tdawson-townsend(at)auror Guest
Posted: Mon Jul 07, 2008 6:16 am Post subject: Paint on plexi? |
I was planning on having the exterior paint lap over the plexiglass on the windows to hide the sins on the inside of the glass. Recently, a local “expert” implied that paint on plexiglass was a no-go. What’s the straight dope?
Tim Dawson-Townsend
40025, endless minutiate
coop85(at)cableone.net Guest
Posted: Mon Jul 07, 2008 7:05 am Post subject: Paint on plexi? |
My paint goes on to the plexi and I don’t think I’ve seen a RV-10 yet that doesn’t have it that way (however, I’ve been wrong before in my observations). The paint is sticking great, however I am having issues where the plexi/cabin meet with cracks in the paint.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Monday, July 07, 2008 9:12 AM
Subject: Paint on plexi?
Tim Dawson-Townsend
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
speckter(at)comcast.net Guest
Posted: Mon Jul 07, 2008 7:20 am Post subject: Paint on plexi? |
I have painted numerous windows on several aircraft with no problems except that on the upper part of the windscreen in rain it will peal back some if you are above 150 knots. I solve that with the clear urethane tape. Normal prep by sanding and alcohol cleaning advised. Logic tells you though not to flood the plexi with paint as the excess solvent is problematic. I spray a thin coat on first and let that dry as a barrier then paint normally.
Gary Specketer
40274 Flying
Tim Dawson-Townsend
greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Mon Jul 07, 2008 12:02 pm Post subject: Re: Paint on plexi? |
I used PPG's black epoxy primer on the inside of my RV8 windshield. It is also on the canopy hiding the front support bow. The RV8 is now 8 years old and 800+ hours. The epoxy has not peeled off or crack the windshield. I plan on doing the same thing on my RV10.
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
