darinh
Posted: Thu Jul 10, 2008 12:00 am Post subject: S7-914 Empty Weight...and questions? |
Well, I have the DAR scheduled for Monday morning at 9 am. Did the W&B tonight and came up with 855 lb empty (includes oil and coolant). I did have a question though for those that have a Series 5 thru 7.
The manual shows the datum (leading edge of wing at the root) to be just in front of the mains (center of axle). My datum ended up opposite and just behind the main axles by 2 3/8" when she is level (the gear are in the correct orientation). What have others found? Also, when in level attitude, the weight on the tailwheel was 53 lbs. Looking at the example in the manual (Section M pg. 86) I see the tailwheel showing like 165 lbs or something in that range. Are these values in the example table simply arbitrary numbers that were pulled out of the air when Skystar wrote the manual? What do others have (actual weights) for their mains and tailwheels? Just want to check if my scales were reading correctly.
As a side note, I am happy with the weight as I was estimating closer to 875 lbs. just on the gut feel.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Tom Jones
Posted: Thu Jul 10, 2008 4:55 am Post subject: Re: S7-914 Empty Weight...and questions? |
| Quote: | | Also, when in level attitude, the weight on the tailwheel was 53 lbs. Looking at the example in the manual (Section M pg. 86) I see the tailwheel showing like 165 lbs or something in that range. Are these values in the example table simply arbitrary numbers that were pulled out of the air when Skystar wrote the manual? |
Darihn, I don't have a 5 or 7 but can say for sure the 165 pound tail wheel weight is a mistake. That would be closer to being the tail wheel arm in inches. My Classic 4 tail wheel weighs 35 pounds when the fuselage is level.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Thu Jul 10, 2008 5:08 am Post subject: S7-914 Empty Weight...and questions? |
Darinh,
My manual, section M page 86, indicates Nose/Tailwheel at 195 lbs. Given
the indicated arm of -35.4 I conclude that is for the nosewheel.
My 7, as I believe is also yours, is conventional gear (with tailwheel).
My weight came in at 827 lbs. The arm (level position) at -2.38 on the main
axles. My weight on the tail wheel is 71 lbs. (seems a little heavy,
don't know what that is all about....)
Your numbers look fine to me.
Hope this helps.
Vic
Vic Baker
S7 912S Warp 100%
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
darinh
Posted: Thu Jul 10, 2008 8:20 am Post subject: Re: S7-914 Empty Weight...and questions? |
Vic,
My mains came out the same -2.38" (forward of Datum).
Tom,
Don't I look like an idiot! I didn't even notice the arm in the example...just assumed it was a tailwheel example because that is what I am building. Makes much more sense as a nosewheel.
Thanks guys for the replies...Airworthiness here we come!
Series 7
914 Turbo
Kaysville, Utah |
Float Flyr
Posted: Thu Jul 10, 2008 12:39 pm Post subject: S7-914 Empty Weight...and questions? |
165lb. sounds like it may be the weight on the tail wheel with the wings
folded.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Thu Jul 10, 2008 2:13 pm Post subject: S7-914 Empty Weight...and questions? |
Even that seems a bit high.
Deke
davestapa
Joined: 13 Mar 2007 Posts: 30 Location: Woodstock, GA
Posted: Thu Jul 10, 2008 5:39 pm Post subject: S7-914 Empty Weight...and questions? |
I have the 912 ULS in a Series 5. Weights are Left Main 390 lbs, Right
Main 376 Lbs, Tail wheel 67 lbs for a total of 833 lbs.
C. David Estapa
Woodstock, Georgia
N97DE S5 TD 912ULS
On Thu, 10 Jul 2008 01:00:26 -0700 "darinh" <gerns25(at)netscape.net>
writes:
5 thru 7.
Darin Hawkes
Series 7 (Final Assembly)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=192090#192090
____________________________________________________________
Fabulous Spa Getaway!
Enter for your chance to WIN great beauty prizes everyday!
http://thirdpartyoffers.juno.com/TGL2141/fc/JKFkuJi7VOAuq7lpSZnvUurlFuzLSuvKYGU10FZBnsWVtPAj4xTXDl/
_________________ C. David Estapa
Woodstock, GA
S5TD N97DE |
