee
Tucson, Arizona |
n801bh(at)netzero.com Guest
Posted: Sat Jul 05, 2008 7:53 pm Post subject: Tire Pressure |
ya get much below 15 psi and it will take full power just to taxi,,, :<)
Ben Haas
N801BH
www.haaspowerair.com
-- "Coloradodan" <dfanning1(at)gmail.com> wrote:
--> Zenith701801-List message posted by: "Coloradodan" <dfanning1(at)gmail.com>
1.5 hours of taxi time.
http://forums.matronics.com/vie================================================-= --> http://www.matronics.com/Navigator?Zenith701801-========================; - MAT================================================bsp; - List Contribution Web Si ====================================================
Sweepstakes!!!
Enter for your chance to WIN one of hundreds of daily prizes.
