Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
lwinger
Posted: Fri Jul 04, 2008 6:28 pm Post subject: Grove Main Gear Support |
When I purchased my Grove main landing gear, I was told I needed main gear supports from Zenair in Canada, since they supply them to AMD. Now that I'm at that point, I can't say that I understand how they mount. Do they work in conjunction with Zenith 6-B-11-4 (welded main gear attachment) or replace it? Does anyone have any drawings. Picture attached.
Thanks.
| Description: |
| Grove main gear supports from Zenair |
| Filesize: |
86.62 KB |
| Viewed: |
369 Time(s) |
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Gig Giacona
lwinger
Posted: Fri Jul 04, 2008 9:03 pm Post subject: Grove Main Gear Support |
After posting my question, I basically figured out what you just described. Now I just need to determine if the welded-on spacer goes toward the front or rear of the channel.
Thanks, Gig.
On Fri, Jul 4, 2008 at 9:50 PM, Gig Giacona <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)> wrote:
[quote]--> Zenith601-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)>
I'm not 100% sure but I believe it replaces the piece of aluminum angle that is used with the normal gear. Those welded on pieces allow for the smaller (front to rear width) gear.
The piece in the background goes on the bottom of the fuselage then the gear is sandwiched between it and the pieces in the foreground.
Is that clear as mud?
W.R. "Gig" Giacona
601XL Under Construction
http://forums.matronics.com/viewtopic.php?p=191299#191299
Tustin, CA
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sat Jul 05, 2008 3:01 am Post subject: Grove Main Gear Support |
On Fri, Jul 04, 2008 at 10:03:17PM -0700, Larry Winger wrote:
| Quote: | After posting my question, I basically figured out what you just described.
The rear, I would believe, based on the gear on my Zodiac being positioned
at the front of the channel.
I was going to take pictures this morning, but Gig described things just
fine.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
macleod(at)eagle.ca Guest
Posted: Sat Jul 05, 2008 7:01 pm Post subject: Grove Main Gear Support |
Larry:
I had the same question when I went to install my Grove gear. One thing
about this list, questions are sure answered fast!!
In addition to the answers you already have you can go to the AMD site and
look at the drawings (Do other manufacturers of light aircraft provide the
same excellent detailed info? i doubt it.)
for Grove gear:
http://www.newplane.com/amd/amd/601_SLSA/Parts/6-A-25.jpg
for the standard Zenith gear:
http://www.newplane.com/amd/amd/601_SLSA/Parts/6-A-24.jpg
Mike
XL final assembly in progress.
Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Sat Jul 05, 2008 8:32 pm Post subject: Re: Grove Main Gear Support |
Why do they supply a smaller main gear other than the one that Zenith supply. (any benefits one over the other)
lwinger
Posted: Sat Jul 05, 2008 10:10 pm Post subject: Grove Main Gear Support |
Thanks so much. I had no idea they provided that kind of detailed information. Questions answered!
Larry Winger
On Sat, Jul 5, 2008 at 8:00 PM, <macleod(at)eagle.ca (macleod(at)eagle.ca)> wrote:
[quote]--> Zenith601-List message posted by: macleod(at)eagle.ca (macleod(at)eagle.ca)
Larry:
for Grove gear:
Mike
Tustin, CA
cndmovn(at)gmail.com Guest
Posted: Sun Jul 06, 2008 2:59 am Post subject: Grove Main Gear Support |
weight! The difference between the two is amazing. I am away from my shop right now but if memory serves me correctly there is at least a 10lbs savings.
On Sun, Jul 6, 2008 at 12:32 AM, Ianrat <ianrat(at)powerup.com.au (ianrat(at)powerup.com.au)> wrote:
[quote]--> Zenith601-List message posted by: "Ianrat" <ianrat(at)powerup.com.au (ianrat(at)powerup.com.au)>
http://forums.matronics.com/viewtopic.php?p=191402#191402
planecrazydld(at)yahoo.co Guest
Posted: Sun Jul 06, 2008 3:31 am Post subject: Grove Main Gear Support |
different alloy and temper - Grove material is stronger. Stronger/stiffer = less weight possible with smaller crossection.
David L. Downey
Harleysville (SE) PA, USA
--- On Sun, 7/6/08, Ianrat <ianrat(at)powerup.com.au> wrote:
[quote]From: Ianrat <ianrat(at)powerup.com.au>
Subject: Re: Grove Main Gear Support
Date: Sunday, July 6, 2008, 12:32 AM
Read this topic online [quote][b]
John Bolding
Posted: Sun Jul 06, 2008 4:01 am Post subject: Grove Main Gear Support |
Absolutely, Also a lot more prone to corrosion, something for those guys in coastal, high humidity, pollution areas to consider.
John
Posted: Sun Jul 06, 2008 4:40 am Post subject: Grove Main Gear Support |
and on the down side as well - also extremely notch sensitive as aluminums go.
Anyone using them should make inspections for nicks and gouges a preflight thing and treat them like a similar nick in a metal prop. Always dress them out in the long axis and avoid any sharp changes.
David L. Downey
--- On Sun, 7/6/08, John Bolding <jnbolding1(at)teleshare.net> wrote:
[quote]From: John Bolding <jnbolding1(at)teleshare.net>
Subject: Re: Re: Grove Main Gear Support
Date: Sunday, July 6, 2008, 7:55 AM
John
jmaynard
Posted: Sun Jul 06, 2008 6:19 pm Post subject: Grove Main Gear Support |
On Sat, Jul 05, 2008 at 09:32:55PM -0700, Ianrat wrote:
| Quote: | Why do they supply a smaller main gear other than the one that Zenith
In addition to the comments others have posted, I'm told that the Grove gear
sits a bit higher than the Zenith gear. AMD also has theirs gundrilled, so
there are no external brake lines running down the gear legs (though there
are short lines from the bottom of the legs to the brake calipers).
Posted: Sun Jul 06, 2008 6:50 pm Post subject: Grove Main Gear Support |
The gun drilled brake lines is why I swapped my gear out for Grove. Having the brake lines just "hang out back" spooked me. My Kitfox had gundrilled Grove gear and it was fantastic. I hope my XL is the same.
Paul
On Sun, Jul 6, 2008 at 10:18 PM, Jay Maynard <jmaynard(at)conmicro.com (jmaynard(at)conmicro.com)> wrote:
[quote] --> Zenith601-List message posted by: Jay Maynard <jmaynard(at)conmicro.com (jmaynard(at)conmicro.com)>
Brady
Posted: Mon Jul 07, 2008 4:51 am Post subject: Re: Grove Main Gear Support |
Has any body tried the Composite gear available from spruce?
I understand there is a 40 LBS savings to be had?
Brady
_________________ Brady McCormick
Poulsbo, WA
www.magnificentmachine.com |
Gig Giacona
Posted: Mon Jul 07, 2008 7:48 am Post subject: Re: Grove Main Gear Support |
While I'll admit the gun-drilled brake lines are nice. The lack of them is hardly anything to be spooked about. Cessna has hung them out the back for years.
http://www.aircraftpartsandsalvage.com/popup_image.php?pID=12340&osCsid=eaccddfaa6563c93e7bceaa615fb3693
| cndmovn(at)gmail.com wrote: | The gun drilled brake lines is why I swapped my gear out for Grove. Having the brake lines just "hang out back" spooked me. My Kitfox had gundrilled Grove gear and it was fantastic. I hope my XL is the same.
Paul
Posted: Mon Jul 07, 2008 1:52 pm Post subject: Grove Main Gear Support |
discussed a while back. The gear that was available from them last year was two piece - not sure how it could be used without a major re-engineering exercise.
David L. Downey
--- On Mon, 7/7/08, Brady <brady(at)magnificentmachine.com> wrote:
[quote]From: Brady <brady(at)magnificentmachine.com>
Date: Monday, July 7, 2008, 8:51 AM
[quote]--> Zenith601-List message posted by: "Brady"
I understand there is a 40 LBS savings to be [quote][b]
LHusky
Joined: 19 Jun 2008 Posts: 86 Location: Madras, Oregon
Posted: Mon Jul 07, 2008 3:49 pm Post subject: Grove Main Gear Support |
I have it in my plane. You do want to make sure you get the gear before you get to that stage. The gear attachment is different. I actually did not get mine from ACS. It is from a CZAW plane that the owner wanted to tear apart due to the accidents. It was almost a new plane and a very well built plane. As far as the re-engineering goes, the gear channel was the exact same as mine with the gear attachments being different. There are 2 metal I beam type fittings that go inside the gear channel from the bottom and 6 support pieces inside the fuse. 4 of them go along the sides of the gear channel and 2 of them go on the inside of the center console and the seat belts attach to them. Makes the seat belt attachment so much stronger. I feel better with that. There is a huge weight savings with this gear. It was not hard at all to convert to use this gear. I got the gear, wheels, tires, brakes and wheel pants for $150.00, so I could not pass it up. I am installing a Corvair on my airframe and I just saved the extra weight from the Jabiru to the Corvair. It is a 2 piece system, but it stands taller. The wheels and tires are much lighter than the grove gear and I thought it might be hard to find parts, but it is not. I have already ordered and received extra disk brakes rotors and pads. I am excited about the gear and hope that it was worth the conversion. I saw the gear on the original plane and it looked really good. I don't know what all comes with the ACS system, but I got everything I needed from the donor plane. I was very impressed with the welded parts. They were top notch parts.
Larry Husky
Madras, Oregon
In a message dated 7/7/2008 2:53:02 P.M. Pacific Daylight Time, planecrazydld(at)yahoo.com writes:
| Quote: | discussed a while back. The gear that was available from them last year was two piece - not sure how it could be used without a major re-engineering exercise.
David L. Downey
| Quote: | From: Brady <brady(at)magnificentmachine.com>
Subject: Zenith601-List: Re: Grove Main Gear Support
| Quote: | --> Zenith601-List message posted by: "Brady"<brady(at)magnificentmachine.com>Has any body tried the Composite gear available from spruce?I understand there is a 40 LBS savings to be
nith601-List"' href='mip://00eb5478/3D"http://www.matronics.com/Navigator?Zenith601-List"'>http://www.matronics.com/Navigator?Zenith601-List
='mip://00eb5478/3D"http://forums.matronics.com"'>http://forums.matronics.com
"' href='mip://00eb5478/3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
annken100
Posted: Thu Jul 10, 2008 6:11 am Post subject: Re: Grove Main Gear Support |
Gig,
Here is a picture of and AMD 601 with the Grove gear. The welded spacers are towards the rear.
Ken
601 XL / Corvair
| Description: |
| Filesize: |
1.17 MB |
| Viewed: |
360 Time(s) |
_________________ 601 XL / Corvair |
