		grantr
				 Posted: Mon Jul 14, 2008 5:01 am    Post subject: off field landings |
				I am a little concerned about my Mark 3 flipping over on its back during an off field emergency landing into a corn, cotton or peanut field.
  http://photobucket.com/grant-kolb
 As you can see from the photos I have plenty of emergency landing options.
 How many of you have have to make a landing into similar crops and what was the outcome? My plane has a nose skid but I dont know if that would help much in preventing it from flipping over in a crop landing.
 Grant
				 Posted: Mon Jul 14, 2008 5:36 am    Post subject: off field landings |
				Grant, having done the 20' nose slide in 3 foot alfalfa earlier this
 summer, I would say the MkIII should
 resist a flipover better than a FS.  The extra weight is a factor and
 also the shorter legs (if you still have the
 old aluminum ones)   The nose hoop would save the bowl from damage.
 My home made aluminum
 nose sticks out more than stock and gives me a little more help.
 Lucky, no rocks this time
 BB, MkIII, suzuki, now featuring new improved pitot tube.
 On 14, Jul 2008, at 9:01 AM, grantr wrote:
  <grant_richardson25(at)yahoo.com>
  field.
  options.
  landing.
  Grant
  http://forums.matronics.com/viewtopic.php?p=192631#192631
				 Posted: Mon Jul 14, 2008 8:01 am    Post subject: off field landings |
				At 06:01 AM 7/14/08 -0700, you wrote:
 Grant,
 I have been in a bean and a corn field with the FireFly.  The beans were
 short and the ground was soft.  The corn field was stubble field in the
 spring so the surface was fairly firm.  In both cases landed with the rows,
 and did not go up on the nose.  Flared into ground effect and held it off
 nose high so that I planted the tail wheel first.  No damage from landing in
 the beans.  In the cornfield I bent the right landing gear leg a bit as it
 happened to travel right down a row.  A corn stalk poked a hole in the
 outboard bottom surface of the right wing.  Surprisingly, the horizontal
 tail surfaces were undamaged.
 Jack B. Hart FF004
 Winchester, IN
		smlplanet(at)msn.com Guest
				 Posted: Mon Jul 14, 2008 9:05 am    Post subject: off field landings |
				I have set them down in tall grass with no problem. Years ago I ran out of gas as I was coming low late in the evening when I had to pop over some tree at the end of the strip. I knew I couldn't make it and picked a tree and flared it and set it down in the top of the tree. After setting there a few minutes and knew it wasn't going any where I climbed down. I went to the house and got the kids C tractor C pick up C ropes and a chainsaw. Between the kids and I we was able to drop the tree and get it back on the ground with out any real damage to the plane.
  The next morning I checked it out and cleared a path to an open field where I took off and landed on the RIGHT strip. I was flying a
  Rally 2B at that time and used it to check live stock and crops. I am not sure if that tree would have held the MK3 that I fly now with it's weight but I know I could set it down on the top of it.
  	  | Quote: | 	 		   Subject: off field landings
  Date: Mon C 14 Jul 2008 06:01:48 -0700
  --> Kolb-List message posted by: "grantr" <grant_richardson25(at)yahoo.com>
  I am a little concerned about my Mark 3 flipping over on its back during an off field emergency landing into a corn C cotton or peanut field.
  Grant
  _=====
				 Posted: Mon Jul 14, 2008 9:45 am    Post subject: off field landings |
				I had a forced landing in my MKIIIC a few years ago in a bean field. The
 actual landing was uneventful with no damage. The beans were short which
 helped a bunch but by using no flaps I was able to snag some beans with my
 tail wheel before my main gear touched. The tail wheel did most of the
 stopping. The main gear sat down between the rows with the tail wheel
 snagging beans.
 Rick Neilsen
 Redrive VW powered MKIIIC
		planecrazzzy Guest
				 Posted: Mon Jul 14, 2008 11:23 am    Post subject: Re: off field landings |
				To overcome your fear of Flat Fields.... Fly over Water , Forests , Mountain
 terrain, swamp & populated areas....
  Then maybe taking your chances on a field will look better....
  Make sure your fuel "Vents" are below your tanks.....
 If you end up on yer top side....The fuel won't leak out...
  Gotta Fly...
 Mike & "Jaz" in MN
