VHMUM(at)bigpond.com Guest
Posted: Sun Jul 06, 2008 3:42 am Post subject: prop governor changes |
I need to change my governor setting as it will over rev and I can only go
3/4 throttle and take off to keep it 2700rpm. I doubt if the screw
adjustment will be enough so my question for those that have moved the arm
one spline was it a big deal? Does the spline want to turn by it self once
you remove the arm to reposition?
Chris
VH-ICY
7.1 hours and no cracks
dlm46007(at)cox.net Guest
Posted: Sun Jul 06, 2008 5:19 am Post subject: prop governor changes |
No big deal but you do neeed to mark with fine tip marker the current
location. Mark both the spline and the arm. If you are over reving then you
must move the arm clockwise with repsect to the spline. My guess would be at
most two splines. Four hands or a locking wrnech may help to ensure movement
in the correct way. Mine was under reving by 200 rpm. I initially moved it
2-3 splines CCW and it was too much. Adjusted to 1 spline and used the
screw.
Posted: Sun Jul 06, 2008 5:23 am Post subject: prop governor changes |
You might also need to adjust the low pitch stop on the prop to ensure that
in the event of governor failure that the in-flight overspeed does not
overstress the prop/engine. Overspeed prop conditions are specified in the
prop manual.
Posted: Sun Jul 06, 2008 3:06 pm Post subject: prop governor changes |
Will do
thanks chris
