carl.froehlich(at)cox.net Guest
Posted: Mon Jul 07, 2008 3:36 pm Post subject: primer suggestions |
PPG DP-40LF two part self etching epoxy primer. Use PPG DX533 aluminum cleaner with red Scotchbrite pads to prep the aluminum. Rinse with a lot of water, let dry then prime.
Very tough, scratch and solvent resistant product. I use the same primer with PPG concept base coat clear coat for the finish paint. PPG concept is very forgiving to the amateur painter working in a makeshift paint booth.
Carl Froehlich
RV-8A (425 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins
Sent: Monday, July 07, 2008 6:46 PM
Subject: primer segestions
I am looking to find a very easy to spray and manage primer. I do not want to acid etch and Aldine then prime. So I am looking for a simple primer that I can spray right on to a scuffed part with reasonable protection. I am in northern California so no real wet environment at all. Plus I have a have to park it in.
What would you builders recommend.
John
40864
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
msausen
Posted: Mon Jul 07, 2008 4:05 pm Post subject: primer suggestions |
DP40 is NOT self etching. It’s a catalyzed epoxy primer that can be used as a sealer depending how it’s mixed. Great stuff though.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Monday, July 07, 2008 6:32 PM
Subject: RE: primer suggestions
Carl Froehlich
RV-8A (425 hrs)
RV-10 (fuselage)
John
40864
| Quote: | | http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution | 01234567890123456789
pascal(at)rv10builder.net Guest
Posted: Mon Jul 07, 2008 5:06 pm Post subject: primer suggestions |
well I am one that says right on! That is what I did and the primer has held well. I did use the 988 and funny that the self etch actually doesn't do well with alclad and comes off pretty easily. Wash primer no problemo as our governor would say!
Pascal
Sent: Monday, July 07, 2008 5:33 PM
Subject: Re: primer segestions
John
I have had great results with SEM primer. I studied primer a bunch until I landed on Randy Lervold's site and took his advice: http://www.romeolima.com/RV3works/Airframe/airframe.html#Primer Randy is our EAA Chapter 105 president. I use the spray cans with a clip on spray handle for convenience. Cost is a bit more then quarts but, easy clean-up and pro finish. I do not scuff with scotchbright choosing instead to preserve that layer of added factory protection, I just wipe my parts with lacquer thinner and shoot them. Last thing, I prime each part before assembly adding the layer of protection where is is needed most in the future.
I know there are at least 20 guys that are reading this and thinking wrong, wrong, wrong.
Best Wishes, good priming,
Paul Grimstad
RV10 450 rudder pedals
