rv(at)thelefflers.com Guest
Posted: Fri Jul 04, 2008 12:33 pm Post subject: Rear Wing Spar question |
On page 15-4 on the Wing manual. It clearly calls to machine counter sink the top of the rear spar (w-1007a) on the three areas with the three (w-1007d/e) spar doublers. It also specifically calls to dimple the 26 inboard places on the top and bottom flange on the rear spar.
This isn’t making sense to me. Perhaps I’m being a little dense (no jokes please) this holiday weekend.
The spar is too think to dimple, so I’m surprised that the instructions don’t specifically call for machine countersinking. I suspect this is the first area that I’ve run into where the common instructions are omitted, since it doesn’t make any mention of countersinking the other top and bottom holes that mate with the wing skins.
I assuming that machine countersinking the top and bottom flange on the rear spar is the appropriate action. I guess I’m probably thinking too hard to understand why they want these 26 holes dimpled instead of countersinking.
I’m curious to see what others have done.
Bob
drfred(at)suddenlinkmail. Guest
Posted: Fri Jul 04, 2008 2:18 pm Post subject: Rear Wing Spar question |
Bob;
It's been about year and half and I looked over that section again. I
think I did get out my big squeezer and dimpled that line on top the
1007 a. As I remember, the skins would have fit better if they were
countersinked, as long as you had adequate metal there. My wings are out
at the hanger so I couldn't look at them. Maybe someone else has some
more recent recollections.
Dr Fred.
wiring up center console.
Bob Leffler wrote:
skins.
countersinking.
Bob
carl.froehlich(at)cox.net Guest
The rear spar does get dimpled. At .040” it is still thin enough.
Carl Froehlich
RV-8A (425 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Friday, July 04, 2008 4:30 PM
Subject: Rear Wing Spar question
Bob
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
pascal(at)rv10builder.net Guest
Posted: Fri Jul 04, 2008 8:07 pm Post subject: Rear Wing Spar question |
Maybe I am looking at the wrong piece 1007c is countersunk and the top and bottom flange of the rear spar are fine to dimple, you as a builder can make the decision to countersink if you chose but you are looking at the rear spar..right? shouldn't be a problem to squeeze; the front.. THAT is too thick.
I would guess the tip of the wings having the skins attached over these flanges they (Van's) want that extra level of strength that dimpling would produce over countersinking..
Sent: Friday, July 04, 2008 1:29 PM
Bob
Posted: Sat Jul 05, 2008 10:53 am Post subject: Rear Wing Spar question |
Thanks to Carl, Fred, and Pascal for getting me by my brain fart this
weekend. Using the pneumatic squeezer and dimpling worked just fine.
Bob
John Kirkland
Joined: 13 Jan 2006 Posts: 19 Location: South Weber, UT
Posted: Sun Jul 06, 2008 6:53 am Post subject: Re: Rear Wing Spar question |
The W1007D & E doublers have a flange that nests in there. Dimpling may make the doublers not fit tightly, as you will now have to dimple them too. The dimples may not set inside each other very well due to the material thickness.
_________________ RV-10 #40333
N540XP (reserved) |
