cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Sat Jul 05, 2008 7:10 am Post subject: Gyrocopter intercept |
I was intercepted today by AF gyro.
just kidding
Gyrocopter flew with me to Alma today on my first cross country in my Kolb Mark II Twinstar.
Description: |
Filesize: |
129.14 KB |
Viewed: |
569 Time(s) |
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
planecrazzzy Guest
Posted: Sat Jul 05, 2008 8:50 am Post subject: Re: Gyrocopter intercept |
Just curious.... Could he "keep up" or did you have to back off the throttle?
Gotta Fly...
Mike & "Jaz" in MN
Description: |
Filesize: |
60.61 KB |
Viewed: |
566 Time(s) |
rlaird
Posted: Sat Jul 05, 2008 9:09 am Post subject: Gyrocopter intercept |
That's looks like a Sparrowhawk, and they normally cruise in the 65-70mph range.
On Sat, Jul 5, 2008 at 11:50 AM, planecrazzzy <planecrazzzy(at)yahoo.com> wrote:
Why did the chicken cross the Mobius strip? To get to the other, er, um....
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
cristalclear13
Posted: Sat Jul 05, 2008 10:48 am Post subject: Re: Gyrocopter intercept |
planecrazzzy wrote: | Just curious.... Could he "keep up" or did you have to back off the throttle?
Gotta Fly...
Mike & "Jaz" in MN
Mike, My climb rate is MUCH faster, but as far as cruising he can keep up or even pass me. On the way there I was cruising at 65 but on the way back I cruised at 60 to save on gas.
It is a RAF 2000 gyrocopter.
gliderx5
Posted: Sat Jul 05, 2008 1:51 pm Post subject: Gyrocopter intercept |
I just flew my 503 powered MKII and I only cruise at about 45 mph on the GPS at 5200 rpm. At 6200 I can get 60 mph but no faster. Do these numbers sound like what others are seeing? I have a 3 blade IVO prop. Average fuel burn looks to be 3 gph.
Malcolm Morrison
http://home.comcast.net/~mmorrison123
Schleicher ASW-15
Pietenpol Air Camper
Kolb MKII
-------------- Original message ----------------------
From: "cristalclear13" <cristalclearwaters(at)juno.com>
Quote: |
> Gotta Fly...
> Mike & "Jaz" in MN
Cristal Waters
Mark II Twinstar
http://forums.matronics.com/viewtopic.php?p=191327#191327
cristalclear13
Posted: Sat Jul 05, 2008 2:41 pm Post subject: Re: Gyrocopter intercept |
gliderx5 wrote: | I just flew my 503 powered MKII and I only cruise at about 45 mph on the GPS at 5200 rpm. At 6200 I can get 60 mph but no faster. Do these numbers sound like what others are seeing? I have a 3 blade IVO prop. Average fuel burn looks to be 3 gph.
Malcolm Morrison
Schleicher ASW-15
Kolb MKII
Malcolm, On the way there my rpm was showing 6000 and I was cruising at 65mph on my ASI (and the GPS registered anywhere from 47 to 65).
On the way back my rpm was around 5700-5800 and I was cruising at 60mph on my ASI. I have a 66inch wood prop. At the rate I was going I burned approximately 4 GPH.
planecrazzzy Guest
Posted: Sat Jul 05, 2008 2:57 pm Post subject: Re: Gyrocopter intercept |
Cruise speed for me, was increased ALOT by changing my 3 blade IVO
to a 2 blade ( I bought the "Blocks" from IVO )
My cruise used to be around 60.... I'm 70 plus now
The other day I was a little high on the throttle RPM's .... I looked at my Airspeed... I was doing 80 !!!
Gotta Fly...
Mike & "Jaz" in MN.
PS Climb out is a little less........ "I'LL TAKE IT "
gliderx5
Posted: Sat Jul 05, 2008 3:50 pm Post subject: Gyrocopter intercept |
Maybe I should try more prop pitch. My CHTs are 300 but my EGTs peak at 1200 (1100 at full power climb). I have home made streamlined struts, but no other "speed" mode. I don't have a VSI, but I will do some timed climbs to see what type of performance I'm getting. What are you seeing for climb rate? If I could get the cruise up to 55 that would be huge!
Malcolm Morrison
Schleicher ASW-15
Kolb MKII
looks to be 3 gph.
> Malcolm Morrison
> Schleicher ASW-15
> Kolb MKII
4 GPH.
Cristal Waters
Mark II Twinstar
http://forums.matronics.com/viewtopic.php?p=191355#191355
JetPilot
Posted: Sat Jul 05, 2008 4:50 pm Post subject: Re: Gyrocopter intercept |
Try increasing your pitch, it does not take long, and you can always put it back if you dont like it.
I decreased the pitch on my 912-s a couple weeks ago to get full RPM on takeoff and climb out.... It got me a couple more hundred FPM in climb, but cruise sucked, I had to run a bunch more power just to get the same cruise I did before. I put the pitch back for 5200 RPM on climb out, it restored my cruise speed with lower power settings.
Kolb MK-III Xtra, 912-S |
gaman(at)att.net Guest
Posted: Sat Jul 05, 2008 6:23 pm Post subject: Gyrocopter intercept |
Might be helpful to know the top RPM on climb out.
gliderx5
Posted: Sat Jul 05, 2008 7:24 pm Post subject: Gyrocopter intercept |
lcottrell
Posted: Sat Jul 05, 2008 7:47 pm Post subject: Gyrocopter intercept |
ez(at)embarqmail.com Guest
Posted: Sun Jul 06, 2008 4:13 am Post subject: Gyrocopter intercept |
Nope, don't mess with your carb till you get your prop set up
correctly. Your top speed indicates that you do not have the optimum
prop configuration. Unless your prop diameter is less than 66"
diameter you will do significantly better with two blades than with
three. What you need is more prop pitch.
Gene
On Jul 5, 2008, at 11:45 PM, Larry Cottrell wrote:
Quote: |
Sounds as though you might be a bit lean on your midrange. You might
try to raise your jet needle one notch.
Larry C
gliderx5
Posted: Sun Jul 06, 2008 4:53 pm Post subject: Gyrocopter intercept |
Quick update
I added a half turn more pitch to the 3 blade IVO and my 5200 RPM cruise went from 45 to 50 MPH. My top speed went from 60 to 65 MPH. Climb still good (not sure of the rate). EGTs quite a bit cooler, but engine running rough in the mid range. I think it's too rich now. I will try dropping the needle 1 notch later this week.
Malcolm Morrison
Schleicher ASW-15
Kolb MKII
Gene
> Larry C
lcottrell
Posted: Sun Jul 06, 2008 7:00 pm Post subject: Gyrocopter intercept |
grantr
Posted: Sun Jul 06, 2008 7:44 pm Post subject: Re: Gyrocopter intercept |
Does that RAF have a horizontal stabilizer on it? If it doesn't don't fly in it. That particular gyroplane has killed many high time pilots. Its unstable without the H stab on it.
cristalclear13
Posted: Mon Jul 07, 2008 4:49 am Post subject: Re: Gyrocopter intercept |
Larry,
I can't ever see what you are writing. It shows up as blank on the website and I don't get the emails. Maybe it's the font you are using. I think I saw Matt Dralle mention that to someone else.
Cristal
cristalclear13
Posted: Mon Jul 07, 2008 4:54 am Post subject: Re: Gyrocopter intercept |
grantr wrote: | Does that RAF have a horizontal stabilizer on it? If it doesn't don't fly in it. That particular gyroplane has killed many high time pilots. Its unstable without the H stab on it. |
Grant,
Now you're delving into what has been "discussed to death" on threads and threads of gyro forums. I won't go there. I just know that I totally trust riding in that gyro and totally trust who is flying it.
Thanks for the concern.
Cristal
cristalclear13
Posted: Mon Jul 07, 2008 4:57 am Post subject: Re: Gyrocopter intercept |
gliderx5 wrote: | I don't have a VSI, but I will do some timed climbs to see what type of performance I'm getting. What are you seeing for climb rate? |
Malcolm,
I don't have a VSI either. I'll time my climbs next time I go and let you know. I'm glad you are seeing better performance after adjusting your prop.
Cristal
Ed in JXN
Posted: Mon Jul 07, 2008 8:53 am Post subject: Gyrocopter intercept |
Hi Cristal,
What state are you in?
Ed in JXN
MkII/503
Do not archive.
